CSMN9MF-25
CSMN9MF-25
    L-COM(诺通)
    Molded
    优良型模制D-SUB 线缆, DB9 公头 / DB9 母头, 25.0 FT / 7.6 M
CSMN9MF-25 数据手册
8 6 7 4 5 THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. 3 2 1 REVISIONS RoHS Compliant  DATE DESCRIPTION REV APPROVED E ECN 3779: DEFINED COLOR TO LIGHT GRAY, NEW FORMAT F ECN 4474: ADDED 1.0 FT. LENGTH, UPDATED FORMAT, ADDED NOTES 1/7/10 D. CASTRO G ECN 6603: REVISED L-COM LOGO, ADDED COLOR 1/25/13 D.FRISIELLO 1/12/09 D.FRISIELLO D D 2X, 4-40 UNC-2B SCREWLOCK LENGTH 4X, 4-40UNC-2A THUMBSCREW POSITION 1 G L-COM LOGO BOTH SIDES POSITION 1 C C "P1" MALE 9-PIN D-SUB CONNECTOR GOLD PLATED PINS G L-COM LOGO BOTH SIDES G UL STYLE 2464 9 CONDUCTOR CABLE PVC JACKET, COLOR: LIGHT GRAY (PANTONE 400C) G "J1" FEMALE 9-CONTACT D-SUB CONNECTOR GOLD PLATED CONTACTS 2X, MOLDED PVC STRAIN RELIEF AND HOOD WITH 360° FOIL SHIELD COLOR:LIGHT GRAY (PANTONE 400C) WIRING MAP B "P1" WIRE COLOR "J1" 1 BLACK 1 2 GRAY 2 CSMN9MF-1 1.0 0.31 CSMN9MF-2.5 2.5 0.76 3 RED 3 4 GREEN 4 5 BROWN 5 6 BLUE 6 7 ORANGE 7 8 YELLOW 8 9 PURPLE 9 SHELL DRAIN WIRE SHELL PART NUMBER UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] A OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% NOTES: 1. CABLE ASSEMBLY SHALL BE TESTED FOR CONTINUITY. ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 .XX = ± .02 .XXX = ±.005 2. CABLE ASSEMBLY SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM PACKAGING SPEC. PS-0031. PROJECTION APPROVALS 7 6 5 METERS CSMN9MF-5 5.0 1.52 CSMN9MF-10 10.0 3.05 CSMN9MF-15 15.0 4.57 CSMN9MF-25 25.0 7.62 TJC CHECKED BY 7/18/01 DFP D-SUBMINIATURE 7/19/01 CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY 3 A CATEGORY APPROVED BY CM B 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE 6/7/01 COLOR VARIATIONS MAY OCCUR 4 FEET DRAWN BY CSMN-FS01 8 LENGTH PRODUCT DESCRIPTION DELUXE MOLDED CABLE, DB9M/DB9F SIZE A FSCM NO. 43321 SCALE: NONE DWG. NO. CAD FILE: 2 REV. G CSMN9MF CSMN9MF.SLDDRW SHEET 1 OF 1 1
CSMN9MF-25 价格&库存
很抱歉,暂时无法提供与“CSMN9MF-25”相匹配的价格&库存,您可以联系我们找货
