CSMN37MF-2.5
CSMN37MF-2.5
    L-COM(诺通)
    Molded
    优良型模制D-SUB 线缆, DB37 公头 / DB37 母头, 2.5 FT / 0.75 M
CSMN37MF-2.5 数据手册
8 6 7 4 5 3 D 2 1 REVISIONS RoHS Compliant  THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. E ECN 4474: ADDED 1.0 FT. LENGTH, UPDATED FORMAT, ADDED NOTES 1/7/10 D. CASTRO F ECN 6603: REVISED L-COM LOGO, ADDED COLOR 1/25/13 D.FRISIELLO 2X, 4-40 UNC-2B SCREWLOCK LENGTH POSITION 1 APPROVED DATE DESCRIPTION REV D POSITION 1 F C F "P1" MALE 37-PIN D-SUB CONNECTOR "P1" 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 B A WIRING MAP "J1" "P1" 1 20 2 21 3 22 4 23 5 24 6 25 7 26 8 27 9 28 10 29 11 30 12 31 13 32 14 33 15 34 16 35 17 36 18 37 19 SHELL WIRE COLOR RED / BLACK ORANGE / BLACK YELLOW / BLACK GREEN / BLACK GRAY / BLACK PINK / BLACK PINK / RED PINK / BLUE PINK / GREEN LIGHT BLUE LIGHT BLUE / BLACK LIGHT BLUE / RED LIGHT BLUE / BLUE LIGHT BLUE / GREEN GRAY / RED GRAY / GREEN PURPLE / BLACK BLUE / BLACK DRAIN WIRE "J1" 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 SHELL 6 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% PROJECTION APPROVALS METERS CSMN37MF-1 1 0.31 CSMN37MF-2.5 2.5 0.76 CSMN37MF-5 5 1.52 CSMN37MF-10 10 3.05 CSMN37MF-15 15 4.57 CSMN37MF-25 25 7.62 CSMN37MF-50 50 15.24 TJC CHECKED BY 7/18/01 DFP D-SUBMINIATURE 7/19/01 CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY 3 A CATEGORY APPROVED BY CM B 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE 6/7/01 COLOR VARIATIONS MAY OCCUR 4 LENGTH FEET DRAWN BY CSMN-FS01 5 F PART NUMBER ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 .XX = ± .02 .XXX = ±.005 1. CABLE ASSEMBLY SHALL BE TESTED FOR CONTINUITY. 2. CABLE ASSEMBLY SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM PACKAGING SPEC. PS-0031. 7 "J1" FEMALE 37-PIN D-SUB CONNECTOR 2X, MOLDED PVC STRAIN RELIEF AND HOOD WITH 360° METAL FOIL SHIELD COLOR: LIGHT GRAY (PANTONE 400C) NOTES: 8 C UL STYLE 2464 37 CONDUCTOR CABLE PVC JACKET, COLOR: LIGHT GRAY (PANTONE 400C) 4X, 4-40 UNC-2A THUMBSCREW L-COM LOGO F BOTH SIDES WIRE COLOR BLACK BROWN RED ORANGE YELLOW GREEN BLUE PURPLE GRAY WHITE PINK LIGHT GREEN BLACK / WHITE BROWN / WHITE RED / WHITE ORANGE / WHITE GREEN / WHITE BLUE / WHITE PURPLE / WHITE L-COM LOGO BOTH SIDES PRODUCT DESCRIPTION DELUXE MOLDED CABLE, DB37M TO DB37F SIZE A FSCM NO. 43321 SCALE: NONE DWG. NO. CAD FILE: 2 CSMN37MF CSMN37MF.SLDDRW REV. F SHEET 1 OF 1 1
CSMN37MF-2.5 价格&库存
很抱歉,暂时无法提供与“CSMN37MF-2.5”相匹配的价格&库存,您可以联系我们找货
