APPROVAL SHEET
RJ SERIES
PRECISION
METAL FILM RESISTORS
PRO DUCE
CHECK AN D APPRO VE
AC CEPTED BY
EM
CE
HO NO RABLE CUSTO M ER
E d iso n C h en
C h arle s C h en
D ec. 1 9, 20 23
D e c. 2 0, 202 3
w w w .th un der-resisto r.co m
sales@ thun der-re sistor.com
Page 1 of 8
1. PRODUCT: METAL FILM PRECISION RESISTORS TYPE
2. PART NUMBER: Part number of the precision metal film resistor is
identified by the series, power rating and size code, tolerance,
temperature coefficient, packing type and resistance value.
Example:
RJ
S e ries
Nam e
73
P o w er
R a tin g
B
R e s istan c e
T o le ran ce
3
T e m p era tu re
C o e ffic ie n t
(1)
Style: RJ series precision metal film resistors
(2)
Power Rating: see electrical characteristics.
(3)
Tolerance:
T
P a ck in g
T yp e
1 0 04
R e s ista n c e
V a lu e
B=±0.1%; C=±0.25%; D=±0.50%; F=±1.0%; G=±2.0%; J=±5.0%;
(4)
T.C.R.: 7=5ppm/℃; 6=10ppm/℃; 5=15ppm/℃; 4=20ppm/℃;
3=25ppm/℃; 2=50ppm/℃; 1=100ppm/℃; 0>100ppm/℃;
(5)
Packaging Type:B=BULK/BOX; T=Tape on Box Packing;
F type and M type forming are available upon request
(6)
Resistance Value: 1R00、20R0、1000、1001、1002、3303、1004
(7)
The part number of jumper is RJ**00TR000 with resistance lower than 30mΩ
3. Standard applied:
Thunder Enterprise standard: Q/SLC005-2011
Thunder Enterprise standard: Q/SLC006-2011
Page 2 of 8
4. COLOR BAND-CODE:
COLOR
1st
2nd
3rd
multiple
tolerance
TCR
black
brown
1
1
1
10
F(±1.0%)
100ppm/℃
red
2
2
2
102
G(±2.0%)
50ppm/℃
orange
3
3
3
103
15ppm/℃
yellow
4
4
4
104
25ppm/℃
green
5
5
5
105
D(±0.50%)
15ppm/℃
blue
6
6
6
106
C(±0.25%)
10ppm/℃
purple
7
7
7
B(±0.10%)
5ppm/℃
gray
8
8
8
white
9
9
9
golden
10-1
J(±5.0%)
silver
10-2
K(±10%)
Five or six color code rings designate the resistance value and tolerance
and temperature coefficient in accordance with IEC 60062.
Digital marking is available upon request.
5. DERATING CURVE
For resistors working at an ambiance
temperature of 70℃ or above, the power
shall be derated in accordance with the
curve.
The working temperature range is from -55℃ to +125℃.
Page 3 of 8
6. ELECTRICAL CHARACTERISTICS
Unless otherwise specified, all values are tested at the following condition:
Temperature:
21℃ to 25℃;
Relative humidity: 45% to 70%
Resistance out of range in available upon request
High insulation requirements are available upon request.
RJ**00TR000 is the part number of jumpers with resistance lower than 30mΩ.
Page 4 of 8
7. DIMENSION
The leads of the resistors are all tinned copper wire. The inner dimension of taping for
type size could be adjusted upon the request of customers.
Page 5 of 8
8. ENVIRONMENTAL CHARACTERISTICS
(1) Insulation Resistance
IEC 60115-1, 4.6: Apply 500VDC on resistor and V-block for 60 seconds, the test
resistance should be high than 1,000 M Ohm.
(2) Dielectric Withstanding Voltage
IEC 60115-1 4.7:
Place resistors in V-block, applied dielectric withstanding voltage
listed in the characteristic form for 60 Seconds, no breakdown or flashover and leak
current less than 10mA.
(3) Temperature Coefficient Test
IEC 60115-1, 4.8: Test of resistors at room temperature and 60°C or 100°C on request
above room temperature. The temperature coefficient is calculated by the following
equation and the value should be within the range requested.
Re sistor Temperature Coefficient
R
R R0
1
10 6
R0
t t0
= Resistance value under the testing temperature
R0 = Resistance value at the room temperature
t
t0
(4)
= the 2nd testing temperature
= Room temperature
Short Time Overload Test
IEC60115-1 4.13: At 2.5 times rated voltage or 2 times the maximum working voltage
whichever is lower for 5 seconds, the resistor should be free from defects. The
change of the resistance value should be within ±(0.10%+0.05Ω) as compared with
the value before the test.
(5)
Solderability
IEC 60115-1, 4.17: 235±5°C for 3±0.5 Seconds, there are at least 95% solder
coverage on the termination.
Page 6 of 8
(6) Resistance to soldering heat:
IEC 60115-1, 4.18: 260±3°C for 10±1 Seconds, immersed to a point 3±0.5mm from
the body. The change of the resistance value should be within ±(0.15%+0.05 Ω) as
compared with the value before the test.
(7) Climatic sequence
IEC 60115-1, 4.19:
-55°C to Room Temp. to +155°C to Room Temp. (5 cycles). The
change of the resistance value shall be within ±(0.50%+0.05 Ω) as compared with the
(8) Damp Heat Steady State
IEC 60115-1, 4.24:
40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV
or the maximum working voltage whichever is lower. The change of the resistance
value should be within ±(0.50%+0.05 Ω) for tighten tolerance resistors and
±(2.5%+0.05 Ω) for normal tolerance resistors and small size and tiny size
resistors.as compared with the value before the test.
(9) Load Life Test
IEC 60115-1, 4.25:
70±2°C at RCWV or the maximum working voltage whichever is
lower for 1,000+48/-0 Hr. (1.5Hr. on, 0.5Hr. off). The resistors shall be arranged not
much effected mutually by the temperature of others and the excessive ventilation
shall not be performed. The change of the resistance value should be within
±(0.50%+0.05 Ω) for tighten tolerance resistors and normal tolerance resistors and
small size and tiny size resistors and ±(2.5%+0.05 Ω) for normal tolerance resistors
and small size and tiny size resistors.as compared with the value before the test.
(10)
Accidental Overload Test
IEC 60115-1, 4.26: 4 times RCWV for 1 Minute. No evidence of flaming or arcing
(11)Resistance to Solvent
IEC 60115-1, 4.30: IPA for 5±0.5 Min. with ultrasonic. No deterioration of coating and
color code occurred.
Page 7 of 8
D isc la im er
A ll p ro du cts, prod uct s pecification s a nd d ata are s ub je ct to ch ange
w ith ou t n otice to im p ro ve re lia bility, fun ction o r d es ign o r oth erw ise .
T hu nd er P re cisio n R e sisto rs m a ke s n o w arran ty, re pre sen tation or
g ua rante e reg ard in g the s uitab ility o f th e p ro du cts for an y p a rtic ular
p urp os e or th e co ntinu in g prod uction of an y pro du ct to the m ax im um
e xte nt pe rm itted b y ap plica ble la w .
Page 8 of 8
很抱歉,暂时无法提供与“RJ16MB3B2000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.86001
- 30+1.80001
- 100+1.68001
- 500+1.56001
- 1000+1.50001
- 2000+1.44000
