CHD78MF-10
CHD78MF-10
    L-COM(诺通)
    Molded
    L-COM(诺通)优良型模制D-SUB 线缆, HD78 公头 / HD78 母头, 10.0 FT/3.0 M
CHD78MF-10 数据手册
8 6 7 4 5 3 2 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. DATE DESCRIPTION REV APPROVED E ECN 6628: UPDATED FORMAT, PKG, AND LOGOS. ADDED PANTONE # 1/21/13 F ECN 6864: REVISE END VIEWS FROM DB50MF TO HD 78MF 5/28/13 D.FRISIELLO G ECN 7237: ADDED CHD78MF-1, UPDATED REGULATORY 1/14/14 D. CASTRO D. DESJARDIN D D LENGTH POSITION 1 1 POSITION 1 2X, L-COM LOGO BOTH SIDES 4X, 4-40UNC-2A THUMBSCREW C C UL STYLE 2464, 39 TWISTED PAIR, 28AWG STRANDED TINNED COPPER WITH ALUM/POLY FOIL SHIELD PLUS TINNED COPPER BRAID SHIELD AND DRAIN WIRE. JACKET: PVC, LIGHT GRAY (PANTONE 400C) B MALE 78 PIN HIGH DENSITY D-SUB CONNECTOR GOLD PLATED PINS PART NUMBER G NOTES: A FEET 1.0 2.5 5.0 10.0 25.0 50.0 DIMENSIONS ARE IN INCHES [mm] OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% 2. CABLE SHALL BE TESTED FOR CONTINUITY. 3. CABLE SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM SPECIFICATION PS-0031. G CHD78MF-1 CHD78MF-2.5 CHD78MF-5 CHD78MF-10 CHD78MF-25 CHD78MF-50 UNLESS OTHERWISE SPECIFIED, 1. SEE SHEET 2 OF 2 FOR WIRING MAP. ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 [5.08] .XX = ± .02 [.51] .XXX = ±.005 [.13] REGULATORY COMPLIANCE: CE2011/65/EU(RoHS DIRECTIVE) PROJECTION LENGTH METERS 0.31 0.76 1.52 3.05 7.62 15.24 APPROVALS 4/2/2003 T CLARK CHECKED BY 4/3/2003 D PARHAM 7 6 5 COLOR VARIATIONS MAY OCCUR 4 D-SUBMINIATURE 4/4/2003 CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY 3 A CATEGORY APPROVED BY R CARRICK B 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE DRAWN BY CHD-FS01 8 FEMALE 78 CONTACT HIGH DENSITY D-SUB CONNECTOR GOLD PLATED PINS 2X, 4-40 UNC-2B HEX SCREWLOCK 2X, MOLDED PVC HOOD AND STRAIN RELIEF WITH 360° METAL FOIL SHIELD COLOR: LIGHT GRAY (PANTONE 400C) PRODUCT DESCRIPTION CBL,HD78M/F MOLDED SIZE A FSCM NO. 43321 SCALE: NONE DWG. NO. CAD FILE: 2 REV. G CHD78MF CHD78MF.SLDDRW SHEET 1 OF 2 1 8 6 7 5 4 3 2 1 THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. D D C C B B 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 CABLE IS WIRED STRAIGHT THROUGH FROM PIN TO LIKE-NUMBERED PIN A CATEGORY A D-SUBMINIATURE PRODUCT DESCRIPTION CBL,HD78M/F MOLDED SIZE A SCALE: 8 7 6 5 4 3 FSCM NO. 43321 DWG. NO. NONE CAD FILE: 2 REV. G CHD78MF CHD78MF.SLDDRW SHEET 2 OF 2 1
CHD78MF-10 价格&库存
很抱歉,暂时无法提供与“CHD78MF-10”相匹配的价格&库存,您可以联系我们找货
