SGM72112AYURE20G/TR
SGM72112AYURE20G/TR
    WEEDSPREAD(萍生微)
    QFN20_2.5X2.5MM_EP
    支持MIPIRFFE接口的SP12T射频开关
SGM72112AYURE20G/TR 数据手册
FINAL DATASHEET RVE.A SGM72112A SP12T Switch with MIPI RFFE Interface GENERAL DESCRIPTION FEATURES The SGM72112A is a single-pole/twelve-throw (SP12T) ● Supply Voltage Range: 2.4V to 4.8V antenna switch, which supports from 0.1GHz to 3GHz. ● Advanced Silicon-On-Insulator (SOI) Process The device features low insertion loss and high ● Frequency Range: 0.1GHz to 3GHz isolation, which make it suitable for high linearity ● Low Insertion Loss: 0.7dB (TYP) at 2.7GHz receiving applications. It also has the advantage of high linearity performance. The SGM72112A is not subject ● MIPI RFFE Interface Compatible ● No External DC Blocking Capacitors Required to cellular interference and is applied to multi-mode and ● Available in a Green UTQFN-2.5×2.5-20L Package multi-band LTE mobile phones. BLICK DIAGRAM SCL process, Internal driver and decoder for switch control signals, which makes it flexible in RF path band and VDD silicon-on-insulator (SOI) VIO and MIPI controller on SDA The SGM72112A has the ability to SP12T RF switch routing selection. No external DC blocking capacitors required on the RF Supply and Logic paths as long as no external DC voltage is applied, which can save PCB area and cost. The SGM72112A is available in a Green UTQFN-2.5× 2.5-20L package, APPLICATIONS 3G/4G Applications RF1 RF7 RF2 RF8 RF3 RF9 RF4 RF10 RF5 RF11 RF6 RF12 RFCOM Figure 1 SGM72112A Block Diagram FEBRUARY 15, 2022 1 SGM72112A SP12T Switch with MIPI RFFE Interface PACKAGE/ORDERING INFORMATION MODEL PACKAGE DESCRIPTION SPECIFIED TEMPERATURE RANGE ORDERING NUMBER PACKAGE MARKING PACKING OPTION SGM72112A UTQFN-2.5×2.5-20L -40℃ to +85℃ SGM72112AYURE20G/TR RD8 XXXX Tape and Reel, 2000 MARKING INFORMATION NOTE: XXXX = Date Code, Trace Code. YYY X XXX Serial Number Trace Code Date Code - Year Green (RoHS & HSF): PS Micro Corp defines "Green" to mean Pb-Free (RoHS compatible) and free of halogen substances. If you have additional comments or questions, please contact your PSMICRO representative directly. ABSOLUTE MAXIMUM RATINGS OVERSTRESS CAUTION Supply Voltage, VDD ............................................................5V Supply Voltage (MIPI), V IO .................................................2V SDA, SCL Control Voltage ..................................................2V RF Input Power, PIN .....................................................26dBm Junction Temperature ................................................. +150℃ Storage Temperature Range ....................... -55℃ to +150℃ Lead Temperature (Soldering, 10s) ............................ +260℃ ESD Susceptibility HBM ................................................1000V Stresses beyond those listed in Absolute Maximum Ratings may cause permanent damage to the device. Exposure to absolute maximum rating conditions for extended periods may affect reliability. Functional operation of the device at any conditions beyond those indicated in the Recommended Operating Conditions section is not implied. RECOMMENDED OPERATING CONDITIONS Operating Temperature Range ...................... -40℃ to +85℃ Operating Frequency Range ........................ 0.1GHz to 3GHz Supply Voltage, VDD ............................................ 2.4V to 4.8V Supply Voltage (MIPI), V IO .............................. 1.65V to 1.95V ESD SENSITIVITY CAUTION This integrated circuit can be damaged if ESD protections are not considered carefully. PSMICRO recommends that all integrated circuits be handled with appropriate precautions. Failure to observe proper handling and installation procedures can cause damage. ESD damage can range from subtle performance degradation to complete device failure. Precision integrated circuits may be more susceptible to damage because even small parametric changes could cause the device not to meet the published specifications. DISCLAIMER PS Micro Corp reserves the right to make any change in circuit design, or specifications without prior notice. FEBRUARY 2022 2 SGM72112A SP12T Switch with MIPI RFFE Interface 2 RF3 3 RF2 GND RF4 RF10 1 RF9 RFCOM GND PIN CONFIGURATION 20 19 18 17 16 RF5 15 RF6 14 RF7 4 13 RF8 RF12 5 12 RF1 GND 6 11 RF11 VIO 9 10 SCL 8 SDA 7 VDD Exposed Pad Figure 2. SGM72112A-20L PIN DESCRIPTION PIN NAME 1 RFCOM PIN NAME RF Common Port. 2 3 FUNCTION 10 SCL RFFE Clock Signal. FUNCTION RF4 RF Port 4. 11 RF11 RF Port 11. RF3 RF Port 3. 12 RF1 RF Port 1. 4 RF2 RF Port 2 13 RF8 RF Port 8. 5 RF12 RF Port 12. 14 RF7 RF Port 7. 6, 17, 20 GND Ground. 15 RF6 RF Port 6. 7 VDD DC Power Supply. 16 RF5 RF Port 5. 8 VIO Supply voltage for MIPI. 18 RF10 RF Port 10. 9 Exposed Pad SDA RFFE Data Signal. 19 RF9 RF Port 9. GND Ground. Register_0 TRUTH TABLE Table 1 Register_0 Truth Table State Mode 1 Register_0 Bits D7 D6 D5 D4 D3 D2 D1 D0 Isolation 0 0 0 0 0 0 0 0 2 RF1 0 0 0 0 0 1 0 0 3 RF2 0 0 0 0 0 1 1 1 4 RF3 0 0 0 0 1 0 0 1 5 RF4 0 0 0 0 1 0 1 1 6 RF5 0 0 0 0 1 1 0 0 7 RF6 0 0 0 0 0 0 0 1 8 RF7 0 0 0 0 0 0 1 0 9 RF8 0 0 0 0 0 0 1 1 10 RF9 0 0 0 0 1 0 1 0 11 RF10 0 0 0 0 1 0 0 0 12 RF11 0 0 0 0 0 1 0 1 13 RF12 0 0 0 0 0 1 1 0 FEBRUARY 2022 3 SGM72112A SP12T Switch with MIPI RFFE Interface ELECTRICAL CHARACTERISTICS (Typical values, V DD = 2.8V, TA = +25℃, PIN = 0dBm, 50Ω, unless otherwise noted.) PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS 2.4 2.8 4.8 V 32 60 μA 1.65 1.8 1.95 V 4.8 10 μA VIO 1.95 DC Specifications Supply Voltage VDD Supply Current IDD VIO Supply Voltage VIO VIO Supply Current IIO Control Voltage VCTL_H High 0.8 × VIO VCTL_L Low 0 0.45 V Switching Time tSW 50% of control voltage to 90% of RF power 1 2 μs Turn-On Time tON Time from VDD = 0V to part ON and RF at 90% 5 10 μs f0 = 0.1GHz to 1.0GHz 0.5 0.65 f0 = 1.0GHz to 2.0GHz 0.6 0.75 f0 = 2.0GHz to 2.7GHz 0.7 0.85 RF Specifications Insertion Loss (RFCOM to All RF Ports) Isolation (RFCOM to All RF Ports) Input Return Loss (RFCOM to All RF Ports) 0.1dB Compression Point (RFCOM to All RF Ports) IL ISO RL P0.1dB f0 = 0.1GHz to 1.0GHz 21 26 f0 = 1.0GHz to 2.0GHz 15 20 f0 = 2.0GHz to 2.7GHz 12 17 f0 = 0.1GHz to 1.0GHz 19 22 f0 = 1.0GHz to 2.0GHz 18 21 f0 = 2.0GHz to 2.7GHz 10 13 f0 = 0.1GHz to 3GHz 26 dB dB dB dBm FEBRUARY 2022 4 SGM72112A SP12T Switch with MIPI RFFE Interface MIPI READ AND WRITE TIMING SCL SDA SA3 SA2 SA1 SSC SA0 0 1 0 A4 A3 A2 A1 A0 P Example Register Write Command Frame SCL Signal Driven by Master Signal Not Driven; Pull-Down Only For Reference Only SDA P D7 D6 D5 D4 D3 D2 D1 D0 P 0 Example Data Frame Bus Park Figure 3. Register Write Command Timing Diagram SCL SDA SA3 SA2 SA1 SSC SA0 0 1 1 A4 A3 A2 A1 A0 P Example Register Read Command Frame SCL Signal Driven by Master Signal Not Driven; Pull-Down Only Signal Driven by Slave SDA For Reference Only P 0 D7 D6 D5 D4 D3 D2 D1 D0 P 0 Example Data Frame Bus Park Bus Park Figure 4. Register Read Command Timing Diagram COMMAND SEQUENCE BIT DEFINITIONS Type Reg0 Write Reg Write Reg Read SSC C11-C8 C7 C6-C5 C4 C3-C0 Extended Operation Parity Bits BPC DA7(1)DA0(1) Parity Bits BPC DA7(n)DA0(n) Parity Bits BPC Y SA[3:0] 1 Data[6:5] Data[4] Data[3:0] Y Y - - - - - - Y SA[3:0] 0 10 Addr[4] Addr[3:0] Y - Data[7:0] Y Y - - - Y SA[3:0] 0 11 Addr[4] Addr[3:0] Y Y Data[7:0] Y Y - - - Legends: SSC = Sequence start command SA = Slave address D = Register Address A = Data bits C = Command frame bits BPC = Bus park cycle FEBRUARY 2022 5 SGM72112A SP12T Switch with MIPI RFFE Interface REGISTER MAPS Register_0 Register Address: 0x0000; R/W Table 2. Register_0 Register Details Bit(s) D[7:0] Bit Name Description See Table 1 section. MODE_CTRL Default R/W 0000 0000 R/W PM_TRIG Register Address: 0x001C; R/W and W Table 3. PM_TRIG Register Details Bit(s) Bit Name D[7] PWR_MODE_1 D[6] PWR_MODE_0 D[5] TRIGGER_MASK_2 D[4] TRIGGER_MASK_1 D[3] TRIGGER_MASK_0 D[2] TRIGGER_2 D[1] TRIGGER_1 D[0] TRIGGER_0 Description 0: Normal 1: Low power 0: Active - Normal 1: Startup - All registers are reset to the default 0: TRIGGER_2 enabled If any one of the three TRIGGER_MASK_x is set to logic 1: TRIGGER_2 disabled '1', the corresponding trigger is disabled, in that case data written to a register associated with the trigger goes 0: TRIGGER_1 enabled directly to the destination register. 1: TRIGGER_1 disabled Otherwise, if the TRIGGER_MASK_x is set to logic '0', incoming data is written to the shadow register, and the 0: TRIGGER_0 enabled destination register is unchanged until its corresponding 1: TRIGGER_0 disabled trigger is asserted. 0: Keep its associated destination registers unchanged. 1: Load its associated destination registers with the data in the parallel shadow register, provided TRIGGER_MASK_2 is set to logic '0'. 0: Keep its associated destination registers unchanged. 1: Load its associated destination registers with the data in the parallel shadow register, provided TRIGGER_MASK_1 is set to logic '0'. 0: Keep its associated destination registers unchanged. 1: Load its associated destination registers with the data in the parallel shadow register, provided TRIGGER_MASK_0 is set to logic '0'. Default Type 0 R/W 0 R/W 0 R/W 0 R/W 0 R/W 0 W 0 W 0 W Default 0000 0011 Type PRODUCT_ID Register Address: 0x001D; R Table 4. PRODUCT_ID Register Details Bit(s) D[7:0] Bit Name PRODUCT_ID Description Product ID. R FEBRUARY 2022 6 SGM72112A SP12T Switch with MIPI RFFE Interface REGISTER MAPS (continued) MANUFACTURER_ID Register Address: 0x001E; R Table 5. MANUFCTURER_ID Register Details Bit(s) D[7:0] Bit Name MANUFACTURER_ID [7:0] Description Lower eight bits of MIPI registered Manufacturer ID. Read-only. Note that during USID programming, the write command sequence is executed on the register, but the value does not change. Default Type 0100 1010 R MAN_USID Register Address: 0x001F; R and R/W Table 6. MAN_USID Register Details Default Type D[7:6] Bit(s) Reserved Bit Name Reserved Description 00 R D[5:4] MANUFACTURER_ID [9:8] Upper two bits of Manufacturer ID. Read-only. Note that during USID programming, the write command sequence is executed on the register, but the value does not change. 00 R D[3:0] USID USID of the device 1011 R/W FEBRUARY 2022 7 SGM72112A SP12T Switch with MIPI RFFE Interface TYPICAL APPLICATION CIRCUIT RFFE Data Signal SDA DNI Supply Voltage RFFR Clock Signal SCL DNI VDD VIO 100nF DC Power Supply. 100nF RF Port 1 RF1 RF Port 2 RF2 RF Port 3 RF3 RF Port 4 RF4 RF Port 5 RF5 RF Port 6 RF6 SGM72112A GND RF7 RF Port 7 RF8 RF Port 8 RF9 RF Port 9 RF10 RF Port 10 RF11 RF Port 11 RF12 RF Port 12 RFCOM RF Common Port Figure 5. SGM72112A Typical Application Circuit EVALUATION BOARD LAYOUT Figure 6. SGM72112A Evaluation Board Layout FEBRUARY 2022 8 SGM72112A SP12T Switch with MIPI RFFE Interface PACKAGE OUTLINE DIMENSIONS UTQFN-2.5×2.5-20L D PIN 1# k e D1 E e1 E1 L1 L L1 TOP VIEW L BOTTOM VIEW 1.34 1.34 1.90 2.30 A A2 0.20 A1 0.45 RECOMMENDED LAND PATTERN (Unit: mm) SIDE VIEW Symbol 0.20 0.40 Dimensions In Millimeters MIN MOD MAX A 0.500 0.550 0.600 A1 0.000 0.020 0.050 A2 0.152 REF D 2.400 2.500 2.600 E 2.400 2.500 2.600 D1 1.240 1.340 1.440 E1 1.240 1.340 1.440 e 0.450 BSC e1 0.400 BSC k L L1 0.280 REF 0.150 0.200 0.250 0.100 REF NOTE: This drawing is subject to change without notice. FEBRUARY 2022 9 SGM72112A SP12T Switch with MIPI RFFE Interface TAPE AND REEL INFORMATION REEL DIMENSIONS TAPE DIMENSIONS P2 W P0 Q1 Q2 Q1 Q2 Q1 Q2 Q3 Q4 Q3 Q4 Q3 Q4 B0 Reel Diameter A0 P1 Reel Width (W1) K0 DIRECTION OF FEED NOTE: The picture is only for reference. Please make the object as the standard. KEY PARAMETER LIST OF TAPE AND REEL Reel Diameter Reel Width W1 (mm) A0 (mm) B0 (mm) K0 (mm) P0 (mm) P1 (mm) P2 (mm) W (mm) Pin1 Quadrant UTQFN-2.5×2.5-20L 7″ 12.4 2.66 2.69 0.77 4.0 8.0 2.0 12.0 Q2 DD0001 Package Type FEBRUARY 2022 10 SGM72112A SP12T Switch with MIPI RFFE Interface CARTON BOX DIMENSIONS NOTE: The picture is only for reference. Please make the object as the standard. KEY PARAMETER LIST OF CARTON BOX Length (mm) Width (mm) Height (mm) Pizza/Carton 7″ (Option) 368 227 224 8 7″ 442 410 224 18 DD0002 Reel Type FEBRUARY 2022 11 SGM72112A SP12T Switch with MIPI RFFE Interface For the latest specifications or product information: Website: www.ps-micro.com.cn Phone: 86-21-50772230 Email: info@ps-micro.com.cn THE INFORMATION CONTAINED HEREIN IS BELIEVED TO BE RELIABLE. PSMICRO MAKES NO WARRANTIES REGARDING INFORMATION CONTAINED HEREIN. PSMICRO ASSUMES NO RESPONSIBILITIES OR LIABILITIES FOR THE USE OF THE INFORMATION CONTAINED HEREIN. THE INFORMATION CONTAINED HEREIN IS PROVIDED "AS IS, WHERE IS", AND THE ENTIRE RISK ASSOCIATED WITH SUCH INFORMATION IS ENTIRELY WITH THE USER. ALL INFORMATION CONTAINED HEREIN IS SUBJECT TO CHANGE WITHOUT NOTICE. THE INFORMATION CONTAINED HEREIN OR ANY USE OF SUCH INFORMATION DOES NOT GRANT, EXPLICITLY OR IMPLICITLY TO ANY PARTY ANY PATENT RIGHTS, LICENSES, OR ANY OTHER INTELLECTUAL PROPERTY RIGHTS, WHETHER WITH REGARD TO SUCH INFORMATION ITSELF OR ANYTHING DESCRIBED BY SUCH INFORMATION. PSMICRO products are not warranted or authorized for use as critical components in medical, life-saving, or life-sustaining applications, or other applications where a failure would reasonably be expected to cause severe personal injury or death. Copyright 2020, 2021 © PS Micro Corp | All rights reserved | Weedspread is a registered trademark of PS Micro Corp FEBRUARY 2022 12
SGM72112AYURE20G/TR 价格&库存
很抱歉,暂时无法提供与“SGM72112AYURE20G/TR”相匹配的价格&库存,您可以联系我们找货
