CS2N25MM-25
CS2N25MM-25
    L-COM(诺通)
    Molded
    L-COM(诺通)特优型模制D-SUB 线缆, DB25 公头 / DB25 公头, 25.0 FT / 7.6 M
CS2N25MM-25 数据手册
8 6 7 4 5 3 D 2 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. DESCRIPTION REV K APPROVED DATE ECN 7298: REVISE MOLDED HOOD, FORMAT, ROHS, CBL DESCRIPTION 2/18/14 D.FRISIELLO 2X, OVERMOLD HOOD/STRAIN RELIEF MATERIAL: PVC, COLOR: LIGHT GRAY (PANTONE 400C) -WITH INTERNAL METAL BACKSHELL/SHIELD L-COM LOGO ON BOTH SIDES PIN 1 D LENGTH K K C "P1" 2X DB25-PIN MALE D-SUB CONNECTOR B A K "P1" 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 SHELL 4X, #4-40 UNC-2A THUMBSCREW WIRE COLOR BLACK BROWN RED ORANGE YELLOW GREEN BLUE VIOLET GRAY WHITE PINK PINK/BLACK LIGHT GREEN BLACK/WHITE BROWN/WHITE RED /WHITE ORANGE/WHITE GREEN/WHITE BLUE/WHITE VIOLET/WHITE RED/BLACK ORANGE/BLACK YELLOW/BLACK GREEN/BLACK GRAY/BLACK DRAIN WIRE C U.L. STYLE 2919 TYPE CL2 25 CONDUCTOR 26AWG STRANDED TINNED COPPER WITH ALUM/POLY FOIL SHIELD AND DRAIN WIRE PLUS TINNED COPPER BRAID SHIELD JACKET: PVC, LIGHT GRAY (PANTONE 400C) NOM. DIA: .323"[8.20], MIN.BEND RAD: 3.25"[82.5] "P2" LENGTH MODEL "P2" 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 SHELL PIN 1 (FEET) (METERS) CS2N25MM-1 1.0 0.31 CS2N25MM-2.5 2.5 0.76 CS2N25MM-5 5.0 1.52 CS2N25MM-6 6.0 1.83 CS2N25MM-10 10.0 3.05 CS2N25MM-12 12.0 3.66 CS2N25MM-15 15.0 4.57 CS2N25MM-25 25.0 7.62 CS2N25MM-50 50.0 15.24 NUMBER B NOTES: 1. CABLE ASSEMBLY SHALL BE TESTED FOR CONTINUITY. 2. CABLE ASSEMBLY SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM SPECIFICATION PS-0031. REGULATORY COMPLIANCE: CE2011/65/EU(RoHS DIRECTIVE) K UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 [5.08] .XX = ± .02 [.51] .XXX = ±.005 [.13] PROJECTION APPROVALS 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE DRAWN BY 9/27/01 TJC CHECKED BY 9/28/01 DFP D-SUBMINIATURE 10/4/01 RC CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY COLOR VARIATIONS MAY OCCUR PRODUCT DESCRIPTION CABLE, DB25M/M DBL SHLD SIZE A FSCM NO. 43321 SCALE: NONE 8 7 6 5 4 3 A CATEGORY APPROVED BY DWG. NO. CAD FILE: 2 CS2N25MM CS2N25MM.SLDDRW REV. K SHEET 1 OF 1 1
CS2N25MM-25 价格&库存
很抱歉,暂时无法提供与“CS2N25MM-25”相匹配的价格&库存,您可以联系我们找货
