KCT8536C
KCT8536C
    KCT(康希通信)
    QFN12_2X2MM_EP
    带有 PA、LNA 和 SPDT 的 5GHZ WLAN 802.11AC RFIC
KCT8536C 数据手册
KCT8536C PRELIMINARY DATASHEET 5GHz WLAN 802.11ac RFIC WITH PA, LNA AND SPDT TX PA_EN Description PA KCT8536C is a highly integrated RF front-end integrated circuit incorporates key RF functionality needed for IEEE 802.11a/n/ac WLAN systems operating in the 5.15-5.85GHz range. KCT8536C integrates a high-efficiency, high-linearity power amplifier (PA), a low noise amplifier (LNA) with bypass, the associated matching network, LO rejection, and harmonic filters all in one device. ANT VDET LNA RX KCT8536C has simple and low-voltage control logic, and requires minimal external components. A power detector is also integrated for accurate monitoring of output power from the PA. KCT8536C is assembled in a compact, low-profile 2.0x2.0x0.75mm 12-lead LGA package. KCT8536C is the ideal RF front-end solution for implementing 5GHz high-power WLAN systems supporting multiple standards including 802.11a/n/ac. Applications LNA_EN     802.11ac Wi-Fi Devices Tablets / MIDs Wi-Fi Media Gateways Consumer Electronics     Notebook / Netbook / Ultrabook Access Points / Routers Set Top Boxes / Wireless IPTVs Other 5GHz ISM Platforms FEATURES  Integrated high performance 5GHz PA, LNA with bypass and T/R switch  Fully-matched input and output  Integrated power detector  Transmit gain: 27.5dB at 5V and 26 dB at 3.3V  Receive gain: 12dB at 5V&3.3V  Output power: +20.5dBm @ -35dB DEVM, VHT80/MCS9, 5V +17dBm @ -35dB DEVM, VHT80/MCS9, 3.3V +21.5dBm @ -30dB DEVM, HT20/MCS7, 5V +18dBm @ -30dB DEVM, HT20/MCS7, 3.3V  ESD protection circuitry on all PINs  DC decoupled RF ports  Minimal external components required  Small package: LGA12, 2.0mm x 2.0mm x0.75mm (MSL3, 260 oC per JEDEC J-STD-020)  ROHS and REACH Compliant KANGXI Communication Technologies  www.kxcomtech.com  TEL (+86) 021 6168 1915 This product datasheet is subject to change without notice. Rev 02 Feb.18, 2020 KCT8536C PRELIMINARY DATASHEET PIN ASSIGNMENTS Pin Number Pin Name Description 1 RX RF Output Port from LNA or Bypass – DC Shorted to GND 2,7,9 GND Ground – Must Be Connected to GND in the Application Circuit 3 TX RF Input Port from the Transceiver – DC Shorted to GND 4,5 VCC Supply Voltage 6 VDET Detector Output Voltage 8 ANT Antenna Port – RF Signal from the PA or RF Signal Applied to the LNA – DC Shorted to GND 10 PA_EN PA Enable 11 LNA_EN LNA Enable 12 VDD LNA Power Supply PIN-OUT DIAGRAM VDD LNA_EN PA_EN 12 11 10 RX 1 9 GND GND 2 8 ANT TX 3 7 GND 4 5 6 VCC VCC VDET KANGXI Communication Technologies  www.kxcomtech.com  TEL (+86) 021 6168 1915 This product datasheet is subject to change without notice. Rev 02 Feb.18, 2020 KCT8536C PRELIMINARY DATASHEET ABSOLUTE MAXIMUM RATINGS Parameters Units Min Max DC Supply Voltage V 0 +6.0 VDD and VCC Control Pin Voltage V 0 +3.6 All Control Pins DC Current Consumption mA 600 Maximum TX Input Power (50 ohm load, No Damage) dBm +12 LNA On Maximum RX Input Power (No Damage) dBm +12 Bypass Mode Maximum RX Input Power (No Damage) dBm +25 Storage Temperature oC Junction Temperature oC +200 C/W +35 VSWR 10:1 Thermal Resistance (θJC) Ruggedness ( Pin =10dBm, No Permanent Damage) -40 Conditions +150 NOTE: Sustained operation at or above the Absolute Maximum Ratings for any one or combinations of the above parameters may result in permanent damage to the device and is not recommended. All Maximum RF Input Power Ratings assume 50-ohm terminal impedance. NOMINAL OPERATING CONDITIONS Parameters Units Min Typ Max DC Supply Voltage V 3 3.3/5 5.5 Control Pin Voltage “High” V 1.8 3.6 Control Pin Voltage “Low” V 0 0.4 Control Pin DC Current uA Operating Temperature oC Conditions VDD and VCC 60 -40 +25 +85 KCT8536C ELECTRICAL SPECIFICATIONS (VDD = VCC = 5V, T = 25 oC, Unless Otherwise Noted) Parameters Frequency Range Units Min GHz 5.15 Typ Max Conditions 5.85 Transmit Mode KANGXI Communication Technologies  www.kxcomtech.com  TEL (+86) 021 6168 1915 This product datasheet is subject to change without notice. Rev 02 Feb.18, 2020 KCT8536C PRELIMINARY DATASHEET Parameters Gain Output Power Units Min Typ Max dB 26 27.5 30 dBm Conditions +20.5 VHT80/MCS9, -35dB DEVM, Preamble only +21.5 HT20/MCS7, -30dB DEVM, Preamble only +25 HT20/MCS0, Mask Compliance Modulated Signal, 100% duty cycle Current Consumption mA 135 140 @ No RF 195 205 @+18dBm 260 270 @+22dBm 350 370 @+25dBm Pout = +25dBm, HT20/MCS0 Harmonics dBm/MHz -32 2nd harmonics -44 3rd harmonics Input Return Loss dB 10 Output Return Loss dB 10 Power Detector Output Power Detector Output Impedance 0.25 @ No RF 0.6 @+18dBm 0.8 @+22dBm 0.92 @+25dBm V ohm 2K ANT-RX Isolation dB TBD PA Switching Time ns TBD PA Turn-On Time from TX_EN edge ns TBD PA Turn-Off Time from TX_EN edge ns TBD dB 12 dBm TBD Noise Figure dB 3.3 Input Return Loss dB 10 Output Return Loss dB 10 Switching Time ns 400 Transmit Mode; TX_EN=High; Maximum Power Receive Mode – LNA On Gain Input Power of P1dB 14 3.5 LNA  Bypass KANGXI Communication Technologies  www.kxcomtech.com  TEL (+86) 021 6168 1915 This product datasheet is subject to change without notice. Rev 02 Feb.18, 2020 KCT8536C PRELIMINARY DATASHEET Parameters Units Min Typ LNA _EN Control Current μA 35 LNA Turn On Time ns TBD Current Consumption mA 14 dB 5 dBm TBD Input Return Loss dB 12 Output Return Loss dB 8 ANT-RX Isolation dB TBD Bypass Current μA 20 Max Conditions Receive Bypass Mode Insertion Loss Input Power of P1dB Transmit Mode; TX_EN=High; Maximum Power (VDD = VCC = 3.3V, T = 25 oC, Unless Otherwise Noted) Parameters Frequency Range Units Min GHz 5.15 dB 25 Typ Max Conditions 5.85 Transmit Mode Gain Output Power dBm 26 30 +17 VHT80/MCS9, -35dB EVM, Preamble only +18 HT20/MCS7, -30dB EVM, Preamble Only +21 HT20/MCS0, Mask Compliance Modulated Signal, 100% duty cycle 105 Current Consumption mA @ No RF 165 170 @+17dBm 175 185 @+18dBm 225 235 @+21dBm Pout = +21dBm, HT20/MCS0 Harmonics dBm/MHz -35 2nd harmonics -50 3rd harmonics Input Return Loss dB 8 Output Return Loss dB 10 KANGXI Communication Technologies  www.kxcomtech.com  TEL (+86) 021 6168 1915 This product datasheet is subject to change without notice. Rev 02 Feb.18, 2020 KCT8536C PRELIMINARY DATASHEET Parameters Power Detector Output Power Detector Output Impedance Units Min Typ Max Conditions 0.25 @ No RF 0.55 @+17dBm 0.6 @+18dBm 0.75 @+21dBm V ohm 1K ANT-RX Isolation dB TBD PA Switching Time ns TBD PA Turn-On Time from TX_EN edge ns TBD PA Turn-Off Time from TX_EN edge ns TBD Transmit Mode; TX_EN=High; Maximum Power Receive Mode – LNA On Gain dB Input Power of P1dB 9 12 dBm TBD Noise Figure dB 3.5 Input Return Loss dB 10 Output Return Loss dB Switching Time ns 400 LNA _EN Control Current μA 35 LNA Turn On Time ns TBD Current Consumption mA 14 dB 4.5 dBm TBD Input Return Loss dB 10 Output Return Loss dB ANT-RX Isolation dB TBD Bypass Current μA 20 6 8 LNA  Bypass Receive Bypass Mode Insertion Loss Input Power of P1dB 6 8 Transmit Mode; TX_EN=High; Maximum Power KANGXI Communication Technologies  www.kxcomtech.com  TEL (+86) 021 6168 1915 This product datasheet is subject to change without notice. Rev 02 Feb.18, 2020 KCT8536C PRELIMINARY DATASHEET PRODUCT QUALIFICATION Parameters Units Min Max Conditions ESD – Human Body Mode V TBD HBM ESD – Charge Device Mode V TBD CDM ESD HANDLING: Although this device is designed to be as robust as possible, electrostatic discharge (ESD) can damage this device. This device must be protected at all times from ESD when handling or transporting. Static charges may easily produce potentials of several kilovolts on the human body or equipment, which can discharge without detection. Industry-standard ESD handling precautions should be used at all times. KANGXI Communication Technologies  www.kxcomtech.com  TEL (+86) 021 6168 1915 This product datasheet is subject to change without notice. Rev 02 Feb.18, 2020 KCT8536C PRELIMINARY DATASHEET CONTROL LOGIC TABLE Note: TX_EN LNA_EN Mode of Operation 1 0 Transmit Mode 0 1 Receive LNA Mode 0 0 Bypass Mode “1” denotes high voltage state (> 1.8V) “0” denotes low voltage state (
KCT8536C 价格&库存
很抱歉,暂时无法提供与“KCT8536C”相匹配的价格&库存,您可以联系我们找货
