BA21
BA21
    L-COM(诺通)
    SMA(DO-214AC)
    同轴线缆适配器,SMA母头/母头穿壁式,D形孔 - BA21 此款SMA母头转母头馈通穿壁式耦合器利用标准的0.300单个D型安装孔实现穿板或穿壁式同轴线缆连接。此设备通常用于在墙或其他障碍物的一侧创...
BA21 数据手册
8 6 7 4 5 3 D DESCRIPTION BODY DIELECTRIC CENTER CONTACT LOCK WASHER NUT WATERPROOF SEAL MATERIAL BRASS TEFLON BRASS BRASS BRASS RUBBER 2 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. DESCRIPTION REV A FINISH NICKEL PLATE GOLD PLATE NICKEL PLATE NICKEL PLATE - RELEASED FOR PRODUCTION DATE APPROVED 07/02/01 MCCORMICK B REVISED; ADDED THREAD CALLOUT AND PANEL OPENING 03/25/02 MCCORMICK C ECN 3124: UPDATE DWG FORMAT 12/19/07 D.GRIFFIN D ECN 5950: REVISED PER VENDOR SPECIFICATIONS, NEW FORMAT 2/1/12 D.FRISIELLO D .88 22.3 .08 2.1 .07 1.8 .24 6 .49 12.5 1/4-36 UNS-2A THREAD C C 2X SMA JACK 2X GOLD PLATED CENTER CONTACT 5/16-32 UNEF-2A THREAD .02 0.5 .31 8 .09 2.3 B B POCKET .300 .328 INTERNAL TOOTH WASHER SEAL NUT NOTES: A RECOMMENDED PANEL OPENING ELECTRICAL: IMPEDANCE: 50 OHMS FREQUENCY RANGE: DC ~ 6 GHz VOLTAGE RATING: 500 VOLTS PEAK DIELECTRIC WITHSTANDING VOLTAGE: 1000V RMS INSERTION LOSS: .15dB MAX. RoHS Compliant  UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% MISCELLANEOUS: ALL DIMENSIONS ARE FOR REFERENCE ONLY. ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 .XX = ± .02 .XXX = ±.005 COMPONENTS SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM SPECIFICATION PS-0031. PROJECTION APPROVALS 06/13/01 MCCORMICK CHECKED BY 07/02/01 D.PARHAM 7 6 5 CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY COLOR VARIATIONS MAY OCCUR 4 COAXIAL 07/02/01 ENG 3 A CATEGORY APPROVED BY REF 8 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE DRAWN BY PRODUCT DESCRIPTION SMA JACK BULKHEAD ADAPTOR SIZE A FSCM NO. 43321 SCALE: NONE DWG. NO. CAD FILE: 2 REV. D BA21 BA21.SLDDRW SHEET 1 OF 1 1
很抱歉,暂时无法提供与“BA21”相匹配的价格&库存,您可以联系我们找货
