CSMNB9MF-50
CSMNB9MF-50
    L-COM(诺通)
    Molded
    优良型模制D-SUB 线缆, DB9 公头 / DB9 母头, 50.0 FT / 15.2 M, 黑色
CSMNB9MF-50 数据手册
8 6 7 4 5 3 2 1 REVISIONS RoHS Compliant  THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. APPROVED DATE DESCRIPTION REV A CN RELEASE 2/25/08 D.GRIFFIN B ECN 4474: ADDED 1.0 FT LENGTH, UPDATED FORMAT, CHANGED NOTE, RoHS 1/7/10 D. CASTRO D D 2X, 4-40 UNC-2B SCREW LOCK LENGTH 4X, 4-40 UNC-2A THUMBSCREW PIN 1 C 2X, LOGO BOTH SIDES "P1" DB9 MALE CONNECTOR GOLD PLATED PINS WIRING MAP "P1" COLOR 1 BLACK 2 GRAY 3 RED 4 GREEN 5 BROWN 6 BLUE 7 ORANGE 8 YELLOW 9 PURPLE SHELL DRAIN WIRE B POSITION 1 UL STYLE 2464 9 CONDUCTOR CABLE PVC JACKET, COLOR: BLACK LENGTH FEET METERS 1.0 0.31 2.5 .76 1.52 5.0 10.0 3.05 15.0 4.57 25.0 7.62 15.24 50.0 PART NUMBER "J1" 1 2 3 4 5 6 7 8 9 SHELL CSMNB9MF-1 CSMNB9MF-2.5 CSMNB9MF-5 CSMNB9MF-10 CSMNB9MF-15 CSMNB9MF-25 CSMNB9MF-50 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% A NOTES: ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 .XX = ± .02 .XXX = ±.005 1. CABLE ASSEMBLY SHALL BE TESTED FOR CONTINUITY. 2. CABLE ASSEMBLY SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM PACKAGING SPEC. PS-0031. PROJECTION B APPROVALS 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE DRAWN BY 2/21/08 D.FRISIELLO CHECKED BY 2/21/08 D.FORTIN D-SUBMINIATURE 2/21/08 S.SMITH CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY COLOR VARIATIONS MAY OCCUR 7 6 5 4 3 A CATEGORY APPROVED BY PRODUCT DESCRIPTION CABLE, DB9M/F MOLDED BLK SIZE A FSCM NO. 43321 SCALE: NONE 8 C "J1" DB9 FEMALE CONNECTOR GOLD PLATED PINS 2X, MOLDED PVC STRAIN RELIEF WITH 360 FOIL SHIELD COLOR: BLACK DWG. NO. CAD FILE: 2 CSMNB9MF CSMNB9MF.SLDDRW REV. B SHEET 1 OF 1 1
CSMNB9MF-50 价格&库存
很抱歉,暂时无法提供与“CSMNB9MF-50”相匹配的价格&库存,您可以联系我们找货
