SES5VD882SY-2B
SES5VD882SY-2B
    SEMITEL(晶讯)
    SOD-882
    SES5VD882SY-2B
SES5VD882SY-2B 数据手册
Semitel ESD Protection Diode Enabling your idea Features SES5VD882SY-2B ■ 174 Watts peak pulse power (tp = 8/20μs) ■ SOD-882 package ■ Bidirectional configurations ■ Protects one I/O port ■ Low clamping voltage ■ Low Leakage current ■ ESD-immunity acc. IEC 61000-4-2 ±30KV contact ±30KV air ■ IEC 61000-4-4 (EFT) 40A (5/50ns) SOD-882 Applications ■ Cell Phone ■ PDA ■ Notebook Schematic Diagram ■ Digital Cameras ESD Protection Diode ■ Portable Instrumentation ■ Audio and video equipment Absolute Maximum Ratings (TA=25℃, Unless otherwise specified.) Parameter Symbol Value Unit Peak Pulse Power (TP=8/20μS) PPP 174 W Peak Pulse Current ( tP = 8/20μS ) IPP 9.4 A Junction Temperature TJ -55 to +125 ℃ Storage temperature TSTG -55 to +150 ℃ Electrical Characteristics (TA=25℃, Unless otherwise specified.) Parameter Reverse stand-off Voltage Reverse Breakdown Voltage Reverse Leakage Current Clamping Voltage Junction Capacitance Symbol Condition Min Typ VRWM 5.6 Max Unit 5 V μA VBR IT=1mA IR VR=5V 6.8 1 VC IPP=5A,TP=8/20μS 11.6 V VC IPP=9.4A,TP=8/20μS 18.6 V CJ VR=0V,f=1MHz 15 V pF 1 @copyright Semitel 2013 www.semiteltech.com Semitel ESD Protection Diode Enabling your idea Typical Characteristic Curves Fig.1 Peak Pulse Power Rating Curve Fig.2 Pulse Derating Curve % of Rated Power (PPP) or IPP Peak Pulse Power –PPP(KW) 10 1 0.1 0.01 0.1 1 10 100 110 100 1000 80 60 40 20 0 0 Pulse Duration tp (μs) 100 125 150 100%IPP , 8μS 100% 90% 50%IPP, 20μS -t e 60 Percent of IPP 30ns 80 40 20 60ns 10% 0 5 10 15 20 25 30 ESD Protection Diode Percent of IPP 75 Fig.4 Pulse Waveform-ESD(IEC61000-4-2) 100 0 50 Ambient Temperature—TA(℃) Fig.3 Pulse Waveform-8/20μs 120 25 0 Time (μs) tr 0.7 to 1ns 30 60 Time (ns) Product Dimensions Unit: mm 2 @copyright Semitel 2013 www.semiteltech.com Semitel ESD Protection Diode Enabling your idea Order Information Device SES5VD882SY-2B Package Marking Carrier SOD-882 C Tape & Reel Quantity HSF Status 10000pcs / Reel RoHS compliant Revision history Date Revision Description of changes 12-March-2013 A0 First issue ESD Protection Diode 3 @copyright Semitel 2013 www.semiteltech.com Semitel ESD Protection Diode Enabling your idea ESD Protection Diode CAUTION / WARNING · Information in this document is believed to be accurate and reliable. However, SEMITEL does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. · Users should independently evaluate the suitability of and test each product selected for their own applications, and SEMITEL assumes no liability whatsoever relating to the choice, selection or use of the SEMITEL products and services described herein. · SEMITEL reserves the right to change or update, without notice, any information contained in this publication; to change, without notice, the design, construction, processing, or specification of any product; and to discontinue or limit production or distribution of any product. · Information in this document supersedes and replaces all information previously supplied. · Products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an SEMITEL product can reasonably be expected to result in personal injury, death or severe property or environmental damage. SEMITEL accepts no liability for inclusion and/or use of SEMITEL products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. · This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. · Resale of SEMITEL products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by SEMITEL for the SEMITEL product or service described herein and shall not create or extend in any manner whatsoever, any liability of SEMITEL. · SEMITEL expressly disclaims all implied warranties regarding the information contained herein, including, but not limited to, any implied warranties of merchantability or fitness for a particular purpose. SEMITEL only obligations are those in the SEMITEL Standard Terms and Conditions of Sale and in no case will SEMITEL be liable for any incidental, indirect, or consequential damages arising from the sale, resale, use, or misuse of its products. Specifications are subject to change without notice © Copyright 2005, Semitel Electronics . ® is a registered trademark of Semitel Electronics All rights reserved 4 @copyright Semitel 2013 www.semiteltech.com
SES5VD882SY-2B 价格&库存
很抱歉,暂时无法提供与“SES5VD882SY-2B”相匹配的价格&库存,您可以联系我们找货
