CHD15MM-2.5
CHD15MM-2.5
    L-COM(诺通)
    Molded
    L-COM(诺通)优良型模制D-SUB 线缆, HD15 公头 / HD15 公头, 2.5 FT / 0.75 M
CHD15MM-2.5 数据手册
8 7 6 4 5 3 2 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. DATE APPROVED REV DESCRIPTION E ECN 6951: REVISED L-COM LOGO, NEW FORMAT, PACKAGING NOTE, ROHS 7/11/13 D.FRISIELLO F ECN 7237: ADDED CHD15MM-1, UPDATED REGULATORY 1/14/14 D. CASTRO D D LENGTH 2X MOLDED PVC HOOD AND STRAIN RELIEF, LIGHT GRAY (400C) 4X, 4-40 UNC-2A KNURLED THUMBSCREW PIN 1 PIN 1 C C 2X MALE 15-PIN HIGH DENSITY D-SUB CONNECTOR B WIRING MAP "P1" WIRE COLOR "P2" 1 BLACK 1 2 BROWN 2 3 RED 3 4 ORANGE 4 5 YELLOW 5 6 GREEN 6 7 BLUE 7 8 PURPLE 8 9 GRAY 9 10 WHITE 10 11 PINK 11 12 LIGHT GREEN 12 13 BLACK/WHITE 13 14 BROWN/WHITE 14 15 RED/WHITE 15 SHELL DRAIN WIRE SHELL U.L. STYLE 2464, 15 CONDUCTOR, 26AWG STRANDED TINNED COPPER WITH ALUMINIZED POLYESTER SHIELD AND DRAIN WIRE, JACKET: PVC, LIGHT GRAY, (PANTONE 400C) F MODEL NUMBER CHD15MM-1 CHD15MM-2.5 CHD15MM-5 CHD15MM-7.5 CHD15MM-10 CHD15MM-15 CHD15MM-25 2X, L-COM LOGO BOTH SIDES LENGTH FEET METERS 1.0 .31 2.5 .76 5.0 1.52 7.5 2.29 10.0 3.05 15.0 4.57 25.0 7.62 B NOTES: INTERNAL 360 FOIL SHIELDS IN CONNECTOR HOODS CONNECTED TO CABLE DRAIN WIRE AND CONNECTOR FRAMES. CONNECTOR PINS: GOLD PLATED. A OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% CABLE ASSEMBLY SHALL BE TESTED FOR CONTINUITY. CABLE ASSEMBLY SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM SPECIFICATION PS-0031. F APPROVALS UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 [5.08] .XX = ± .02 [.51] .XXX = ±.005 [.13] REGULATORY COMPLIANCE: CE2011/65/EU(RoHS DIRECTIVE) PROJECTION 8/8/01 TJC CHECKED BY 8/15/01 DFP 7 6 5 CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY COLOR VARIATIONS MAY OCCUR 4 D-SUBMINIATURE 8/16/01 RC 3 A CATEGORY APPROVED BY CHD-FS01 8 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE DRAWN BY PRODUCT DESCRIPTION CA, HD15 MALE TO MALE SIZE A FSCM NO. 43321 SCALE: NONE DWG. NO. CAD FILE: 2 CHD15MM CHD15MM.SLDDRW REV. F SHEET 1 OF 1 1
CHD15MM-2.5 价格&库存
很抱歉,暂时无法提供与“CHD15MM-2.5”相匹配的价格&库存,您可以联系我们找货
