8
6
7
4
5
3
2
1
REVISIONS
THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE
PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE
WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED.
D
APPROVED
DATE
DESCRIPTION
REV
E
ECN 7237: ADDED CHD26MM-1, ADDED REGULATORY
1/14/14
D. CASTRO
D
LENGTH
2X, L-COM LOGO
BOTH SIDES
4X, 4-40UNC-2A
THUMBSCREW
"P1"
POSITION 1
B
A
8
"P2"
U.L. STYLE 2464,
26 COND. 26AWG STRANDED TINNED COPPER
WITH ALUM/POLY FOIL SHIELD AND DRAIN WIRE.
JACKET: PVC, LIGHT GRAY (PANTONE 400C)
C
2X, MALE 26 PIN
HIGH DENSITY
D-SUB CONNECTOR
GOLD PLATED PINS
2X, MOLDED PVC HOOD AND STRAIN RELIEF
WITH 360° METAL FOIL SHIELD
COLOR: LIGHT GRAY (PANTONE 400C)
"P1"
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
SHELL
7
WIRING MAP
COLOR
BROWN
RED
ORANGE
YELLOW
GREEN
BLUE
VIOLET
GRAY
WHITE
LIGHT GREEN
BLACK
GRAY/BLACK
BLUE/WHITE
VIOLET/WHITE
BROWN/WHITE
BLACK/WHITE
RED/WHITE
ORANGE/WHITE
GREEN/WHITE
GRAY/GREEN
GRAY/RED
GRAY/VIOLET
LIGHT GREEN/BLACK
RED/BLACK
ORANGE/BLACK
YELLOW/BLACK
DRAIN WIRE
6
"P2"
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
SHELL
C
POSITION 1
PART
NUMBER
E
FEET
1.0
2.5
5.0
10.0
15.0
CHD26MM-1
CHD26MM-2.5
CHD26MM-5
CHD26MM-10
CHD26MM-15
LENGTH
METERS
0.31
0.76
1.52
3.05
4.57
B
NOTES:
1. CABLE SHALL BE TESTED FOR CONTINUITY.
2. CABLE SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE
WITH L-COM SPECIFICATION PS-0031.
E
REGULATORY COMPLIANCE:
CE2011/65/EU(RoHS DIRECTIVE)
APPROVALS
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES [mm]
OVERALL CABLE LENGTH TOLERANCE:
≤12 [305] = +1 [25] / -0
>12 [305] ≤60 [1524] = +2 [51] / -0
>60 [1524] ≤120 [3048] = +4 [102] / -0
>120 [3048] ≤300 [7620] = +6 [152] / -0
>300 [7620] = +5% / -0%
ALL OTHER DIMENSIONAL TOLERANCES:
.X = ± .2 [5.08]
.XX = ± .02 [.51]
.XXX = ±.005 [.13]
PROJECTION
8/15/01
TJC
CHECKED BY
8/16/01
DFP
CONFIGURATION DETAILS OF
UNDIMENSIONED FEATURES
MAY VARY
COLOR VARIATIONS
MAY OCCUR
4
D-SUBMINIATURE
8/17/01
RC
3
A
CATEGORY
APPROVED BY
CHD-FS01
5
45 BEECHWOOD DRIVE
NORTH ANDOVER, MA
01845
DATE
DRAWN BY
PRODUCT DESCRIPTION
CABLE, HD26M/M MOLDED
SIZE
A
FSCM NO.
43321
SCALE: NONE
DWG. NO.
CAD FILE:
2
CHD26MM
CHD26MM.SLDDRW
REV.
E
SHEET 1 OF 1
1
很抱歉,暂时无法提供与“CHD26MM-10”相匹配的价格&库存,您可以联系我们找货
