CSMN37MM-2.5
CSMN37MM-2.5
    L-COM(诺通)
    Molded
    L-COM(诺通)优良型模制D-SUB 线缆, DB37 公头 / DB37 公头, 2.5 FT / 0.75 M
CSMN37MM-2.5 数据手册
8 6 7 4 5 "P1" 1 REVISIONS DATE DESCRIPTION REV APPROVED E ECN 4474: ADDED 1.0 FT. LENGTH, UPDATED FORMAT, ADDED NOTES 1/7/10 D. CASTRO F ECN 6603: REVISED L-COM LOGO, ADDED COLOR 1/25/13 D.FRISIELLO "P2" LENGTH F C F 2X, MALE 37-PIN D-SUB CONNECTOR A 2 POSITION 1 D B 3 RoHS Compliant  THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. "P1" 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 WIRING MAP "P2" "P1" 1 20 2 21 3 22 4 23 5 24 6 25 7 26 8 27 9 28 10 29 11 30 12 31 13 32 14 33 15 34 16 35 17 36 18 37 19 SHELL WIRE COLOR BLACK BROWN RED ORANGE YELLOW GREEN BLUE PURPLE GRAY WHITE PINK LIGHT GREEN BLACK / WHITE BROWN / WHITE RED / WHITE ORANGE / WHITE GREEN / WHITE BLUE / WHITE PURPLE / WHITE WIRE COLOR RED / BLACK ORANGE / BLACK YELLOW / BLACK GREEN / BLACK GRAY / BLACK PINK / BLACK PINK / RED PINK / BLUE PINK / GREEN LIGHT BLUE LIGHT BLUE / BLACK LIGHT BLUE / RED LIGHT BLUE / BLUE LIGHT BLUE / GREEN GRAY / RED GRAY / GREEN PURPLE / BLACK BLUE / BLACK DRAIN WIRE L-COM LOGO BOTH SIDES UL STYLE 2464 37 CONDUCTOR CABLE PVC JACKET, COLOR: LIGHT GRAY (PANTONE 400C) 4X, 4-40 UNC-2A THUMBSCREW L-COM LOGO F BOTH SIDES C 2X, MOLDED PVC STRAIN RELIEF AND HOOD WITH 360° METAL FOIL SHIELD COLOR: LIGHT GRAY (PANTONE 400C) "P2" 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 SHELL UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 .XX = ± .02 .XXX = ±.005 1. CABLE ASSEMBLY SHALL BE TESTED FOR CONTINUITY. 2. CABLE ASSEMBLY SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM PACKAGING SPEC. PS-0031. 6 F LENGTH PROJECTION APPROVALS 5 METERS 1 0.31 CSMN37MM-2.5 2.5 0.76 CSMN37MM-5 5 1.52 CSMN37MM-10 10 3.05 CSMN37MM-15 15 4.57 CSMN37MM-25 25 7.62 CSMN37MM-50 50 15.24 TJC CHECKED BY 7/18/01 DFP D-SUBMINIATURE 7/19/01 CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY 3 A CATEGORY APPROVED BY CM B 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE 5/2/01 COLOR VARIATIONS MAY OCCUR 4 FEET CSMN37MM-1 DRAWN BY CSMN-FS01 7 POSITION 1 PART NUMBER NOTES: 8 D PRODUCT DESCRIPTION DELUXE MOLDED CABLE, DB37M TO DB37M SIZE A FSCM NO. 43321 SCALE: NONE DWG. NO. CAD FILE: 2 CSMN37MM CSMN37MM.SLDDRW REV. F SHEET 1 OF 1 1
CSMN37MM-2.5 价格&库存
很抱歉,暂时无法提供与“CSMN37MM-2.5”相匹配的价格&库存,您可以联系我们找货
