CSM9MF-1
CSM9MF-1
    L-COM(诺通)
    Molded
    L-COM(诺通)经济型模制D-SUB 线缆,DB9 公头 / DB9 母头,1.0 FT / 0.3 M
CSM9MF-1 数据手册
8 6 7 4 5 3 2 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. E DATE DESCRIPTION REV APPROVED 7/2/13 ECN 6940: REVISED L-COM LOGO'S, ROHS, ADDED PANTONE 424C D.FRISIELLO D D LENGTH POSITION 1 E C "P1" MALE, 9-PIN D-SUB CONNECTOR GOLD PLATED PINS 4X, 4-40UNC-2A JACKSCREW "P1" 1 2 3 4 5 6 7 8 9 SHELL B WIRING MAP COLOR BLACK GRAY RED GREEN BROWN BLUE ORANGE YELLOW PURPLE DRAIN WIRE POSITION 1 UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% 2. CABLE ASSEMBLY SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM SPECIFICATION PS-0031. ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 .XX = ± .02 .XXX = ±.005 REGULATORY COMPLIANCE: ROHS, CE PROJECTION C "J1" FEMALE, 9-PIN D-SUB CONNECTOR GOLD PLATED CONTACTS LENGTH FEET METERS 1.0 .31 2.5 .76 5.0 1.52 10.0 3.05 15.0 4.57 25.0 7.62 50.0 15.24 MODEL NUMBER CSM9MF-1 CSM9MF-2.5 CSM9MF-5 CSM9MF-10 CSM9MF-15 CSM9MF-25 CSM9MF-50 "J1" 1 2 3 4 5 6 7 8 9 SHELL 1. CABLE ASSEMBLY SHALL BE TESTED FOR CONTINUITY. E 2X, MOLDED PVC STRAIN RELIEF WITH 360° METAL FOIL SHIELD COLOR: GRAY (PANTONE 424C) E UL STYLE 2464 9 COND., 26AWG STRANDED TINNED COPPER WITH ALUM/POLY FOIL SHIELD AND DRAIN WIRE JACKET: PVC, GRAY (PANTONE 424C) NOTES: A 2X, 4-40 UNC-2B HEX STANDOFF APPROVALS 7 6 5 4/25/01 TJC CHECKED BY 4/26/01 DFP D-SUBMINIATURE 4/26/01 CM CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY 3 A CATEGORY APPROVED BY COLOR VARIATIONS MAY OCCUR 4 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE DRAWN BY CSM-FS01 8 B PRODUCT DESCRIPTION DB9M/F CABLE ASSEMBLY SIZE A FSCM NO. 43321 SCALE: NONE DWG. NO. CAD FILE: 2 REV. E CSM9MF CSM9MF.SLDDRW SHEET 1 OF 1 1
CSM9MF-1 价格&库存
很抱歉,暂时无法提供与“CSM9MF-1”相匹配的价格&库存,您可以联系我们找货
