CSMN15MM-5
CSMN15MM-5
    L-COM(诺通)
    Molded
    L-COM(诺通)优良型模制D-SUB 线缆, DB15 公头 / DB15 公头,5.0 FT / 1.5 M
CSMN15MM-5 数据手册
8 6 7 4 5 THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. 3 2 1 REVISIONS RoHS Compliant  DATE DESCRIPTION REV APPROVED E ECN 3779: DEFINED COLOR TO LIGHT GRAY, NEW FORMAT 1/7/09 F ECN 4474: ADDED 1.0 FT. LENGTH, UPDATED FORMAT, ADDED NOTES 1/7/10 D. CASTRO G ECN 6603: REVISED L-COM LOGO, ADDED COLOR 1/25/13 D.FRISIELLO D.FRISIELLO D D LENGTH "P1" 4X, 4-40 UNC-2A THUMBSCREW PIN 1 C 2X, 15-PIN MALE D-SUB CONNECTOR GOLD PLATED PINS G L-COM LOGO BOTH SIDES G L-COM LOGO BOTH SIDES UL STYLE 2464 15 CONDUCTOR CABLE PVC JACKET, COLOR: LIGHT GRAY G (PANTONE 400C) A 2X, MOLDED PVC STRAIN RELIEF AND HOOD WITH 360° METAL FOIL SHIELD COLOR: LIGHT GRAY (PANTONE 400C) W IRE COLOR "P2" 1 BLACK 1 2 BROW N 2 3 RED 3 FEET METERS 4 ORANGE 4 CSMN15MM-1 1 0.31 5 YELLOW 5 CSMN15MM-2.5 2.5 0.76 6 GREEN 6 CSMN15MM-5 5 1.52 7 BLUE 7 CSMN15MM-10 10 3.05 8 PURPLE 8 CSMN15MM-15 15 4.57 9 GRAY 9 CSMN15MM-25 25 7.62 10 W HITE 10 CSMN15MM-50 50 15.24 11 PINK 11 12 LIGHT GREEN 12 13 BLACK / W HITE 13 14 BROW N / W HITE 14 15 RED / W HITE 15 SHELL DRAIN W IRE SHELL UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 .XX = ± .02 .XXX = ±.005 PROJECTION APPROVALS 6/7/01 TJC CHECKED BY 7/18/01 DFP 5 COLOR VARIATIONS MAY OCCUR 4 D-SUBMINIATURE 7/19/01 CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY 3 A CATEGORY APPROVED BY CM B 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE DRAWN BY CSMN-FS01 6 LENGTH PART NUMBER 1. CABLE ASSEMBLY SHALL BE TESTED FOR CONTINUITY. 2. CABLE ASSEMBLY SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM PACKAGING SPEC. PS-0031. 7 G "P1" NOTES: 8 C PIN 1 W IRING MAP B "P2" PRODUCT DESCRIPTION DELUXE MOLDED CABLE, DB15M TO DB15M SIZE A FSCM NO. 43321 SCALE: NONE DWG. NO. CAD FILE: 2 CSMN15MM CSMN15MM.SLDDRW REV. G SHEET 1 OF 1 1
CSMN15MM-5 价格&库存
很抱歉,暂时无法提供与“CSMN15MM-5”相匹配的价格&库存,您可以联系我们找货
