CSMN9FF-25
CSMN9FF-25
    L-COM(诺通)
    Molded
    优良型D-Sub模制线缆,DB9母头/母头,25.0ft/7.6m - CSMN9FF-25 L-com的CSMN系列D-sub 线缆组件价格实惠但性能卓越。整个线缆完全屏蔽,防止电磁干扰/射频干扰导...
CSMN9FF-25 数据手册
8 6 7 4 5 3 RoHS Compliant  THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. 2 1 REVISIONS DATE DESCRIPTION REV APPROVED A INITIAL RELEASE 12/30/10 D.GRIFFIN - - - - D D LENGTH L-COM LOGO BOTH SIDES 4X, 4-40UNC-2A THUMBSCREW "J1" C POSITION 1 POSITION 1 C UL STYLE 2464 9 CONDUCTOR CABLE PVC JACKET, COLOR: LIGHT GRAY (PANTONE 400C) L-COM LOGO BOTH SIDES B WIRE COLOR "J2" 1 BLACK 1 2 GRAY 2 3 RED 3 4 GREEN 4 5 BROWN 5 6 BLUE 6 7 ORANGE 7 8 YELLOW 8 9 PURPLE 9 SHELL DRAIN WIRE SHELL UNLESS OTHERWISE SPECIFIED, OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% NOTES: 1. CABLE ASSEMBLY SHALL BE TESTED FOR CONTINUITY. ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 .XX = ± .02 .XXX = ±.005 2. CABLE ASSEMBLY SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM PACKAGING SPEC. PS-0031. PROJECTION APPROVALS 12/29/10 D. CASTRO CHECKED BY 12/30/10 D. PARHAM 7 6 5 COLOR VARIATIONS MAY OCCUR 4 D-SUBMINIATURE 12/30/10 CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY 3 A CATEGORY APPROVED BY S. SMITH B 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE DRAWN BY - 8 LENGTH FEET METERS 1.0 0.31 2.5 0.76 5.0 1.52 10.0 3.05 15.0 4.57 25.0 7.62 50.0 15.24 PART NUMBER CSMN9FF-1 CSMN9FF-2.5 CSMN9FF-5 CSMN9FF-10 CSMN9FF-15 CSMN9FF-25 CSMN9FF-50 DIMENSIONS ARE IN INCHES [mm] A "J2" 2X FEMALE 9-CONTACT D-SUB CONNECTOR GOLD PLATED CONTACTS 2X, MOLDED PVC STRAIN RELIEF AND HOOD WITH 360° FOIL SHIELD COLOR:LIGHT GRAY (PANTONE 400C) WIRING MAP "J1" 4X, 4-40 UNC-2B SCREWLOCK PRODUCT DESCRIPTION CABLE, DB9F/F MOLDED SIZE A FSCM NO. 43321 SCALE: NONE DWG. NO. CAD FILE: 2 REV. A CSMN9FF CSMN9FF.SLDDRW SHEET 1 OF 1 1
CSMN9FF-25 价格&库存
很抱歉,暂时无法提供与“CSMN9FF-25”相匹配的价格&库存,您可以联系我们找货
