ASM-1406
ASM-1406
    L-COM(诺通)
    SMA(DO-214AC)
    压接式连接器,SMA公头,用于RG8、低损耗400系列线缆
ASM-1406 数据手册
8 6 7 D DESCRIPTION BODY CENTER CONTACT FERRULE INSULATOR GASKET RETAINING RING SHELL MATERIAL BRASS BRASS BRASS TEFLON RUBBER BRASS BRASS 4 5 RoHS Compliant  THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. FINISH NICKEL GOLD NICKEL --NICKEL NICKEL 3 2 1 REVISIONS DESCRIPTION REV B ECN 6444: UPDATED DRAWING FORMAT. ADDED PACKAGING DATE APPROVED 10/4/12 D. DESJARDIN D .705 17.9 C .315 8.0 C .531 13.5 1/4-36UNS-2B .610 15.5 .128 3.3 .429 10.9 B .256 6.5 RECOMMENDED PIN CRIMP SIZE RECOMMENDED FERRULE CRIMP SIZE A ELECTRICAL: IMPEDENCE: 50 OHMS WITHSTAND VOLTAGE: 1000V FREQUENCY RANGE: 0~6 GHz VSWR: 500 CYCLE CABLE RETENTION: > 40 POUNDS UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% MISCELLANEOUS: COMPONENTS SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM SPECIFICATIONS PS-0031. ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 .XX = ± .02 .XXX = ±.005 PROJECTION ALL DIMENSIONS ARE FOR REFERENCE ONLY. APPROVALS 7 6 5 10/4/12 D. DESJARDIN CHECKED BY 10/4/12 D. PARHAM COAXIAL 10/5/12 K. BURGNER CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY 3 A CATEGORY APPROVED BY COLOR VARIATIONS MAY OCCUR 4 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE DRAWN BY 1AB01-035 8 .138 3.5 RECOMMENDED CABLE STRIPPING NOTES: B PRODUCT DESCRIPTION CON,SMA MALE CRIMP LMR400 SIZE A FSCM NO. 43321 SCALE: NONE DWG. NO. CAD FILE: 2 REV. B ASM-1406 ASM-1406.SLDDRW SHEET 1 OF 1 1
ASM-1406 价格&库存
很抱歉,暂时无法提供与“ASM-1406”相匹配的价格&库存,您可以联系我们找货
