AXA-RSJRSJB
AXA-RSJRSJB
    L-COM(诺通)
    SMA(DO-214AC)
    同轴线缆适配器,反极性SMA插座/插座穿壁式
AXA-RSJRSJB 数据手册
8 6 7 4 5 3 D DESCRIPTION BODY CENTER PIN DIELECTRIC LOCK WASHER NUT MATERIAL BRASS BRASS TEFLON BRASS BRASS 2 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. A FINISH NICKEL GOLD NICKEL NICKEL DATE DESCRIPTION REV APPROVED 4/22/10 INITIAL RELEASE D.GRIFFIN D .88 22.3 .58 14.61 .276 7.0 .232 5.9 C NUT C LOCK WASHER BODY 1/4"-36 UNS-2A .250 6.4 RECOMMENDED PANEL MOUNTING B B NOTES: A RoHS Compliant  ELECTRICAL: IMPEDANCE: 50 OHMS FREQUENCY RANGE: DC ~ 11 GHz VOLTAGE RATING: 500 VOLTS PEAK WITHSTAND VOLTAGE: 1000V RMS. INSERTION LOSS: .15 dB MAX. UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% MISCELLANEOUS: COMPONENT SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM SPEC. PS-0031 ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 .XX = ± .02 .XXX = ±.005 PROJECTION ALL DIMENSIONS ARE FOR REFERENCE ONLY. APPROVALS 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE DRAWN BY 4/21/10 D. CASTRO CHECKED BY 4/21/10 K. BURGNER COAXIAL 4/21/10 K. BURGNER CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY COLOR VARIATIONS MAY OCCUR PRODUCT DESCRIPTION ADP,RP-SMA JACK/JACK BLKHD SIZE A FSCM NO. 43321 SCALE: NONE 8 7 6 5 4 3 A CATEGORY APPROVED BY DWG. NO. CAD FILE: 2 AXA-RSJRSJB AXA-RSJRSJB.SLDDRW REV. A SHEET 1 OF 1 1
AXA-RSJRSJB 价格&库存
很抱歉,暂时无法提供与“AXA-RSJRSJB”相匹配的价格&库存,您可以联系我们找货
