CSMN9MM-2.5
CSMN9MM-2.5
    L-COM(诺通)
    Molded
    L-COM(诺通)优良型模制D-SUB 线缆, DB9 公头 / DB9 公头, 2.5 FT / 0.75 M
CSMN9MM-2.5 数据手册
8 6 7 4 5 3 RoHS Compliant  THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. 2 1 REVISIONS DATE DESCRIPTION REV APPROVED E ECN 3779: DEFINED COLOR TO LIGHT GRAY, NEW FORMAT 1/8/09 F ECN 4474: ADDED 1.0 FT. LENGTH, UPDATED FORMAT, ADDED NOTES 1/7/10 D. CASTRO G ECN 6603: REVISED L-COM LOGO, ADDED COLOR 1/25/13 D.FRISIELLO D.FRISIELLO D D LENGTH POSITION 1 G 4X, 4-40UNC-2A THUMBSCREW C "P1" 2X, 9-PIN MALE D-SUB CONNECTOR GOLD PLATED PINS G L-COM LOGO G BOTH SIDES L-COM LOGO BOTH SIDES UL STYLE 2464 9 CONDUCTOR CABLE PVC JACKET, COLOR: LIGHT GRAY (PANTONE 400C) C POSITION 1 2X, MOLDED PVC STRAIN RELIEF AND HOOD WITH 360° METAL FOIL SHIELD COLOR: LIGHT GRAY (PANTONE 400C) G W IRING MAP B "P1" W IRE COLOR "P2" 1 BLACK 1 2 GRAY 2 3 RED 3 4 GREEN 5 PART NUMBER FEET METERS 1.0 0.31 CSMN9MM-2.5 2.5 0.76 4 CSMN9MM-5 5.0 1.52 BROW N 5 CSMN9MM-10 10.0 3.05 6 BLUE 6 CSMN9MM-15 15.0 4.57 7 ORANGE 7 CSMN9MM-25 25.0 7.62 8 YELLOW 8 CSMN9MM-125 125.0 38.10 9 PURPLE 9 SHELL DRAIN W IRE SHELL UNLESS OTHERWISE SPECIFIED, OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% NOTES: 1. CABLE ASSEMBLY SHALL BE TESTED FOR CONTINUITY. ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 .XX = ± .02 .XXX = ±.005 2. CABLE ASSEMBLY SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM PACKAGING SPEC. PS-0031. PROJECTION APPROVALS 6/7/01 TJC CHECKED BY 7/18/01 DFP 7 6 5 COLOR VARIATIONS MAY OCCUR 4 D-SUBMINIATURE 7/20/01 CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY 3 A CATEGORY APPROVED BY CM B 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE DRAWN BY CSMN-FS01 8 LENGTH CSMN9MM-1 DIMENSIONS ARE IN INCHES [mm] A "P2" PRODUCT DESCRIPTION CABLE, DB9M/M MOLDED SIZE A FSCM NO. 43321 SCALE: NONE DWG. NO. CAD FILE: 2 CSMN9MM CSMN9MM.SLDDRW REV. G SHEET 1 OF 1 1
CSMN9MM-2.5 价格&库存
很抱歉,暂时无法提供与“CSMN9MM-2.5”相匹配的价格&库存,您可以联系我们找货
