CS2N9MF-15
CS2N9MF-15
    L-COM(诺通)
    Molded
    特优型模制D-SUB 线缆, DB9 公头 / DB9 母头,15.0 FT / 4.5 M
CS2N9MF-15 数据手册
8 6 7 4 5 3 RoHS Compliant  THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. 1 REVISIONS DATE DESCRIPTION REV 2X, PVC OVERMOLD/STRAIN RELIEF COLOR: LIGHT GRAY (PANTONE 400C) WITH INTERNAL METAL BACKSHELL/SHIELD L-COM LOGO ON BOTH SIDES D 2 G ECN #3359, CN RELEASE H J APPROVED 6/3/08 E. STAUBLE ECN 4474: ADDED 1.0 FT. LENGTH, UPDATED FORMAT, ADDED NOTES 1/7/10 D. CASTRO ECN4813: ADDED 26AWG & PANTONE 400C TO CABLE DESCRIPTION. ADDED LOGO NOTE. 6/9/10 DFP D J POSITION 1 POSITION 1 LENGTH C C J "P1" MALE 9-PIN D-SUB CONNECTOR B "P1" WIRE COLOR "J1" 1 2 3 4 5 6 7 8 9 SHELL BLACK RED ORANGE YELLOW GREEN BLUE VIOLET GRAY BROWN DRAIN WIRE 1 2 3 4 5 6 7 8 9 SHELL MODEL NUMBER CS2N9MF-1 CS2N9MF-2.5 CS2N9MF-5 CS2N9MF-6 CS2N9MF-10 CS2N9MF-12 CS2N9MF-15 CS2N9MF-25 CS2N9MF-50 B UNLESS OTHERWISE SPECIFIED, OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% NOTES: 1. CABLE ASSEMBLY SHALL BE TESTED FOR CONTINUITY. ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 .XX = ± .02 .XXX = ±.005 2. CABLE ASSEMBLY SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM SPECIFICATION PS-0031. 2X, #4-40 UNC-2B SCREWLOCK LENGTH FEET METERS 1.0 0.31 2.5 0.76 5.0 1.52 6.0 1.83 10.0 3.05 12.0 3.66 15.0 4.57 25.0 7.62 50.0 15.24 DIMENSIONS ARE IN INCHES [mm] A "J1" FEMALE 9-PIN D-SUB CONNECTOR UL STYLE 2919 9 CONDUCTOR (26AWG) CABLE (DOUBLE SHIELDED, BRAID & FOIL) JACKET: PVC, COLOR: LIGHT GRAY (PANTONE 400C) 4X, #4-40 UNC-2A THUMBSCREW PROJECTION APPROVALS 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE DRAWN BY 9/27/01 TJC CHECKED BY 9/28/01 DFP D-SUBMINIATURE 10/4/01 RC CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY COLOR VARIATIONS MAY OCCUR PRODUCT DESCRIPTION CABLE, DB9M/F DBL SHLD SIZE A FSCM NO. 43321 SCALE: NONE 8 7 6 5 4 3 A CATEGORY APPROVED BY DWG. NO. CAD FILE: 2 REV. J CS2N9MF CS2N9MF.SLDDRW SHEET 1 OF 1 1
CS2N9MF-15 价格&库存
很抱歉,暂时无法提供与“CS2N9MF-15”相匹配的价格&库存,您可以联系我们找货
