SESUC5VD882SY-2B
SESUC5VD882SY-2B
    SEMITEL(晶讯)
    SOD-882
    双向ESD 5V截止 峰值浪涌电流:3A@8/20US
SESUC5VD882SY-2B 数据手册
Semitel Ultra Low Capacitance ESD/Transient Protection Diode Enabling your idea Features SESUC5VD882SY-2B ■ 60Watts peak pulse power (tp = 8/20μs) ■ SOD-882 Package ■ Bidirectional configurations ■ R2R + Zener technology ■ Low clamping voltage ■ Low leakage current ■ Ultra low capacitance (Cj=0.3pF typ.) ■ Protection one data/power line to: IEC 61000-4-2 ±10kV contact ±15kV air SOD-882 IEC 61000-4-4 (EFT) 40A (5/50ns) Ultra Low Capacitance ESD/Transient Protection Diode IEC 61000-4-5 (Lightning) 3A (8/20μs) ■ RoHS compliant Applications ■ USB3.0, Firewire, DVI, HDMI, S-ATA ■ Thunderbolt, Display Port Schematic Diagram ■ Mobile HDMI Link, MDDI, MIPI, SWP / NFC Absolute Maximum Ratings (TA=25℃, Unless otherwise specified.) Parameter Symbol Value Unit Peak Pulse Power (TP=8/20μS) PPP ESD contact/air discharge (IEC-61000-4-2) VESD 60 10/15 W kV A ℃ Peak Pulse Current ( tP = 8/20μS ) IPP Junction Temperature TJ 3 -55 to +125 Storage temperature TSTG -55 to +150 ℃ TL 260 ℃ Maximum Lead Solder Temperature(10 second duration) Electrical Characteristics (TA=25℃, Unless otherwise specified.) Parameter Reverse stand-off Voltage Reverse Breakdown Voltage Symbol Condition Min Typ VRWM VBR IT=1mA Reverse Leakage Current IR VR=5.0V 6.5 Clamping Voltage (IEC 61000-4-5) VC IPP=3A Trigger Voltage (IEC 61000-4-2) VT VESD=8kV Clamping Voltage (IEC 61000-4-2) VC VESD=8kV 20 Junction Capacitance CJ VR=0V, f=1MHz 0.3 Max Unit 5.0 V 100 nA 20.5 V 8.5 5 V 135 V V 0.35 pF 1 @copyright Semitel 2016 www.semiteltech.com Semitel Ultra Low Capacitance ESD/Transient Protection Diode Enabling your idea Typical Characteristic Curves Fig.1 Peak Pulse Power Rating Curve Fig.2 Pulse Derating Curve 1 % of Rated Power (PPP) or IPP Peak Pulse Power –PPP(KW) 10 60W 0.1 1 10 100 1000 80 60 40 20 0 0 Pulse Duration tp (μs) 100 125 100%IPP , 8μS 150 100% 90% 30ns 80 50%IPP, 20μS -t e 60 Percent of IPP Percent of IPP 75 Fig.4 Pulse Waveform-ESD(IEC61000-4-2) 100 40 20 0 50 Ambient Temperature—TA(℃) Fig.3 Pulse Waveform-8/20μs 120 25 60ns 10% 0 5 10 15 20 25 30 0 30 60 Fig.5 IEC61000-4-2 +8kV Contact Discharge Fig.6 IEC61000-4-2 -8kV Contact Discharge Trigger and Clamping Voltage(V) Time (ns) Trigger and Clamping Voltage(V) Time (μs) tr 0.7 to 1ns Time (ns) Ultra Low Capacitance ESD/Transient Protection Diode 0.01 0.1 110 100 Time (ns) 2 @copyright Semitel 2016 www.semiteltech.com Semitel Ultra Low Capacitance ESD/Transient Protection Diode Enabling your idea Product Dimensions Unit: mm P Order Information Device SESUC5VD882SY-2B Package Carrier Quantity HSF Status SOD-882 Tape & Reel(7") 10,000pcs/reel RoHS compliant Revision history Date Revision Description of changes 22-April-2016 A0 First issue Ultra Low Capacitance ESD/Transient Protection Diode Marking 3 @copyright Semitel 2016 www.semiteltech.com Semitel Ultra Low Capacitance ESD/Transient Protection Diode Enabling your idea or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. · Users should independently evaluate the suitability of and test each product selected for their own applications, and SEMITEL assumes no liability whatsoever relating to the choice, selection or use of the SEMITEL products and services described herein. · SEMITEL reserves the right to change or update, without notice, any information contained in this publication; to change, without notice, the design, construction, processing, or specification of any product; and to discontinue or limit production or distribution of any product. · Information in this document supersedes and replaces all information previously supplied. · Products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an SEMITEL product can reasonably be expected to result in personal injury, death or severe property or environmental damage. SEMITEL accepts no liability for inclusion and/or use of SEMITEL products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. · This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Ultra Low Capacitance ESD/Transient Protection Diode CAUTION / WARNING · Information in this document is believed to be accurate and reliable. However, SEMITEL does not give any representations or warranties, expressed · Resale of SEMITEL products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by SEMITEL for the SEMITEL product or service described herein and shall not create or extend in any manner whatsoever, any liability of SEMITEL. · SEMITEL expressly disclaims all implied warranties regarding the information contained herein, including, but not limited to, any implied warranties of merchantability or fitness for a particular purpose. SEMITEL only obligations are those in the SEMITEL Standard Terms and Conditions of Sale and in no case will SEMITEL be liable for any incidental, indirect, or consequential damages arising from the sale, resale, use, or misuse of its products. Specifications are subject to change without notice © Copyright 2005, Semitel Electronics . ® is a registered trademark of Semitel Electronics All rights reserved 4 @copyright Semitel 2016 www.semiteltech.com
SESUC5VD882SY-2B 价格&库存
很抱歉,暂时无法提供与“SESUC5VD882SY-2B”相匹配的价格&库存,您可以联系我们找货
