SESUC5VD2510-10U
SESUC5VD2510-10U
    SEMITEL(晶讯)
    DFN2510-10
    SESUC5VD2510-10U
SESUC5VD2510-10U 数据手册
Semitel Ultra Low Capacitance ESD TVS Array Enabling your idea Features SESUC5VD2510-10U ■ DFN2510 package ■ Protects up to 4-Lines operating at 5V ■ R2R + Zener technology ■ Low clamping voltage ■ Low leakage current ■ Ultra low capacitance (0.15pF typical I/O to I/O) 1 ■ ESD Protection for high-speed data lines to: 2 IEC 61000-4-2 ±8KV contact ±15KV air DFN2510 ■ RoHS compliant Ultra Low Capacitance ESD TVS Array Applications ■ USB 3.0/3.1 ■ HDMI 1.4/2.0, Display Port 1.3, eSATA ■ Unified Display Interface (UDI) ■ Digital Visual Interface (DVI) Schematic Diagram ■ High speed serial interfaces Absolute Maximum Ratings (TA=25℃, Unless otherwise specified.) Parameter Symbol Value Unit TJ TSTG -55 to +125 -55 to +150 ℃ ℃ Lead Soldering Temperature TL 260 (10sec.) ℃ Peak Pulse Current ( tP = 8/20μS ) IPP 3 A IEC 61000-4-2 Contact (ESD) VESD ±8 kV IEC 61000-4-2 Air (ESD) VESD ±15 kV Junction Temperature Storage Temperature Electrical Characteristics (TA=25℃, Unless otherwise specified.) Parameter Reverse stand-off Voltage Reverse Breakdown Voltage Symbol Condition Min Typ Max Unit 5 V 7.2 9.5 V 1 μA VRWM VBR IT=1mA 6 Reverse Leakage Current IR VR=5V 0.01 Clamping Voltage (IEC 61000-4-5) VC IPP=3A,TP=8/20μS 10 Trigger Voltage (IEC 61000-4-2) VT V ESD =8kV 135 V Clamping Voltage (IEC 61000-4-2) VC CJ VESD =8kV 20 V VR=0V,f=1MHz, I/O to I/O 0.15 pF CJ VR=0V,f=1MHz, I/O to GND 0.35 pF Junction Capacitance V 1 Doc.No.SSME/JS-100-0461 @copyright Semitel 2016 www.semiteltech.com Semitel Ultra Low Capacitance ESD TVS Array Enabling your idea Typical Characteristic Curves Fig.1 Pulse Waveform-ESD(IEC61000-4-2) Fig.3 IEC61000-4-2 +8kV Contact ESD Clamping Waveform 100% 90% Percent of IPP 30ns 60ns 10% 30 60 Time (ns) Time (ns) Fig.6 Insertion Loss S21 - I/O to I/O Insertion Loss (dB) Fig.5 Eye Diagram - USB3.1 at 10Gbps per channel (with SESUC5VD2510-10U) m1 = 0.123dB @2.5GHz m2 = 0.245dB @5.0GHz m3 = 0.489dB @7.5GHz m4 = 3.751dB @15GHz Ultra Low Capacitance ESD TVS Array 0 tr 0.7 to 1ns Frequency (Hz) 2 Doc.No.SSME/JS-100-0461 @copyright Semitel 2016 www.semiteltech.com Semitel Ultra Low Capacitance ESD TVS Array Enabling your idea Product Dimensions Symbol Dimensions in millimeters Min Nom Max A 0.45 0.50 0.55 A1 - 0.02 0.05 A3 0.10 0.15 0.20 D 2.45 2.50 2.55 E 0.95 1.00 1.05 D1 0.35 0.40 0.45 b 0.15 0.20 0.25 e L 0.50BSC 0.35 0.40 0.45 Part Number System SES UC 5V D2510 - 10 U Unidirectional Pin Numbers Package Voltage Rating Ultra Low Capacitance Product Series Marking 5R2P 3 Doc.No.SSME/JS-100-0461 @copyright Semitel 2016 www.semiteltech.com Semitel Ultra Low Capacitance ESD TVS Array Enabling your idea Order Information Device Package Carrier Quantity HSF Status SESUC5VD2510-10U DFN2510 Tape & Reel (7") 3000pcs / Reel RoHS Compliant Revision history Date 26-January-2016 Revision Description of changes A0 First issue 4 Doc.No.SSME/JS-100-0461 @copyright Semitel 2016 www.semiteltech.com Semitel Ultra Low Capacitance ESD TVS Array Enabling your idea or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. · Users should independently evaluate the suitability of and test each product selected for their own applications, and SEMITEL assumes no liability whatsoever relating to the choice, selection or use of the SEMITEL products and services described herein. · SEMITEL reserves the right to change or update, without notice, any information contained in this publication; to change, without notice, the design, construction, processing, or specification of any product; and to discontinue or limit production or distribution of any product. · Information in this document supersedes and replaces all information previously supplied. · Products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in Ultra Low Capacitance ESD TVS Array CAUTION / WARNING · Information in this document is believed to be accurate and reliable. However, SEMITEL does not give any representations or warranties, expressed applications where failure or malfunction of an SEMITEL product can reasonably be expected to result in personal injury, death or severe property or environmental damage. SEMITEL accepts no liability for inclusion and/or use of SEMITEL products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. · This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. · Resale of SEMITEL products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by SEMITEL for the SEMITEL product or service described herein and shall not create or extend in any manner whatsoever, any liability of SEMITEL. · SEMITEL expressly disclaims all implied warranties regarding the information contained herein, including, but not limited to, any implied warranties of merchantability or fitness for a particular purpose. SEMITEL only obligations are those in the SEMITEL Standard Terms and Conditions of Sale and in no case will SEMITEL be liable for any incidental, indirect, or consequential damages arising from the sale, resale, use, or misuse of its products. Specifications are subject to change without notice © Copyright 2005, Semitel Electronics . ® is a registered trademark of Semitel Electronics All rights reserved 5 Doc.No.SSME/JS-100-0461 @copyright Semitel 2016 www.semiteltech.com
SESUC5VD2510-10U 价格&库存
很抱歉,暂时无法提供与“SESUC5VD2510-10U”相匹配的价格&库存,您可以联系我们找货
