CSMN15MF-15
CSMN15MF-15
    L-COM(诺通)
    Molded
    L-COM(诺通)优良型模制D-SUB 线缆, DB15 公头 / DB15 母头,15.0 FT / 4.6 M
CSMN15MF-15 数据手册
8 6 7 4 5 3 D 2 1 REVISIONS RoHS Compliant  THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. DATE DESCRIPTION REV ECN 4474: ADDED 1.0 FT. LENGTH, UPDATED FORMAT, ADDED NOTES 1/7/10 D. CASTRO F ECN 6603: REVISED L-COM LOGO, ADDED COLOR 1/25/13 D.FRISIELLO D LENGTH 4X, 4-40 UNC-2A THUMBSCREW POSITION 1 C "P1" 15-PIN MALE D-SUB CONNECTOR GOLD PLATED PINS F "P1" 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SHELL B A WIRING MAP WIRE COLOR BLACK BROWN RED ORANGE YELLOW GREEN BLUE PURPLE GRAY WHITE PINK LIGHT GREEN BLACK / WHITE BROWN / WHITE RED / WHITE DRAIN WIRE "J1" 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 SHELL UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 .XX = ± .02 .XXX = ±.005 1. CABLE ASSEMBLY SHALL BE TESTED FOR CONTINUITY. 2. CABLE ASSEMBLY SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM PACKAGING SPEC. PS-0031. C 2X, MOLDED PVC STRAIN RELIEF AND HOOD WITH 360° METAL FOIL SHIELD COLOR: LIGHT GRAY (PANTONE 400C) 6 "J1" 15 CONTACT FEMALE D-SUB CONNECTOR GOLD PLATED CONTACTS F LENGTH PROJECTION APPROVALS FEET METERS CSMN15MF-1 1 0.31 CSMN15MF-2.5 2.5 0.76 CSMN15MF-5 5 1.52 CSMN15MF-10 10 3.05 CSMN15MF-15 15 4.57 CSMN15MF-25 25 7.62 CSMN15MF-50 50 15.24 6/6/01 TJC CHECKED BY 7/18/01 DFP 5 COLOR VARIATIONS MAY OCCUR 4 D-SUBMINIATURE 7/19/01 CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY 3 A CATEGORY APPROVED BY CM B 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE DRAWN BY CSMN-FS01 7 POSITION 1 PART NUMBER NOTES: 8 2X, 4-40 UNC-2B SCREW LOCK L-COM LOGO BOTH SIDES F UL STYLE 2464 15 CONDUCTOR CABLE PVC JACKET, COLOR: LIGHT GRAY F (PANTONE 400C) L-COM LOGO BOTH SIDES APPROVED E PRODUCT DESCRIPTION CABLE, DB15M/F MOLDED SIZE A FSCM NO. 43321 SCALE: NONE DWG. NO. CAD FILE: 2 CSMN15MF CSMN15MF.SLDDRW REV. F SHEET 1 OF 1 1
CSMN15MF-15 价格&库存
很抱歉,暂时无法提供与“CSMN15MF-15”相匹配的价格&库存,您可以联系我们找货
