TSP18N20M
TSP18N20M
200V N-Channel MOSFET
General Description
Features
This Power MOSFET is produced using Truesemi‘s
advanced planar stripe DMOS technology.
This advanced technology has been especially tailored to
minimize on-state resistance, provide superior switching
performance, and withstand high energy pulse in the
avalanche and commutation mode. These devices are well
suited for high efficiency switched mode power supplies,
active power factor correction based on half bridge
topology.
Absolute Maximum Ratings
Symbol
• 18A,200V,Max.RDS(on)=0.17 Ω @ VGS =10V
• Low gate charge(typical 22nC)
• High ruggedness
• Fast switching
• 100% avalanche tested
• Improved dv/dt capability
TC=25℃ unless otherwise specified
Value
Units
VDSS
Drain-Source Voltage
Parameter
200
V
VGS
Gate-Source Voltage
± 30
V
TC = 25℃
18*
A
TC = 100℃
9.1*
A
ID
Drain Current
IDM
Pulsed Drain Current
72*
A
EAS
Single Pulsed Avalanche Energy
(Note 2)
453
mJ
EAR
Repetitive Avalanche Energy
(Note 1)
13.9
mJ
IAR
Repetitive avalanche current
18
A
PD
Power Dissipation (TC = 25℃)
TJ, TSTG
(Note 1)
Operating and Storage Temperature Range
35
W
-55 to +150
* Drain current limited by maximum junction temperature.
Thermal Resistance Characteristics
Symbol
Parameter
Value
Units
RθJC
Thermal Resistance,Junction-to-Case
3.57
℃/W
RθJA
Thermal Resistance,Junction-to-Ambient
62.5
℃/W
© 2018 Truesemi Semiconductor Corporation
Ver.B1
www.truesemi.com
Symbol
Parameter
Test Conditions
Min
Typ
Max
Units
Gate Threshold Voltage
VDS = VGS, ID = 250 uA㎂
2.0
4.0
V
Static Drain-Source
On-Resistance
VGS = 10 V, ID = 9A
0.14
0.17
Ω
Forward transfer conductance(note 3)
VDS = 10 V, ID = 10A
35
S
200
V
uA
On Characteristics
VGS(th)
RDS(ON)
gfs
Off Characteristics
BVDSS
Drain-Source Breakdown Voltage
VGS = 0 V, ID = 250 uA㎂
IDSS
Zero Gate Voltage Drain Current
VDS = 200 V, VGS = 0 V
1
IGSSF
Gate-Body Leakage Current,Forward
VGS = 30 V, VDS = 0 V
100
nA㎁
IGSSR
Gate-Body Leakage Current,Reverse
VGS =- 30 V, VDS = 0 V
-100
nA㎁
965
pF㎊
227
310
pF㎊
55
71
pF
15
ns
130
ns㎱
135
ns㎱
105
ns㎱
22
28
nC
6.6
nC
7.2
nC
18
72
Dynamic Characteristics
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
VDS = 25 V, VGS = 0 V,
f = 1.0 MHz
Switching Characteristics
td(on)
Turn-On Time
tr
Turn-On Rise Time
td(off)
Turn-Off Delay Time
tf
Turn-Off Fall Time
Qg
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
VDS = 125 V, ID = 18A,
RG = 25 Ω
(Note 3,4)
VDS = 160 V, ID = 18A,
VGS = 10 V
(Note 3,4)
Gate-Drain Charge
Source-Drain Diode Maximum Ratings and Characteristics
IS
Continuous Source-Drain Diode Forward Current
ISM
Pulsed Source-Drain Diode Forward Current
VSD
Source-Drain Diode Forward Voltage
IS = 18A, VGS = 0 V
1.4
trr
Reverse Recovery Time
IS =18A, VGS = 0 V
208
ns㎱
Qrr
Reverse Recovery Charge
diF/dt = 100 A/μs
1.63
uC
A
(Note 1)
(Note 4)
V
Note:
1. Repeated rating: Pulse width limited by maximum junction temperature
2. L=2.1mH, IAS=18A, VDD=50V, RG=25Ω, Starting TJ=25℃
3. Pulse test: Pulse width≤300us, Duty cycle≤2%
4. Essentially independent of operating temperature
Ver.B1
www.truesemi.com
TSP18N20M
Electrical Characteristics TC=25 ℃
TSP18N20M
Typical Characteristics
Ver.B1
www.truesemi.com
TSP18N20M
Ver.B1
www.truesemi.com
TSP18N20M
Fig 11. Gate Charge Test Circuit & Waveform
50KΩ
12V
VGS
Same Type
as DUT
Qg
200nF
10V
300nF
VDS
VGS
Qgs
Qgd
DUT
3mA
Charge
Fig 12. Resistive Switching Test Circuit & Waveforms
RL
VDS
VDS
90%
VDD
RG
( 0.5 rated VDS )
Vin
DUT
10V
10%
td(on)
tr
td(off)
t on
tf
t off
Fig 13. Unclamped Inductive Switching Test Circuit & Waveforms
L
1
EAS = ---- LL IAS2
2
VDS
VDD
ID
BVDSS
IAS
RG
ID (t)
10V
DUT
VDS (t)
VDD
tp
Ver.B1
Time
www.truesemi.com
TSP18N20M
Fig 14. Peak Diode Recovery dv/dt Test Circuit & Waveforms
DUT
VDS
_
IS
L
Driver
RG
VGS
VGS
( Driver )
Same Type
as DUT
VDD
• dv/dt controlled by RG
• IS controlled by pulse period
Gate Pulse Width
D = -------------------------Gate Pulse Period
10V
IFM , Body Diode Forward Current
IS
( DUT )
di/dt
IRM
Body Diode Reverse Current
VDS
( DUT )
Body Diode Recovery dv/dt
VDD
Vf
Body Diode
Forward Voltage Drop
Ver.B1
www.truesemi.com
TSP18N20M
Package Dimension
TO-220
Ver.B1
www.truesemi.com
很抱歉,暂时无法提供与“TSP18N20M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+1.27600
- 100+1.21000
- 500+1.15500
- 国内价格
- 1+3.51000
- 10+2.94840
- 50+2.67840
- 100+2.37600
- 500+2.23560
- 1000+2.16000
