CMB24-2M
CMB24-2M
    L-COM(诺通)
    Molded
    模制IEEE-488线缆,正向/正向,2.0m - CMB24-2M 此类线缆的最大特性在于它的高性能和它的坚固耐用。它拥有一层外部的编织屏蔽加铝箔屏蔽,加强对电磁干扰(EMI)的抵御,独特的冲压钢内...
CMB24-2M 数据手册
8 6 7 4 5 3 2 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. LENGTH D DATE DESCRIPTION REV APPROVED E ECN 7890: UPDATED FORMAT, PACKAGING, ROHS 04/02/2015 D. DESJARDIN F ECN 8117: CORRECTED FUNCTION NAMES IN WIRE MAP. 10/01/2015 D. DESJARDIN G ECN 10639: REMOVED RoHS STATEMENT 08/20/2020 PNEWTON PIN 1 D "P1" "P2" PIN 1 2X 24-PIN MALE GPIB RIBBON CONNECTOR C C 4X ISO M3.5 X 0.6 THUMBSCREW 4X TAPPED ISO M3.5 X 0.6 PIN 1 "J1" "J2" B MODEL LENGTH NUMBER METERS [FEET] CMB24-05M 0.50 [1.64] CMB24-1M 1.0 [3.28] CMB24-2M 2.0 [6.56] CMB24-3M 3.0 [9.84] CMB24-4M 4.0 [13.12] CMB24-5M 5.0 [16.40] CMB24-6M 6.0 [19.68] CMB24-8M 8.0 [26.24] PIN 1 2X 24-PIN FEMALE GPIB RIBBON CONNECTOR NOTES: MEETS REQUIREMENTS OF ANSI/IEEE STD 488.1-1987. MATERIALS: CABLE: U.L. STYLE 2464, TWELVE TWISTED PAIRS 26AWG STRANDED COPPER, OVERALL DOUBLE SHIELD ALUMINIZED POLYESTER FOIL PLUS BRAIDED TINNED COPPER WITH DRAIN WIRE, BEIGE PVC JACKET. MOLDINGS: POLYVINYLCHLORIDE, BEIGE CONNECTOR INSULATORS: GLASS-FILLED PBT (BLUE), UL94V-0 CONNECTOR CONTACTS: COPPER ALLOY, 30 MICROINCHES GOLD OVER NICKEL CONNECTOR SHELL: STAMPED STEEL OR DIE-CAST ALLOY, NICKEL PLATED THUMBSCREWS: ISO M3.5 X.0.6, STEEL, BLACK OXIDE FINISH ENVIRONMENTAL: OPERATING TEMPERATURE RANGE: -20 C TO + 80 C A UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0 MISCELLANEOUS: SEE SHEET 2 FOR WIRE MAP CABLE ASSEMBLY SHALL BE TESTED FOR CONTINUITY. CABLE ASSEMBLY SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM SPECIFICATION PS-0031. ALL OTHER DIMENSIONAL TOLERANCES: FRACTIONS .X = .2 [5] ± 1/32 .XX = .02 [.5] ANGLES ± 1° .XXX = .005 [.13] THIRD-ANGLE PROJECTION G T-Rev.D APPROVALS 8/23/2001 T CLARK CHECKED BY 9/5/2001 D PARHAM APPROVED BY 7 6 5 4 CATEGORY IEEE-488 9/10/2001 R CARRICK CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY COLOR VARIATIONS MAY OCCUR REF 8 50 High Street, West Mill, North Andover, MA 01845 USA. Phone: 1.800.341.5266 1.978.682.6936 DATE DRAWN BY 3 B PRODUCT DESCRIPTION MOLDED IEEE-488 GPIB CABLE ASSEMBLY SIZE A CAGE CODE 43321 SCALE: NONE ITEM NO. REV. G CMB24 SHEET 1 OF 2 CAD FILE: CMB24.SLDDRW 2 1 A 8 7 6 4 5 3 2 1 THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. WIRING MAP D PAIR NUMBER 1 2 3 4 C 5 6 7 8 9 B 10 11 12 DRAIN WIRE J1/P1 J2/P2 D FUNCTON 1 1 DATA LINE DI01 14 14 DATA LINE DI06 2 2 DATA LINE DI02 3 3 DATA LINE DI03 4 4 DATA LINE DI04 13 13 DATA LINE DI05 15 15 DATA LINE DI07 16 16 DATA LINE DI08 5 5 EOI 24 24 EOI RETURN 6 6 DAV 18 18 DAV RETURN 7 7 NRFD 19 19 NRDF RETURN 8 8 NDAC 20 20 NDAC RETURN 9 9 IFC 21 21 IFC RETURN 10 10 SRQ 22 22 SRQ RETURN 11 11 ATN 23 23 ATN RETURN 17 17 REN 24 24 REN RETURN 12 & SHELL 12 & SHELL C B SHIELD 50 High Street, West Mill, North Andover, MA 01845 USA. Phone: 1.800.341.5266 1.978.682.6936 A CATEGORY IEEE-488 PRODUCT DESCRIPTION MOLDED IEEE-488 GPIB CABLE ASSEMBLY SIZE A CAGE CODE 43321 SCALE: NONE T-Rev.D 8 7 6 5 4 3 ITEM NO. REV. G CMB24 SHEET 2 OF 2 CAD FILE: CMB24.SLDDRW 2 1 A
CMB24-2M 价格&库存
很抱歉,暂时无法提供与“CMB24-2M”相匹配的价格&库存,您可以联系我们找货
