ASMBP-1100
ASMBP-1100
    L-COM(诺通)
    SMB(DO-214AA)
    SMB压接式插头,用于RG316、RG174、低损耗100系列线缆 - ASMBP-1100 SMB插头连接器采用“快速插合”式连接器设计。这些50欧姆连接器可提供0-4GHz的宽带功能。所有连接器均...
ASMBP-1100 数据手册
8 6 7 4 5 3 DESCRIPTION BODY INSULATOR BRAID HOLDER CONTACT PIN FERRULE C-RING D MATERIAL BRASS TEFLON BRASS BURYILLIUM COPPER COPPER BURYILLIUM COPPER 2 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. DATE DESCRIPTION REV D ECN 10949: REVISED CRIMP SIZE FROM .040 TO.128 FINISH NICKEL PLATE WHITE NICKEL PLATE GOLD PLATE NICKEL PLATE - APPROVED 01/27/2021 SELLIS D .66 16.8 .26 6.5 C C CONTACT PIN (SOLDER TYPE) FERRULE BODY .45 11.5 .23 5.8 .128 3.25 .09 2.3 D B B NOTES: RECOMMENDED CABLE STRIPPING ELECTRICAL: IMPEDANCE: 50 OHM FREQUENCY RANGE: DC ~ 4 GHz (USEABLE TO 10 GHz) VSWR: 1.2 MAX. @ DC ~ 4 GHz DIELECTRIC WITHSTANDING VOLTAGE: 1,000 Vrms DURABILITY: 500 CYCLES MIN. UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0 MISCELLANEOUS: APPLICATIONS: LMR100, RG174/U, RG188A/U, RG316/U. A ALL DIMENSIONS ARE FOR REFERENCE ONLY. ALL OTHER DIMENSIONAL TOLERANCES: FRACTIONS .X = .2 [5] ± 1/32 .XX = .02 [.5] ANGLES ± 1° .XXX = .005 [.13] COMPONENT SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM SPECIFICATION PS-0031. THIRD-ANGLE PROJECTION CRIMP FERRULE SIZE APPROVALS 50 High Street, West Mill, North Andover, MA 01845 USA. Phone: 1.800.341.5266 1.978.682.6936 DATE DRAWN BY 09/27/2010 DFRISIELLO CHECKED BY 09/27/2010 K.BURGNER APPROVED BY CATEGORY COAXIAL 09/27/2010 CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY COLOR VARIATIONS MAY OCCUR PRODUCT DESCRIPTION CON SMB PLUG CRIMP LMR100, RG188 SIZE A CAGE CODE 43321 SCALE: NONE T-Rev.D 8 7 6 5 4 3 REV. ITEM NO. ASMBP-1100 2 D SHEET 1 OF 1 CAD FILE: ASMBP-1100.SLDDRW 1 A
ASMBP-1100 价格&库存
很抱歉,暂时无法提供与“ASMBP-1100”相匹配的价格&库存,您可以联系我们找货
