CRMN9FF-15
CRMN9FF-15
    L-COM(诺通)
    Molded
    L-COM(诺通)模制D-SUB 线缆, DB9 母头 / DB9 母头,带可逆硬件, 15.0 FT / 4.6 M
CRMN9FF-15 数据手册
8 7 6 4 5 3 2 DESCRIPTION REV D L-COM LOGO BOTH SIDES A DATE APPROVED E ECN 6602: ADDED NOTES, REVISED FORMAT, LOGOS, COLOR 1/14/13 D.FRISIELLO F ECN 7241: ADDED 1.0 FT LENGTH, REVISED ROHS AND FORMAT 1/20/14 D.FRISIELLO LENGTH "J1" 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. 2X, MOLDED PVC HOOD AND STRAIN RELIEF WITH 360° METAL FOIL SHIELD COLOR: LIGHT GRAY (PANTONE 400C) 4X, 4-40 UNC-2A THUMBSCREW D "J2" POSITION 1 C A C POSITION 1 4X, 4-40 UNC-2B CAPTIVE NUT 2X 9 CONTACT FEMALE, D-SUB CONNECTOR GOLD PLATED PINS UL STYLE 2464, 9 COND. 26AWG STRANDED TINNED COPPER WITH ALUM/POLY FOIL SHIELD AND DRAIN WIRE. JACKET: PVC, LIGHT GRAY (PANTONE 400C) L-COM LOGO BOTH SIDES WIRING MAP B H SECTION A-A SUPPLIED WITH THUMBSCREWS IN PLACE. NOTE: SUPPLIED WITH OPTIONAL USE HARDWARE AND INSTRUCTIONS. CABLE INTERCONNECTION HARDWARE: (4) SCREWLOCKS, H= .191" PANEL MOUNT HARDWARE: (4) SCREWLOCKS, H= .160" J1 WIRE COLOR J2 1 BLACK 1 2 GRAY 2 3 RED 3 4 GREEN 4 5 BROWN 5 6 BLUE 6 7 ORANGE 7 8 YELLOW 8 9 PURPLE 9 SHELL DRAIN WIRE SHELL UNLESS OTHERWISE SPECIFIED, OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% NOTES: 1. CABLE ASSEMBLY SHALL BE TESTED FOR CONTINUITY. 2. CABLE ASSEMBLY SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM SPECIFICATION PS-0031. F ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 [5.08] .XX = ± .02 [.51] .XXX = ±.005 [.13] REGULATORY COMPLIANCE: CE2011/65/EU(RoHS DIRECTIVE) 8 7 CRMN9FF-1 CRMN9FF-2.5 CRMN9FF-5 CRMN9FF-10 CRMN9FF-15 CRMN9FF-25 PROJECTION APPROVALS F B 5 3/10/2004 T CLARK CHECKED BY 3/30/2004 D PARHAM D-SUBMINIATURE 3/31/2004 C McCORMICK CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY 3 A CATEGORY APPROVED BY COLOR VARIATIONS MAY OCCUR 4 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE DRAWN BY CRMN-FS01 6 LENGTH FEET METERS 1.0 0.31 2.5 0.76 5.0 1.52 10.0 3.05 15.0 4.57 25.0 7.62 F DIMENSIONS ARE IN INCHES [mm] A PART NUMBER PRODUCT DESCRIPTION CA, DB9F/F REVERSIBLE HDWR SIZE A FSCM NO. 43321 SCALE: NONE DWG. NO. CAD FILE: 2 REV. F CRMN9FF CRMN9FF.SLDDRW SHEET 1 OF 1 1
CRMN9FF-15 价格&库存
很抱歉,暂时无法提供与“CRMN9FF-15”相匹配的价格&库存,您可以联系我们找货
