KCT8227D
KCT8227D
    KCT(康希通信)
    QFN16_2.5X2.5MM_EP
    2.4GHZ无线局域网前端模块
KCT8227D 数据手册
KCT8227D PRODUCT DATASHEET RX_EN VDET PA_EN 2.4GHz WLAN Front-End Module PA TX Description KCT8227D is a fully integrated 802.11b/g/n/ac WLAN RF Front-end module (FEM) which incorporates key RF functionality. It is integrated with a highefficiency power amplifier (PA), a low noise amplifier (LNA) with bypass, the associated matching network and a single-pole, double-throw (SPDT) switch all in one device. The PA power detector and a digital enable control are also integrated. KCT8227D is assembled in a compact, low-profile 2.5*2.5*0.55mm 16-pin QFN ANT package. It is the perfect RF Front-end solution for implementing 2.4GHz high performance WLAN systems supporting multiple standards. Applications LNA RX LNA_EN    802.11b/g/n/ac set-top boxes, networking, and personal computer systems PC cards, PCMCIA cards, mini-cards, and half mini-cards WLAN enabled wireless video systems FEATURES  Integrated high performance 2.4GHz PA, LNA with bypass, and T/R switch  Fully-matched input and output  Integrated Power Detector  Output power: +21.5dBm @ DEVM=-35dB, VHT40/MCS9, 5V +22.5dBm @ DEVM=-30dB, HT20/MCS7, 5V  Transmit gain: 28dB at 5V  Receive gain: 17dB at 5V  Noise Figure: 3.0dB at 5V  ESD protection circuitry on all PINs  Minimal External Components Required  Small package: QFN 16-pin, 2.5×2.5×0.55mm (MSL3, 260 oC per JEDEC J-STD-020)  ROHS and REACH Compliant KANGXI Communication Technologies  www.kxcomtech.com  TEL (+86) 021 6168 1915 This product datasheet is subject to change without notice. Rev E Dec.28, 2020 KCT8227D PRODUCT DATASHEET PIN ASSIGNMENTS Pin Number Pin Name Description 1 VDET Detector Output Voltage 3, 4 VCC PA Supply Voltage 5 TX RF Input Port from the Transceiver 6 TX_EN Input to Control TX Enable 2,7,11,12,15,17 GND Ground – Must be connected to Ground in the Application Circuit 8 RX RF Output Port from the LNA or Bypass 9 LNA_EN Input to Control LNA Enable or Bypass Mode 10,13 NC Internally Not Connected 14 RX_EN Input to Control RX Enable 16 ANT Antenna – RF Signal from the PA or RF Signal Applied to the LNA PIN-OUT DIAGRAM (Top View) VDET ANT GND RX_EN NC 16 15 14 13 1 12 GND 17 GND GND 2 11 GND VCC 3 10 NC VCC 4 9 5 6 7 8 TX TX_EN GND RX LNA_EN KANGXI Communication Technologies  www.kxcomtech.com  TEL (+86) 021 6168 1915 This product datasheet is subject to change without notice. Rev E Dec.28, 2020 KCT8227D PRODUCT DATASHEET ABSOLUTE MAXIMUM RATINGS Parameters Units Min Max DC Supply Voltage V -1.0 +8.0 All VCC Pins Control Voltage V -1.0 +3.6 All Control Pins DC Current Consumption mA 600 Maximum TX Input Power (50 ohm load, No Damage) dBm +10 LNA On Maximum RX Input Power (No Damage) dBm +10 Bypass Mode Maximum RX Input Power (No Damage) dBm +20 Storage Temperature oC Junction Temperature oC +150 oC/W +37 VSWR 20:1 Thermal Resistance (θJC) Ruggedness ( Pin =10dBm, No Permanent Damage) -40 Conditions +150 NOTE: Sustained operation at or above the Absolute Maximum Ratings for any one or combinations of the above parameters may result in permanent damage to the device and is not recommended. All Maximum RF Input Power Ratings assume 50-ohm terminal impedance. NOMINAL OPERATING CONDITIONS Parameters Units Min Typical Max DC Supply Voltage V 4.5 5.0 5.5 Control Pin Voltage- Logic High V 1.8 3.6 Control Pin Voltage- Logic Low V 0 0.4 Control Pin DC Current μA Operating Temperature oC Conditions All VCC pins 400 -40 +25 +85 KCT8227D ELECTRICAL SPECIFICATIONS (VCC= 5V, T = 25 oC, All Unused Ports Terminated with 50Ω, Unless Otherwise Noted) Parameters Units Min GHz 2.4 Small Signal Gain dB 26.5 28 Gain Flatness dB -0.5 20.5 21.5 25 21.5 22.5 26 Frequency Range Typ Max Conditions 2.5 Transmit Mode Output Power dBm 29.5 CW Signal; input power=-20dBm +0.5 Across any 40MHz bandwidth DEVM=-35dB, VHT40/MCS9, Preamble only DEVM=-30dB, HT20/MCS7, Preamble only 802.11b, Mask Compliance KANGXI Communication Technologies  www.kxcomtech.com  TEL (+86) 021 6168 1915 This product datasheet is subject to change without notice. Rev E Dec.28, 2020 KCT8227D PRODUCT DATASHEET Parameters Current Consumption Units Min Typ Max Conditions Modulated signal, 100% duty @ No RF @+21.5dBm @+22.5dBm @+26dBm 110 250 270 390 120 270 300 420 135 290 340 460 -3 -20 dB 8 -5 -24 10 dB 10 16 dBm 26.5 28.5 0.17 0.55 0.58 0.65 30 3 0.22 0.60 0.63 0.70 32 5 0.25 0.65 0.68 0.75 400 1 500 17 18.5 3.0 3.3 -3 mA Harmonic dBm/MHz 2nd Harmonics 3rd Harmonics Input Return Loss Output Return Loss 1dB Output Compression Point Power Detector Output V Isolation dB PA Switching Time ns Power Detector Bandwidth MHz Pout=+26dBm, 1Mbps, 802.11b Modulated signal, 100% duty @ No RF @+21.5dBm @+22.5dBm @+26dBm ANT to RX TX to RX From 50% logic level change to 90%/10% power level TX SD Receive Mode – LNA On Gain dB Noise Figure dB 1dB Input Compression Point 15.5 dBm -7 -5 Input Return Loss dB 8 12 Output Return Loss dB 10 13 LNA Supply Current mA 15 18 Switching Time ns Isolation dB 26 40 29 42 dB 4 5.5 7 dBm 16 18 20 Input Return Loss dB 8 11 Output Return Loss dB 6 8 Isolation dB Bypass Current Consumption μA 40 42 350 43 44 450 24 LNA Bypass LNA TX ANT to TX RX to TX 400 Receive Bypass Mode Insertion Loss Input Power of P1dB ANT to TX RX to TX 700 KANGXI Communication Technologies  www.kxcomtech.com  TEL (+86) 021 6168 1915 This product datasheet is subject to change without notice. Rev E Dec.28, 2020 KCT8227D PRODUCT DATASHEET PRODUCT QUALIFICATION Parameters Units Min Max Conditions ESD – Human Body Mode V 500 HBM ESD – Charge Device Mode V 2000 CDM ESD – Machine Mode V 50 ESD HANDLING: MM Although this device is designed to be as robust as possible, electrostatic discharge (ESD) can damage this device. This device must be protected at all times from ESD when handling or transporting. Static charges may easily produce potentials of several kilovolts on the human body or equipment, which can discharge without detection. Industry-standard ESD handling precautions should be used at all times. CONTROL LOGIC TABLE TX_EN RX_EN LNA_EN Mode of Operation 1 0 0 WLAN Transmit 0 1 1 WLAN Receive LNA 0 1 0 WLAN Receive Bypass 0 0 0 Shutdown Note: “1” denotes high voltage state (>1.8V) “0” denotes low voltage state (
KCT8227D 价格&库存
很抱歉,暂时无法提供与“KCT8227D”相匹配的价格&库存,您可以联系我们找货
