8
6
7
4
5
THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE
PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE
WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED.
3
2
1
REVISIONS
RoHS Compliant
DATE
DESCRIPTION
REV
APPROVED
E
ECN 3779: DEFINED COLOR TO LIGHT GRAY, NEW FORMAT
F
ECN 4474: ADDED 1.0 FT. LENGTH, UPDATED FORMAT, ADDED NOTES
1/7/10
D. CASTRO
G
ECN 6603: REVISED L-COM LOGO, ADDED COLOR
1/25/13
D.FRISIELLO
1/12/09
D.FRISIELLO
D
D
2X, 4-40 UNC-2B
SCREWLOCK
LENGTH
4X, 4-40UNC-2A
THUMBSCREW
POSITION 1
G
L-COM LOGO
BOTH SIDES
POSITION 1
C
C
"P1"
MALE 9-PIN
D-SUB CONNECTOR
GOLD PLATED PINS
G
L-COM LOGO
BOTH SIDES
G
UL STYLE 2464
9 CONDUCTOR CABLE
PVC JACKET, COLOR: LIGHT GRAY
(PANTONE 400C)
G
"J1"
FEMALE 9-CONTACT
D-SUB CONNECTOR
GOLD PLATED CONTACTS
2X, MOLDED PVC
STRAIN RELIEF AND
HOOD WITH 360°
FOIL SHIELD
COLOR:LIGHT GRAY
(PANTONE 400C)
WIRING MAP
B
"P1"
WIRE COLOR
"J1"
1
BLACK
1
2
GRAY
2
CSMN9MF-1
1.0
0.31
CSMN9MF-2.5
2.5
0.76
3
RED
3
4
GREEN
4
5
BROWN
5
6
BLUE
6
7
ORANGE
7
8
YELLOW
8
9
PURPLE
9
SHELL
DRAIN WIRE
SHELL
PART NUMBER
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES [mm]
A
OVERALL CABLE LENGTH TOLERANCE:
≤12 [305] = +1 [25] / -0
>12 [305] ≤60 [1524] = +2 [51] / -0
>60 [1524] ≤120 [3048] = +4 [102] / -0
>120 [3048] ≤300 [7620] = +6 [152] / -0
>300 [7620] = +5% / -0%
NOTES:
1. CABLE ASSEMBLY SHALL BE TESTED FOR CONTINUITY.
ALL OTHER DIMENSIONAL TOLERANCES:
.X = ± .2
.XX = ± .02
.XXX = ±.005
2. CABLE ASSEMBLY SHALL BE INDIVIDUALLY PACKAGED IN
ACCORDANCE WITH L-COM PACKAGING SPEC. PS-0031.
PROJECTION
APPROVALS
7
6
5
METERS
CSMN9MF-5
5.0
1.52
CSMN9MF-10
10.0
3.05
CSMN9MF-15
15.0
4.57
CSMN9MF-25
25.0
7.62
TJC
CHECKED BY
7/18/01
DFP
D-SUBMINIATURE
7/19/01
CONFIGURATION DETAILS OF
UNDIMENSIONED FEATURES
MAY VARY
3
A
CATEGORY
APPROVED BY
CM
B
45 BEECHWOOD DRIVE
NORTH ANDOVER, MA
01845
DATE
6/7/01
COLOR VARIATIONS
MAY OCCUR
4
FEET
DRAWN BY
CSMN-FS01
8
LENGTH
PRODUCT DESCRIPTION
DELUXE MOLDED CABLE, DB9M/DB9F
SIZE
A
FSCM NO.
43321
SCALE: NONE
DWG. NO.
CAD FILE:
2
REV.
G
CSMN9MF
CSMN9MF.SLDDRW
SHEET 1 OF 1
1
很抱歉,暂时无法提供与“CSMN9MF-5”相匹配的价格&库存,您可以联系我们找货
