CSMN25MM-2.5
CSMN25MM-2.5
    L-COM(诺通)
    Molded
    L-COM(诺通)优良型模制D-SUB 线缆, DB25 公头 / DB25 公头,2.5 FT / 0.75 M
CSMN25MM-2.5 数据手册
8 6 7 4 5 3 2 1 REVISIONS RoHS Compliant  THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. DATE DESCRIPTION REV APPROVED G ECN 3779: DEFINED COLOR TO LIGHT GRAY, NEW FORMAT 1/8/09 D.FRISIELLO H ECN 4474: ADDED 1.0 FT. LENGTH, UPDATED FORMAT, ADDED NOTES 1/7/10 D. CASTRO J ECN 6603: REVISED L-COM LOGO, ADDED COLOR 1/25/13 D.FRISIELLO D D LENGTH "P1" POSITION 1 "P2" 4X, 4-40 UNC-2A THUMBSCREW C J 2X, MALE, 25 PIN D-SUB CONNECTOR GOLD PLATED PINS J L-COM LOGO BOTH SIDES UL STYLE 2464 25 CONDUCTOR CABLE PVC JACKET, COLOR: LIGHT GRAY (PANTONE 400C) C 2X, MOLDED PVC STRAIN RELIEF AND HOOD WITH 360° METAL FOIL SHIELD COLOR: LIGHT GRAY (PANTONE 400C) L-COM LOGO J BOTH SIDES W IRING MAP "P1" W IRE COLOR "P2" "P1" W IRE COLOR "P2" 1 BLACK 1 14 BROW N / W HITE 14 2 BROW N 2 15 RED / W HITE 15 3 RED 3 16 ORANGE / W HITE 16 4 ORANGE 4 17 GREEN / W HITE 17 5 YELLOW 5 18 BLUE / W HITE 6 GREEN 6 19 PURPLE / W HITE B A 0.31 0.76 CSMN25MM-5 5 1.52 18 CSMN25MM-10 10 3.05 19 CSMN25MM-15 15 4.57 CSMN25MM-25 25 7.62 CSMN25MM-50 50 15.24 CSMN25MM-125 125 38.1 RED / BLACK 20 8 PURPLE 8 21 ORANGE / BLACK 21 9 GRAY 9 22 YELLOW / BLACK 22 10 W HITE 10 23 GREEN / BLACK 23 11 PINK 11 24 GRAY / BLACK 24 12 LIGHT GREEN 12 25 PINK / BLACK 25 DRAIN W IRE UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] SHELL NOTES: 2. CABLE ASSEMBLY SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM PACKAGING SPEC. PS-0031. 7 6 OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 .XX = ± .02 .XXX = ±.005 1. CABLE ASSEMBLY SHALL BE TESTED FOR CONTINUITY. 8 METERS 2.5 20 SHELL FEET CSMN25MM-2.5 7 13 LENGTH PART NUMBER 1 BLUE BLACK / W HITE J CSMN25MM-1 7 13 POSITION 1 PROJECTION APPROVALS 4/30/01 TJC 7/18/01 DFP CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY COLOR VARIATIONS MAY OCCUR 4 D-SUBMINIATURE 7/19/01 CM 3 A CATEGORY APPROVED BY CSMN-FS01 5 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE DRAWN BY CHECKED BY B PRODUCT DESCRIPTION DELUXE MOLDED CABLE, DB25M TO DB25M SIZE A FSCM NO. 43321 SCALE: NONE DWG. NO. CAD FILE: 2 CSMN25MM CSMN25MM.SLDDRW REV. J SHEET 1 OF 1 1
CSMN25MM-2.5 价格&库存
很抱歉,暂时无法提供与“CSMN25MM-2.5”相匹配的价格&库存,您可以联系我们找货
