CRMN9MF-5
CRMN9MF-5
    L-COM(诺通)
    Molded
    模制D-SUB 线缆, DB9 公头 / DB9 母头,带可逆硬件, 5.0 FT / 1.5 M
CRMN9MF-5 数据手册
8 6 7 4 5 3 L-COM LOGO BOTH SIDES A DATE APPROVED E ECN 6602: ADDED NOTES, REVISED FORMAT, LOGO, COLOR 1/14/13 D.FRISIELLO F ECN 7241: ADDED 1.0 FT LENGTH, REVISED ROHS AND FORMAT 1/20/14 D.FRISIELLO LENGTH 2X, MOLDED PVC HOOD AND STRAIN RELIEF WITH 360° METAL FOIL SHIELD COLOR: LIGHT GRAY (PANTONE 400C) 4X, 4-40 UNC-2A THUMBSCREW D "P1" POSITION 1 A C 1 DESCRIPTION REV D "J1" 2 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. POSITION 1 9 CONTACT FEMALE, D-SUB CONNECTOR GOLD PLATED CONTACTS 4X, 4-40 UNC-2B CAPTIVE NUT UL STYLE 2464, 9 COND. 26AWG STRANDED TINNED COPPER WITH ALUM/POLY FOIL SHIELD AND DRAIN WIRE. JACKET: PVC, LIGHT GRAY (PANTONE 400C) C 9 PIN MALE, D-SUB CONNECTOR GOLD PLATED PINS L-COM LOGO BOTH SIDES WIRING MAP B H SECTION A-A SUPPLIED WITH THUMBSCREWS IN PLACE. NOTE: SUPPLIED WITH OPTIONAL USE HARDWARE AND INSTRUCTIONS. CABLE INTERCONNECTION HARDWARE: (4) SCREWLOCKS, H= .191" PANEL MOUNT HARDWARE: (4) SCREWLOCKS, H= .160" J1 WIRE COLOR P1 1 BLACK 1 PART NUMBER 2 GRAY 2 3 RED 3 4 GREEN 4 5 BROWN 5 6 BLUE 6 CRMN9MF-1 CRMN9MF-2.5 CRMN9MF-5 CRMN9MF-10 CRMN9MF-15 CRMN9MF-25 7 ORANGE 7 8 YELLOW 8 9 PURPLE 9 SHELL DRAIN WIRE SHELL UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] NOTES: A OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% 1. CABLE ASSEMBLY SHALL BE TESTED FOR CONTINUITY. 2. CABLE ASSEMBLY SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM SPECIFICATION PS-0031. F ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 [5.08] .XX = ± .02 [.51] .XXX = ±.005 [.13] REGULATORY COMPLIANCE: CE2011/65/EU(RoHS DIRECTIVE) PROJECTION APPROVALS T CLARK 3/10/2004 D PARHAM 7 6 5 COLOR VARIATIONS MAY OCCUR 4 D-SUBMINIATURE 3/31/2004 CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY 3 A CATEGORY APPROVED BY C McCORMICK B 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE 3/10/2004 CHECKED BY F F DRAWN BY CRMN-FS01 8 LENGTH FEET METERS 1.0 0.31 2.5 0.76 5.0 1.52 10.0 3.05 15.0 4.57 25.0 7.62 PRODUCT DESCRIPTION CA, DB9M / DB9F REVERSIBLE HDWR SIZE A FSCM NO. 43321 SCALE: NONE DWG. NO. CAD FILE: 2 CRMN9MF CRMN9MF.SLDDRW REV. F SHEET 1 OF 1 1
CRMN9MF-5 价格&库存
很抱歉,暂时无法提供与“CRMN9MF-5”相匹配的价格&库存,您可以联系我们找货
