CSMNB9MM-50
CSMNB9MM-50
    L-COM(诺通)
    Molded
    优良型黑色D-SUB模制线缆,DB9公头/公头,50.0FT/15.2M
CSMNB9MM-50 数据手册
8 6 7 4 5 3 2 1 REVISIONS RoHS Compliant  THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. DATE DESCRIPTION REV A CN RELEASE B ECN 4474: ADDED 1.0 FT LENGTH, UPDATED FORMAT, CHANGED NOTES, RoHS 1/7/10 APPROVED 2/25/08 D.GRIFFIN D. CASTRO D D LENGTH 4X, 4-40 UNC-2A THUMBSCREW PIN 1 PIN 1 C "P1" 2X, DB9 MALE CONNECTOR GOLD PLATED PINS 2X LOGO BOTH SIDES "P1" 1 2 3 4 5 6 7 8 9 SHELL B WIRING MAP COLOR BLACK GRAY RED GREEN BROWN BLUE ORANGE YELLOW PURPLE DRAIN WIRE UL STYLE 2464 9 CONDUCTOR CABLE PVC JACKET, COLOR: BLACK PART NUMBER CSMNB9MM-1 CSMNB9MM-2.5 CSMNB9MM-5 CSMNB9MM-10 CSMNB9MM-15 CSMNB9MM-25 CSMNB9MM-50 "P2" 1 2 3 4 5 6 7 8 9 SHELL LENGTH FEET METERS 1.0 0.31 2.5 .76 5.0 1.52 10.0 3.05 15.0 4.57 25.0 7.62 50.0 15.24 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% A NOTES: ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 .XX = ± .02 .XXX = ±.005 1. CABLE ASSEMBLY SHALL BE TESTED FOR CONTINUITY. 2. CABLE ASSEMBLY SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM PACKAGING SPEC. PS-0031. PROJECTION B APPROVALS 7 6 5 2/21/08 D.FRISIELLO CHECKED BY 2/21/08 D.FORTIN D-SUBMINIATURE 2/21/08 S.SMITH CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY 3 A CATEGORY APPROVED BY COLOR VARIATIONS MAY OCCUR 4 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE DRAWN BY REF 8 C "P2" 2X, MOLDED PVC STRAIN RELIEF WITH 360 FOIL SHIELD COLOR: BLACK PRODUCT DESCRIPTION CABLE, DB9M/M MOLDED BLK SIZE A FSCM NO. 43321 SCALE: NONE DWG. NO. CAD FILE: 2 CSMNB9MM CSMNB9MM.SLDDRW REV. B SHEET 1 OF 1 1
CSMNB9MM-50 价格&库存
很抱歉,暂时无法提供与“CSMNB9MM-50”相匹配的价格&库存,您可以联系我们找货
