CHD26MM-1
CHD26MM-1
    L-COM(诺通)
    Molded
    L-COM(诺通)优良型模制D-SUB线缆,HD26公头/公头,1英尺(0.3米)
CHD26MM-1 数据手册
8 6 7 4 5 3 2 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. D APPROVED DATE DESCRIPTION REV E ECN 7237: ADDED CHD26MM-1, ADDED REGULATORY 1/14/14 - - - - - - - - - - - - D. CASTRO D LENGTH 2X, L-COM LOGO BOTH SIDES 4X, 4-40UNC-2A THUMBSCREW "P1" POSITION 1 B A 8 "P2" U.L. STYLE 2464, 26 COND. 26AWG STRANDED TINNED COPPER WITH ALUM/POLY FOIL SHIELD AND DRAIN WIRE. JACKET: PVC, LIGHT GRAY (PANTONE 400C) C 2X, MALE 26 PIN HIGH DENSITY D-SUB CONNECTOR GOLD PLATED PINS 2X, MOLDED PVC HOOD AND STRAIN RELIEF WITH 360° METAL FOIL SHIELD COLOR: LIGHT GRAY (PANTONE 400C) "P1" 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 SHELL 7 WIRING MAP COLOR BROWN RED ORANGE YELLOW GREEN BLUE VIOLET GRAY WHITE LIGHT GREEN BLACK GRAY/BLACK BLUE/WHITE VIOLET/WHITE BROWN/WHITE BLACK/WHITE RED/WHITE ORANGE/WHITE GREEN/WHITE GRAY/GREEN GRAY/RED GRAY/VIOLET LIGHT GREEN/BLACK RED/BLACK ORANGE/BLACK YELLOW/BLACK DRAIN WIRE 6 "P2" 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 SHELL C POSITION 1 PART NUMBER E FEET 1.0 2.5 5.0 10.0 15.0 CHD26MM-1 CHD26MM-2.5 CHD26MM-5 CHD26MM-10 CHD26MM-15 LENGTH METERS 0.31 0.76 1.52 3.05 4.57 B NOTES: 1. CABLE SHALL BE TESTED FOR CONTINUITY. 2. CABLE SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM SPECIFICATION PS-0031. E REGULATORY COMPLIANCE: CE2011/65/EU(RoHS DIRECTIVE) APPROVALS UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 [5.08] .XX = ± .02 [.51] .XXX = ±.005 [.13] PROJECTION 8/15/01 TJC CHECKED BY 8/16/01 DFP CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY COLOR VARIATIONS MAY OCCUR 4 D-SUBMINIATURE 8/17/01 RC 3 A CATEGORY APPROVED BY CHD-FS01 5 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE DRAWN BY PRODUCT DESCRIPTION CABLE, HD26M/M MOLDED SIZE A FSCM NO. 43321 SCALE: NONE DWG. NO. CAD FILE: 2 CHD26MM CHD26MM.SLDDRW REV. E SHEET 1 OF 1 1
CHD26MM-1 价格&库存
很抱歉,暂时无法提供与“CHD26MM-1”相匹配的价格&库存,您可以联系我们找货
