BAC06A
BAC06A
    L-COM(诺通)
    SMA(DO-214AC)
    压接式连接器,SMA母头穿壁式,镀金,用于RG174、RG188、RG316线缆 - BAC06A 此款具有单个D型安装孔的母头穿壁式SMA连接器专门用于使用标准压接尺寸的易用压接工具压接RG174、...
BAC06A 数据手册
8 6 7 4 5 3 D DESCRIPTION BODY CENTER PIN DIELECTRIC LOCK WASHER FERRULE NUT MATERIAL BRASS BRASS TEFLON BRASS BRASS BRASS 2 1 REVISIONS THE INFORMATION CONTAINED IN THIS DRAWING IS THE SOLE PROPERTY OF L-COM, INC. ANY REPRODUCTION IN PART OR WHOLE WITHOUT THE WRITTEN PERMISSION OF L-COM, INC. IS PROHIBITED. FINISH GOLD GOLD --GOLD GOLD GOLD DATE DESCRIPTION REV APPROVED E ECN 3150: UPDATE DWG FORMAT 1/10/08 D.GRIFFIN F ECN 5679: UPDATED TO MATCH NEW SUPPLIER SPECS. 8/23/11 D. CASTRO D .83 21 .43 11 C C .236 6 .128 3.25 B .256 6.50 .06 1.6 RECOMMENDED MOUNTING HOLE RECOMMENDED CABLE STRIPPING DIMENSIONS RoHS Compliant  ELECTRICAL: IMPEDANCE: 50 OHMS FREQUENCY RANGE: 0~6 GHz VSWR: 1.3 MAX. UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES [mm] OVERALL CABLE LENGTH TOLERANCE: ≤12 [305] = +1 [25] / -0 >12 [305] ≤60 [1524] = +2 [51] / -0 >60 [1524] ≤120 [3048] = +4 [102] / -0 >120 [3048] ≤300 [7620] = +6 [152] / -0 >300 [7620] = +5% / -0% MISCELLANEOUS: COMPONENT SHALL BE INDIVIDUALLY PACKAGED IN ACCORDANCE WITH L-COM SPEC. PS-0031. ALL OTHER DIMENSIONAL TOLERANCES: .X = ± .2 .XX = ± .02 .XXX = ±.005 ALL DIMENSIONS ARE FOR REFERENCE ONLY. PROJECTION APPROVALS 45 BEECHWOOD DRIVE NORTH ANDOVER, MA 01845 DATE DRAWN BY 05/17/2002 T.CLARK CHECKED BY 05/17/2002 D.PARHAM COAXIAL 05/17/2002 C.MCCORMICK CONFIGURATION DETAILS OF UNDIMENSIONED FEATURES MAY VARY COLOR VARIATIONS MAY OCCUR 7 6 5 4 3 A CATEGORY APPROVED BY PRODUCT DESCRIPTION CONN SMA F BHD RG174 CRIMP NK SIZE A FSCM NO. 43321 SCALE: NONE 8 B .10 2.5 RECOMMENDED FERRULE CRIMP SIZE. CENTER PIN TO BE SOLDERED NOTES: A .22 5.7 DWG. NO. CAD FILE: 2 REV. F BAC06A BAC06A.SLDDRW SHEET 1 OF 1 1
BAC06A 价格&库存
很抱歉,暂时无法提供与“BAC06A”相匹配的价格&库存,您可以联系我们找货
