SA22300FAP
SA22300FAP
    SILERGY(矽力杰)
    SOP-8
    线性稳压器/LDO SOP-8 3.45V~36V
SA22300FAP 数据手册
Application Note: SA22300 36V, Boost/Flyback/Sepic Controller General Description Key Features              i tt r Fo ep The SA22300 is available in a SOP8 package. d The SA22300 integrates a gate driver to drive external N-channel MOSFET and also adopts peak current control strategy with built-in slope compensation to improve the stability. Wide Input Voltage Range: 3.45V to 36V 1.2V ±2% Reference Voltage Fixed Frequency Operation Internal Soft-Start Typical 1.6μA Shutdown Current Cycle-by-Cycle Current Limit Protection Hiccup-Mode Overcurrent Protection (OCP) Hiccup-Mode Short-Circuit Protection (SCP) 1.5A Peak Gate Source Current 1.5A Peak Gate Sink Current Thermal Shutdown Package: SOP8 Automotive AEC- Q100 Grade 1 Certified ar e The SA22300 is a non-synchronous Boost/Flyback/ Sepic controller with built-in protection features. The device is suitable for harsh automotive environment. It features several built-in protection such as cycleby-cycle current limit, overcurrent protection, FB short protection, etc. Ordering Information Pr Applications l SA22300 □(□□ □) nt Automotive 12-V Battery Application DC-to-DC Converters LIDAR Power Supply Battery-powered Boost, Flyback, Sepic Note de Package Type SOP8     fi Ordering Number SA22300FAP ia Package Code Optional Spec Code .C on Typical Application Circuit RFB1 Co CIN D L rp VSUPPLY VOUT CO RO rg y VIN Q GATE EN RFB2 le RGS ISEN Si RSEN GND FB COMP Rz Cz VCC CVCC Figure 1. Boost Application AN_SA22300 Rev. 0.9 © 2023 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 1 All Rights Reserved. SA22300 VSUPPLY D 1:N VOUT CIN CO RO VIN Q tt i GATE EN RGS RSEN r ISEN Fo RFB1 GND FB COMP RFB2 d Rz Cz ar e VCC Pr ep CVCC ia l Figure 2. Flyback Application nt VSUPPLY * * Coupling L fi de CIN D on VIN .C rp AN_SA22300 Rev. 0.9 © 2023 Silergy Corp. RFB1 CO RO RGS RSEN Co rg y le Si Cz C1 ISEN RFB2 GND COMP Rz Q GATE EN VOUT FB VCC CVCC Figure 3. Sepic Application Silergy Corp. Confidential- Prepared for Customer Use Only 2 All Rights Reserved. SA22300 Block Diagram LDO enable_LDO VCC2 EN_OK LDO2 VBG bandgap FB - SCP VREF VCC Vscp + VREF Vth Select + + gm_ea - Burst_mode - logic GATE S Q clock ep SS ar e d VCC2 Fo r + - VEN _H Power_Ready EN_OK VIN_OK OTP EN VCC_OK + - VVCC_R i VIN_OK + - VUVLO_R VCC tt VIN VCC2 R Pr Shutdown IFB_PU GND Min_Ton FB l ia COMP + + fi on SLOPE rp Peak_limit GND + Oneshot clock Hiccup Timer OTP Power_ready + - VCL SCP OCP + - 150%VCL Thermal sensor 165 Figure 4. Block Diagram Si le rg y Co Shutdown ISEN + Acsa - Max_ D .C Oscillator IIS EN_PU + de Shutdown nt High clamp &Low clamp VCC2 Shutdown Peak_limit Max_D - AN_SA22300 Rev. 0.9 © 2023 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 3 All Rights Reserved. SA22300 Pin-Out (Top View) EN 1 7 COMP GND 3 6 VIN GATE 4 5 VCC d Fo r tt ISEN 2 i 8 FB 2 GND 3 GATE 4 VCC 5 VIN 6 COMP 7 FB 8 Pr ISEN Pin Description Enable pin, apply logic high signal to enable the device. Current sense input pin. Voltage generated across an external sense resistor is fed into this pin. Ground pin. Gate driver output. Connect to the gate of the external N-channel MOSFET. GATE pin will turn into high impedance state when EN is off. Put a 10kΩ resistor between MOSFET gate and source or GND to prevent electric accumulation of gate charge. 10.5V internal LDO output from VIN. Do not leave open, bypass with 1μF ceramic capacitor. Power supply input pin. A 100nF ceramic capacitor is recommended to be placed close to VIN and GND pin. External compensation pin. Connect RC network from this pin to GND to compensate the control loop. Output voltage feedback pin. The output voltage reference is 1.2V. Si le rg y Co rp .C on fi de nt ia l EN Pin Number 1 Pin Name ep ar e (SOP8) Top Mark: FEMxyz (Device code:FEM, x=year code, y=week code, z= lot number code) AN_SA22300 Rev. 0.9 © 2023 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 4 All Rights Reserved. SA22300 Absolute Maximum Ratings (Note 1) tt i VIN, EN----------------------------------------------------------------------------------------------------------------- -0.3V to 40V FB, ISEN, COMP------------------------------------------------------------------------------------------------------ -0.3V to 6V GATE, VCC ----------------------------------------------------------------------------------------------------------- -0.3V to 13V Power dissipation @TA = 25℃ -------------------------------------------------------------------------------------------- 1.26W Package Thermal Resistance (Note 2) θ JA ---------------------------------------------------------------------------------------------------------------------- 98.5°C/W θ JB ------------------------------------------------------------------------------------------------------------------------- 58°C/W ep ar e d Fo r ΨJT ------------------------------------------------------------------------------------------------------------------------- 10°C/W Junction Temperature Range ------------------------------------------------------------------------------------- -40°C to 150°C Lead Temperature (Soldering, 10 sec.) ------------------------------------------------------------------------------------ 260°C Storage Temperature Range -------------------------------------------------------------------------------------- -65°C to 150°C ESD Susceptibility (Note3) HBM (Human Body Mode) --------------------------------------------------------------------------------------------------- 2000V CDM (Charge Device Mode)All pins------------------------------------------------------------------------------------------500V Pr Recommended Operating Conditions (Note 3) Si le rg y Co rp .C on fi de nt ia l Supply Voltage VIN -------------------------------------------------------------------------------------------------- 3.45V to 36V EN --------------------------------------------------------------------------------------------------------------------------- 0V to 36V Ambient Temperature Range ------------------------------------------------------------------------------------- -40°C to 125°C AN_SA22300 Rev. 0.9 © 2023 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 5 All Rights Reserved. SA22300 Electrical Characteristics (3.45V≤VIN≤36V,-40°C≤TA≤125°C, unless otherwise specified) Typ Max Unit VUVLO_R 3.05 3.225 3.45 V VUVLO_F ISD IOP 2.9 VEN=0V VEN=3V, no switching 3.1 1.6 1.5 VVCC VDROP IVCC_LIMH IVCC=10mA, VIN=12V IVCC = 50mA VCC drop 10% Co rg y Si le Error Amplifier Transconductance of Error Amplifier COMP Sourcing Current COMP Sinking Current COMP High Clamp COMP Low Clamp COMP Low Threshold Stop Switching Slope Compensation Current Sense ISEN Pull up Current Cycle by Cycle Current Limit Threshold Voltage AN_SA22300 Rev. 0.9 © 2023 Silergy Corp. i Min tt Test Conditions 3.35 3 2.5 V μA mA 9.2 10.5 0.4 11.8 1 120 V V mA 2.85 3.0 3.15 V 2.75 2.9 3.05 V 1.425 1.380 0.03 0.5 1.5 1.45 0.05 1 1.575 1.520 0.08 μA V V V 153 85 280 170 140 450 187 210 620 kHz ns ns 1.176 1.2 1.224 V 4.8 0.1 6 0.2 7.2 μA ms gm_ea 800 1200 1680 μS ICOMP_SOURCE ICOMP_SINK VCOMP_HIGH VCOMP_LOW 80 80 1.15 320 130 130 1.2 350 180 180 1.25 380 μA μA V mV VCOMP_BURST 370 400 430 mV 90 110 130 mV IISEN_PU 10 30 50 μA VCL 360 400 440 mV d 60 l VVCC_F .C on fi de nt ia IEN VEN_H VEN_L VEN_hys Vref IFB_PU Tss VSLOPE ar e ep Pr VVCC_R fSW tON_MIN tOFF_MIN Fo 0.5 r Symbol rp Parameter VIN VIN UVLO Rising Threshold UVLO Falling Shutdown Current Operating Current VCC VCC Output Voltage Drop Out Voltage VCC Current Limit VCC Under Voltage Reset Rising Threshold VCC Under Voltage Reset Falling Threshold EN EN Pull-Down Current EN Logic ‘1’ Threshold EN Logic ‘0’ Threshold EN Hysteresis Voltage Oscillator Switching Frequency Minimum On Time Minimum Off Time FB&SS Output Feedback Reference FB Pull up Current Soft-start Time From 10%Vref to 90%Vref D=100% Silergy Corp. Confidential- Prepared for Customer Use Only 6 All Rights Reserved. SA22300 150 175 % 1.4 0.65 2.8 1.5 4.9 2.9 Ω Ω 150 165 180 ºC 10 15 20 ºC 75 %VREF tt i 125 Fo Percent of VCL r Over Current Protection %VCL Threshold Voltage Gate Driver Gate Driver HSFET Ron RHS_ON Gate Driver LSFET Ron RLS_ON Thermal Shutdown Thermal Shutdown TSD Threshold Thermal Shutdown TSDHYS Hysteresis FB Short Circuit Protection Short Circuit Threshold Vscp Voltage 60 67 ar e d VFB as percent of Vref Pr ep Note 1: Stresses beyond the “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. ia l Note 2: θ JA is measured in the natural convection at TA = 25°C. Device mounted on an 8.5x8.5cm FR-4 substrate PCB, 2oz copper, 2 layers. nt Note 3: Electrical characteristics are not guaranteed outside its operating conditions. Si le rg y Co rp .C on fi de Note 4: Guaranteed by design. Not tested in production. AN_SA22300 Rev. 0.9 © 2023 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 7 All Rights Reserved. SA22300 Typical Performance Characteristics (TA=25°C Boost Application) Startup from VIN (VIN =12V,VOUT=24V,IOUT=1A) i Startup from VIN (VIN =12V,VOUT=24V,IOUT=0A) VIN 10V/div VOUT 10V/div VOUT 10V/div VGA TE 10V/div VGA TE 10V/div VVCC 10V/div VVCC 10V/div ar e d Fo r tt VIN 10V/div Time (4ms/div) Pr ep Time (4ms/div) Shutdown from VIN Shutdown from VIN (VIN =12V,VOUT=24V,IOUT=1A) ia l (VIN =12V,VOUT=24V,IOUT=0A) de VOUT 20V/div VIN 10V/div nt VIN 10V/div fi VOUT 20V/div on VGA TE 10V/div .C VGA TE 10V/div VVCC 10V/div rp VVCC 10V/div Time (4ms/div) rg y Co Time (10ms/div) Startup from Enable (VIN =12V,VOUT=24V,IOUT=1A) Si le Startup from Enable (VIN =12V,VOUT=24V,IOUT=0A) VEN 10V/div VEN 10V/div VOUT 10V/div VOUT 10V/div VGA TE 10V/div VGA TE 10V/div VVCC 10V/div VVCC 10V/div Time (4ms/div) AN_SA22300 Rev. 0.9 © 2023 Silergy Corp. Time (4ms/div) Silergy Corp. Confidential- Prepared for Customer Use Only 8 All Rights Reserved. SA22300 Shutdown from Enable Shutdown from Enable (VIN =12V,VOUT=24V,IOUT=0A) (VIN =12V,VOUT=24V,IOUT=1A) VEN 10V/div VEN 10V/div VOUT 20V/div tt i VOUT 20V/div VGA TE 10V/div Fo r VGA TE 10V/div VVCC 10V/div d VVCC 10V/div Time (800us/div) ep ar e Time (4ms/div) Output Voltage Ripple Output Voltage Ripple (VIN =12V,VOUT=24V,IOUT=1A) Pr (VIN =12V,VOUT=24V,IOUT=0A) nt ia l ΔVOUT 100mV/div de VGA TE 10V/div VGA TE 10V/div IL 2A/div .C on fi IL 500mA/div ΔVOUT 200mV/div Time (10us/div) Co rp Time (10us/div) Load Transient Response (VIN =12V,VOUT=24V,IOUT=0~1A) rg y Load Transient Response (VIN =12V,VOUT=24V,IOUT=0.25A~1A) ΔVOUT 500mV/div Si le ΔVOUT 500mV/div IL 1A/div IL 1A/div Time (2ms/div) AN_SA22300 Rev. 0.9 © 2023 Silergy Corp. Time (2ms/div) Silergy Corp. Confidential- Prepared for Customer Use Only 9 All Rights Reserved. SA22300 Output Over Current Protection CBC current limit protection (VIN =12V,VOUT=24V,IOUT=0.2A) (VIN =12V,set VOUT=24V, V OUT force 22.8V) VOUT 10V/div VOUT 10V/div VGA TE 10V/div IL 2A/div r tt i VGA TE 10V/div d Fo IL 2A/div Time (800us/div) ep ar e Time (10ms/div) ISEN open Protection VCC Short Circuit Protection (VIN =12V,VOUT=24V,IOUT=0.2A) Pr (VIN =12V,VOUT=24V,IOUT=0.5A) VVCC 10V/div l 1V/div ia VIS EN nt VOUT 10V/div de VCOMP 500mV/div VGA TE 10V/div IL 2A/div .C on fi VGA TE 10V/div VOUT 20V/div Time (2ms/div) Co rp Time (4ms/div) FB open Protection (VIN =12V,VOUT=24V,IOUT=0.5A) rg y FB Short Protection (VIN =12V,VOUT=24V,IOUT=0.2A) VFB 1V/div Si VOUT 20V/div VCOMP 500mV/div VGA TE 10V/div VGA TE IL 1V/div VOUT 10V/div le VCOMP 10V/div 2A/div Time (10ms/div) AN_SA22300 Rev. 0.9 © 2023 Silergy Corp. Time (800us/div) Silergy Corp. Confidential- Prepared for Customer Use Only 10 All Rights Reserved. SA22300 Efficiency VS Load Current (IOUT=0~1A, L=47μH Boost) 100 95 i 85 tt 80 9VIN /24VOUT 65 12VIN /24VOUT 16VIN /24VOUT 60 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 Fo 70 r 75 0.9 d Efficiency (%) 90 Si le rg y Co rp .C on fi de nt ia l Pr ep ar e Load Current (A) AN_SA22300 Rev. 0.9 © 2023 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 11 All Rights Reserved. SA22300 VIN Detailed Description L VCC CLK The SA22300 is a non-synchronous controller for Boost, Flyback and Sepic applications. The controller integrates a gate driver with 1.5A current capability, which can drive external MOSFET fast. Considering the operation stability and ease of use, peak current control strategy with built-in slope compensation is adopted, where the switching current is sensed through an external resistor to control the on-time. The SA22300 has a fixed-frequency clock (170kHz) to ensure constant operational frequency. During light load operation, the controller will enter burst mode to improve light-load efficiency. R nt de fi Q CO RO RGS Current sense ISEN Acsa RSEN VRAMP RFB1 FB COMP RZ i gm RFB2 tt REF CZ Fo r Figure 5. Peak Current Mode Control Scheme l Pr ep ar e d Under Voltage Lockout The SA22300 has input undervoltage lockout (UVLO) protection. If VIN pin voltage drops below the UVLO falling threshold, the device will shut down. It will not restart until VIN pin voltage surpasses the UVLO rising threshold when enabled. EN VIN UVLO_R VIN 300μs VIN UVLO_F VCC UVLO_R VCC VREF 1ms VFB SS VCOMP COMP Low Clamp GATE .C on Current Mode Control The SA22300 uses a fixed frequency peak current mode control architecture. The peak current through the external MOSFET is sensed through an external sense resistor and fed into the ISEN pin. The sensed current is added to the slope compensation ramp and fed into the positive input of the PWM comparator. The output voltage is also sensed through an external feedback resistor divider network and fed into the error amplifier negative input (feedback pin, FB). The output of the error amplifier (COMP pin) is fed into the negative input of the PWM comparator. At the start of any switching cycle, the oscillator sets the RS latch using the switch logic block. This forces a high signal on the GATE pin and the external MOSFET turns on. When the voltage on the positive input of the PWM comparator exceeds the negative input, the RS latch is reset and the external MOSFET turns off. D GATE Q ia The SA22300 has several built-in protection features and is suitable for harsh automotive environment. On the basis of peak current control, the SA22300 possesses fast and accurate cycle-by-cycle current limit and over current protection (OCP). Once the voltage drop of sense resistor exceeds OCP threshold, the controller will enter hiccup mode to prevent overheating of the external MOSEFT. Besides, the SA22300 also has VCC short, FB short, ISEN pin open and FB pin open protection. These protection measures help to improve the system reliability and make the controller robust for complicated automotive environment. S Si le rg y Co rp Figure 6. Start-up by VIN VIN EN 130μs VCC UVLO_R VCC VREF 1ms VFB SS VCOMP COMP Low Clamp GATE Figure 7. Start-up by EN The minimum supply voltage after start-up can be further decreased by supplying the VIN pin from the Boost converter output or an external power supply. AN_SA22300 Rev. 0.9 © 2023 Silergy Corp. Silergy Corp. Confidential- Prepared for Customer Use Only 12 All Rights Reserved. SA22300 D L VSUPPLY CIN VOUT VOUT CO RFB1 EN RO VIN UVLO_R Short circuit VIN Short circuit removal 300μs VIN Q GATE EN RFB2 VCC UVLO_R 50% VCC RGS VCC UVLO_F VCC current ISEN 70% Current limit RSEN FB 15μs SS VCC Cz COMP Low Clamp VCOMP COMP Low Clamp GATE Figure 8. Decrease the Minimum Operating Voltage after Start-up d Figure 9. VCC Over Current Protection Output Current Limit The voltage drop of external current sense resistor reflects the current information of the external MOSFET and is fed to ISEN pin. On this basis, SA22300 features cycle-by-cycle current limit and over current protection. cycle-by-cycle current limit. 80ns Hiccup mode auto recover. 50%VVCC 80ns - - - - FB Short Circuit 67%VREF 400ns Si le ISEN Open ep Pr fi de 15μs Turn off GATE, reset COMP and SS. Reduce current limit by 30%. 100nA pull-up current, FB voltage increase and stop switching. 30μA pull-up current, trigger OCP. Hiccup mode auto recover, typical 30ms hiccup period. .C VVCC_F on 150%VCL If the voltage between ISEN and GND pin exceeds cycle-by-cycle current limit value (VCL), the external MOSFET will be turned off for the remainder of the cycle. In cycle-by-cycle current limit state, the IC still operates with the internal fixed frequency. l 80ns ia VCL=400mV nt Shutdown when temperature>165℃ Restart when temperature0.5. It is specially designed to offer sufficient slope compensation. COUT Selection Output capacitor is used to smooth the voltage ripple. The following equation is used to calculate the minimum capacitance. Assuming the output voltage ripple is 1%, we have: Silergy Corp. Confidential- Prepared for Customer Use Only 16 All Rights Reserved. SA22300 COUT  IO D 1A  0.625   15F VO f SW 1%  24V 170kHz RZ  2RSEN f cCoVo (1  Dmax ) g m _ eaVREF 2  50m 1.9kHz  67F  24V (1 - 0.625) 1200S 1.2V  1.78k  tt i Considering the voltage drop during the load transient, as well as the capacitance drop of ceramic capacitor, we choose four 10μF ceramic capacitors. A 47μF electrolytic capacitor is also chosen in this example. We choose RZ=2kΩ in this example, and the fc becomes 2.2kHz. r Loop Compensation 1) Calculate the RHP zero frequency fRHP_z and crossover frequency fc. Fo When calculating RZ above, 50% capacitance decrease of ceramic capacitor is considered. 3) Finally, we need to choose proper CZ. If CZ=47nF, the compensated zero can be calculated as: d (1  Dmax ) 2 RO 2L 24V (1  0.625 ) 2  1A  11 .43kHz  2  47 H ep ar e f RHP _ Z  Pr fZ  1 1   1.7kHz 2RZ CZ 2  2k  47nF In this way, fz
SA22300FAP 价格&库存
很抱歉,暂时无法提供与“SA22300FAP”相匹配的价格&库存,您可以联系我们找货
