1N5408-H0-B
1N5408-H0-B
    XINGXIN(兴芯)
    DO-27(DO-201AA)
    1N5408-H0-B
1N5408-H0-B 数据手册
Silicon Rectifiers ;[ 1N5400 THRU 1N5408  50 to 1000 V DO-27(DO-201AD) Features     Low forward voltage drop High current capability High reliability High surge current capability .96 (24.5) MIN. .220 (5.6) .197 (5.0) DIA. Mechanical Data     3.0 A .375 (9.5) .285 (7.2) Case: Molded plastic Epoxy: UL 94V-O rate flame retardant Lead: Axial leads, solder able per MIL-STD-202, Method 208 guaranteed Polarity: Color band denotes cathode end .96 (24.5) MIN. .052 (1.3) .043 (1.1) DIA. Dimensions in inches and (millimeters) Maximum Ratings and Electrical Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Single phase, half wave, 60HZ, resistive or inductive load. For capacitive load, derate current by 20%. Type Number Symbols 1N5400 1N5401 1N5402 1N5404 1N5406 1N5407 1N5408 Units VRRM 50 100 200 400 600 800 1000 Volts Maximum RMS Voltage VRMS 35 70 140 280 420 560 700 Volts Maximum DC Blocking Voltage VDC 50 100 200 400 600 800 1000 Volts Maximum Recurrent Peak Reverse Voltage Maximum Average Forward Rectified Current at TA=25℃ I(AV) 3.0 Amp IFSM 80 Amp VF 1.0 Volts Peak Forward Surge Current,8.3ms single half-sine-wave superimposed on rated load (JEDEC method) Maximum Forward Voltage at 3.0A and TA=25℃ Maximum DC reverse current at rated DC blocking voltage per Tj=25℃ Tj=100℃ Typical Junction Capacitance (Note 1) 5.0 IR uAmp 100 CJ 35 pF RθJA 30 ℃/W Operating and Storage Temperature TJ -55 to +125 Range Tstg -55 to +150 Typical Thermal Resistance (Note 2) ℃ NOTES: 1. Measured at 1 MHz and Applied Reverse Voltage of 4.0 Volts D.C. 2. Thermal Resistance from Junction to Ambient .375" (9.5mm) Lead Length. Xingxin smart-tech www.sntoweb.com 1/2 Silicon Rectifiers ;[ 1N5400 THRU 1N5408  50 to 1000 V 3.0 A RATINGS AND CHARACTERISTIC CURVES FIG.1-TYPICAL FORWARD FIG.2-TYPICAL FORWARD CURRENT DERATING CURVE AVERAGE FORWARD CURRENT,(A) CHARACTERISTICS 10 3.0 2.0 1.0 Resistive Or Inductive Load 0.5 0.375"(9.5mm) Lead Length 0.3 0 0 25 50 75 100 125 150 175 AMBIENT TEMPERATURE,(℃) 1.0 Tj=25 C Pulse Width 300us 1% Duty Cycle 0.1 FIG.4-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT .01 .6 .7 .8 .9 1.0 1.1 1.2 1.3 FORWARD VOLTAGE,(V) FIG.3 - TYPICAL REVERSE CHARACTERISTICS 100 PEAK FORWARD SURGE CURRENT,(A) INSTANTANEOUS FORWARD CURRENT,(A) 50 3.0 150 120 90 Tj=25 C 8.3ms Single Half Sine Wave 60 JEDEC method 30 0 1 5 10 50 100 NUMBER OF CYCLES AT 60Hz REVERSE LEAKAGE CURRENT, (μA) 10 Tj=100 C 1.0 Tj=25 C .1 .01 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) Xingxin smart-tech www.sntoweb.com 2/2
1N5408-H0-B 价格&库存
很抱歉,暂时无法提供与“1N5408-H0-B”相匹配的价格&库存,您可以联系我们找货
