CCS316-08
CCS316-08
    L-COM(诺通)
    SMA(DO-214AC)
    RG316 同轴线缆 , SMA 公头 / SMA 公头 , 0.67 FT / 0.2 M
CCS316-08 数据手册
8 7 6 4 5 3 2 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. D DATE DESCRIPTION REV APPROVED E ECN 4101: CN RELEASE AND NEW FORMAT F ECN 4285: CORRECT LENGTH OF CCS316-08 TO .66 [0.20] 9/28/09 D.FRISIELLO F ECN 99999: CCS316-010 WAS CCS316-10, ADDED PS-0031 10/12/10 D. CASTRO G ECN 5080: ADDED CCS316-10, CHANGE CCS316-010 TO INCHES 10/13/10 D. CASTRO 7/7/09 D.FRISIELLO D LENGTH 2X SMA PLUG NICKEL PLATE OVER BRASS GOLD PLATED CENTER CONTACTS C RG316/U, 50 OHMS COAXIAL CABLE STRANDED TINNED COPPER COVERED STEEL. WITH SILVER COATED COPPER ALLOY BRAID SHIELD. JACKET: FEP, BROWN TABLE MODEL # CCS316-08 CCS316-010 CCS316-1 CCS316-1.5 CCS316-2 CCS316-2.5 CCS316-3 CCS316-4 CCS316-5 CCS316-7.5 CCS316-10 B LENGTH FEET [METERS] 0.66 [0.20] 0.83 [0.25] 1.0 [0.30] 1.5 [0.46] 2.0 [0.61] 2.5 [0.76] 3.0 [0.91] 4.0 [1.22] 5.0 [1.52] 7.5 [2.29] 10.0 [3.05] C G B G RoHS Compliant  UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] NOTES: A 1. 2. 3. 4. CABLE ASSEMBLY IS DESIGNED FOR HIGH TEMPERATURE APPLICATIONS. OPERATING TEMPERATURE RANGE: -70˚C TO +200˚C. CABLE ASSEMBLIES SHALL BE TESTED FOR CONTINUITY. CABLE ASSEMBLIES SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM SPEC. PS-0031. OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 .XX = ± .02 .XXX = ±.005 PROJECTION APPROVALS 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE DRAWN BY 05/07/2001 C.MCCORMICK CHECKED BY 05/11/2001 D.PARHAM COAXIAL 05/14/2001 R.CARRICK CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY COLOR VARIATIONS MAY OCCUR PRODUCT DESCRIPTION CA SMA M/SMA M RG316/U SIZE A FSCM NO. 43321 SCALE: NONE 8 7 6 5 4 3 A CATEGORY APPROVED BY DWG. NO. CAD FILE: 2 REV. G CCS316 CCS316.SLDDRW SHEET 1 OF 1 1
CCS316-08 价格&库存
很抱歉,暂时无法提供与“CCS316-08”相匹配的价格&库存,您可以联系我们找货
