CHD15MF-2.5
CHD15MF-2.5
    L-COM(诺通)
    Molded
    L-COM(诺通)优良型模制D-SUB 线缆, HD15 公头 / HD15 母头, 2.5 FT / 0.75 M
CHD15MF-2.5 数据手册
8 6 7 4 5 3 2 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. D APPROVED DESCRIPTION E ECN 6951: REVISED L-COM LOGO, NEW FORMAT, PACKAGING NOTE, ROHS 7/11/13 D.FRISIELLO F ECN 7237: ADDED CHD15MF-1, UPDATED REGULATORY 1/14/14 D. CASTRO D LENGTH 2X, 4-40 UNC-2B HEX STANDOFF 4X, 4-40 UNC-2A KNURLED JACKSCREW, PIN 1 DATE REV PIN 1 2X MOLDED PVC HOOD AND STRAIN RELIEF, LIGHT GRAY (400C) C 2X, L-COM LOGO BOTH SIDES "P1" MALE 15-PIN HIGH DENSITY D-SUB CONNECTOR WIRING MAP "P1" WIRE COLOR "J1" 1 BLACK 1 2 BROWN 2 3 RED 3 4 ORANGE 4 5 YELLOW 5 6 GREEN 6 7 BLUE 7 8 PURPLE 8 9 GRAY 9 10 WHITE 10 11 PINK 11 12 LIGHT GREEN 12 13 BLACK/WHITE 13 14 BROWN/WHITE 14 15 RED/WHITE 15 SHELL DRAIN WIRE SHELL B U.L. STYLE 2464 15-CONDUCTOR, 26AWG STRANDED TINNED COPPER WITH ALUMINIZED POLYESTER SHIELD AND DRAIN WIRE, JACKET: PVC, LIGHT GRAY, (PANTONE 400C) NOTES: INTERNAL 360 FOIL SHIELDS IN CONNECTOR HOODS CONNECTED TO CABLE DRAIN WIRE AND CONNECTOR FRAMES. OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% CABLE ASSEMBLY SHALL BE TESTED FOR CONTINUITY. CABLE ASSEMBLY SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM SPECIFICATION PS-0031. F APPROVALS UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] CONNECTOR PINS: GOLD PLATED. A ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 [5.08] .XX = ± .02 [.51] .XXX = ±.005 [.13] REGULATORY COMPLIANCE: CE2011/65/EU(RoHS DIRECTIVE) LENGTH FEET METERS 1.0 .31 2.5 .76 5.0 1.52 7.5 2.29 10.0 3.05 15.0 4.57 25.0 7.62 MODEL NUMBER CHD15MF-1 CHD15MF-2.5 CHD15MF-5 CHD15MF-7.5 CHD15MF-10 CHD15MF-15 CHD15MF-25 F PROJECTION 7 6 5 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 8/8/01 TJC CHECKED BY 8/15/01 DFP D-SUBMINIATURE 8/16/01 RC CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY 3 A CATEGORY APPROVED BY COLOR VARIATIONS MAY OCCUR 4 B DATE DRAWN BY CHD-FS01 8 C "J1" FEMALE 15-POSITION HIGH DENSITY D-SUB CONNECTOR PRODUCT DESCRIPTION HD15M/F DATA CABLE ASSEMBLY SIZE A FSCM NO. 43321 SCALE: NONE DWG. NO. CAD FILE: 2 REV. F CHD15MF CHD15MF.SLDDRW SHEET 1 OF 1 1
CHD15MF-2.5 价格&库存
很抱歉,暂时无法提供与“CHD15MF-2.5”相匹配的价格&库存,您可以联系我们找货
