MXDLN16TL
MXDLN16TL
    MAXSCEND(卓胜微电子)
    LGA6_1.1X0.7MM
    用于全球导航卫星系统的高增益低噪声放大器
MXDLN16TL 数据手册
MXDLN16TL VED APPRO SiGe LNA for Global Navigation Satellite System (GNSS) Description Applications MXDLN16TL high gain, low noise amplifier (LNA) is dedicated  Automotive Navigation to GPS, GLONASS Galileo and Beidou standards. This  Personal Navigation Device (PND)  Cell Phone with GPS  MID/PAD with GPS product has an extremely low noise figure of 0.7dB, 17dB gain and excellent linearity. MXDLN16TL works under a 1.6V to 3.3V single power supply while consumes 0.8 mA current, in power down (PD) mode, the power consumption will be reduced to less than 1uA. Features MXDLN16TL use a small 1.1mmx0.7mmx0.45mm LGA 6-pin  High Gain: 17dB  Low noise figure 0.7dB @ 1575.42MHz  Low operation current 0.8mA & PD current less than 1uA  Single supply voltage range 1.6V to 3.3V  Small package 1.1mmx0.7mmx0.45mm,MSL1  Low cost BOM  Lead-Free and RoHS-Compliant package. Page 1 / 8 MXDLN16TL Rev1.5 This document contains information that is confidential and proprietary to Maxscend Microelectronics Company, Ltd. (Maxscend) and may not be reproduced in any form without express written consent of Maxscend. No transfer or licensing of technology is implied by this document. Pin Description SiGe LNA for Global Navigation Satellite System (GNSS) Pin Configuration/Application Diagram (Top view) Figure 1 MXDLN16TL application circuit Table 1 Pin Descriptions Pin Pin Name I/O Pin Description 1 GND AG Analog VSS 2 VDD AP Power supply 3 RFOUT AO LNA output 4 GND AG Analog VSS 5 RFIN AI LNA input from antenna 6 EN DI Pull high enable, pull low into power down mode Note: DI (digital input), DO (digital output), DIO (digital bidirectional), AI (analog input), AO (analog output), AIO (analog bidirectional), AP (analog power), AG (analog ground), Table 2 Recommended component value in application circuit Component Vendor Type Part Number & value Murata Wired inductor, high Q LQW15AN, 15nH Various Ceramic 14nH L1 Page 2 / 8 MXDLN16TL: Rev1.5 Copyright @2018 Maxscend Microelectronics Company, Ltd. All rights reserved. Maxscend Confidential Electrical Characteristics SiGe LNA for Global Navigation Satellite System (GNSS) Electrical Characteristics Table 3 Absolute Maximum Ratings Parameter Symbol Min Max DC Supply Voltage VDD -0.3 4.0 Supply Voltage For other Pin VIO -0.3 VDD+0.3 Max RF Input Power(RFx to GND) PIN - 10 dBm Device Operating Temperature TOP -40 90 ℃ Junction Temperature TJun 150 - ℃ Device Storage Temperature TSTG -65 150 - Lead Temperature (soldering) TLT 260 - Soldering Temperature (reflow) TST 260 - VESD(MM) 125 - VESD(HBM) 2000 - VESD(CDM) 1000 - Electrostatic Discharge Unit V - V Notice: Exposure to maximum rating conditions for extended periods may reduce device reliability. There is no damage to device with only one parameter set at the limit and all other parameters set at or below their nominal value. Exceeding any of the limits listed here may result in permanent damage to the device. Table 4 Recommended Operating Conditions Parameter Operating Frequency Symbol MIN TYP MAX Unit F0 1559 - 1610 MHz 0.6 0.8 1.15 mA 0 0.01 1 uA IDD EN=High Supply Current IDD EN=Low MIPI Logic Voltage(SDATA, SCL) High VIH 1.0 1.8 VDD MIPI Logic Voltage(SDATA, SCL) Low VIL 0 0 0.3 V Page 3 / 8 MXDLN16TL: Rev1.5 Copyright @2018 Maxscend Microelectronics Company, Ltd. All rights reserved. Maxscend Confidential Electrical Characteristics SiGe LNA for Global Navigation Satellite System (GNSS) AC Characteristics TA=-40~+85℃, typically TA=25℃ VDD=2.8V, all data measured on Maxscend’s EVB, unless otherwise noted Table 5 AC Characteristics(VDD=2.8V) Parameters Conditions Min Typ Max Units RF Frequency Range None 1559 - 1610 MHz 15 17 19 15 17 19 - 0.7 1.1 Note5 - 0.75 1.15 Note1 - -8 -5 Note5 - -8 -5 Note1 - -20 -15 Note5 - -20 -15 Reverse Isolation Note1 - -30 -24 dB Desense Note2 - 0.25 0.75 dB Stability Note3 1.5 - - - Input Power 1-dB Compression Point 1575MHz -25 -18 - dBm Input In-Band IP3 Note4 -13 -8 - dBm Power Gain dB Note5 Noise Figure dB Input Return Loss dB Output Return Loss dB Note1: sweep power -30dBm, 1575.42MHz Note2: jammed signal @ 1463MHz & 1712MHz, -20dBm Note3: frequency range 500MHz-5GHz Note4: f1 = 1574.5 MHz, f2 = 1575.5 MHz, -20dBm Note5: Beidou frequency range B1:1559.052MHz---1591.788MHz Page 4 / 8 MXDLN16TL: Rev1.5 Copyright @2018 Maxscend Microelectronics Company, Ltd. All rights reserved. Maxscend Confidential Electrical Characteristics SiGe LNA for Global Navigation Satellite System (GNSS) TA=-40~+85℃, typically TA=25℃ VDD=1.8V, all data measured on Maxscend’s EVB, unless otherwise noted Table 6 AC Characteristics(VDD=1.8V) Parameters Conditions Min Typ Max Units RF Frequency Range None 1559 - 1610 MHz 14.8 16.8 18.8 14.8 16.8 18.8 - 0.7 1.1 Note5 - 0.75 1.15 Note1 - -8 -5 Note5 - -8 -5 Note1 - -20 -15 Note5 - -20 -15 Reverse Isolation Note1 - -30 -24 dB Desense Note2 - 0.25 0.75 dB Stability Note3 1.5 - - - Input Power 1-dB Compression Point 1575MHz -26 -19 - dBm Input In-Band IP3 Note4 -14 -9 - dBm Power Gain dB Note5 Noise Figure dB Input Return Loss dB Output Return Loss dB Note1: sweep power -30dBm, 1575.42MHz Note2: jammed signal @ 1463MHz & 1712MHz, -20dBm Note3: frequency range 500MHz-5GHz Note4: f1 = 1574.5 MHz, f2 = 1575.5 MHz, -20dBm Note5: Beidou frequency range B1:1559.052MHz---1591.788MHz Page 5 / 8 MXDLN16TL: Rev1.5 Copyright @2018 Maxscend Microelectronics Company, Ltd. All rights reserved. Maxscend Confidential Package Information SiGe LNA for Global Navigation Satellite System (GNSS) Package Outline Dimensions Figure 2 Package Outline Dimensions Page 6 / 8 MXDLN16TL: Rev1.5 Copyright @2018 Maxscend Microelectronics Company, Ltd. All rights reserved. Maxscend Confidential Package Information SiGe LNA for Global Navigation Satellite System (GNSS) Marking Specifications Manufacture Code(Variable): XA Product Code(Fixed): X From 0~9 and A ~Z excluding letter "I" and "O" for lot tracking Pin 1 Figure 3 Marking Specification (Top View) Tape and Reel Dimensions Figure 4 Tape and Reel Dimensions Page 7 / 8 MXDLN16TL: Rev1.5 Copyright @2018 Maxscend Microelectronics Company, Ltd. All rights reserved. Maxscend Confidential Package Information SiGe LNA for Global Navigation Satellite System (GNSS) Reflow Chart tP TP Critical Zone TL to TP Ramp-up Temperature TL TSmax tL TSmin Ramp-down tS Preheat t 25 ℃ to Peak Time Figure 5 Recommended Lead-Free Reflow Profile Table 7 Reflow condition Profile Parameter Lead-Free Assembly, Convection, IR/Convection Ramp-up rate(TSmax to Tp) 3℃/second max. Preheat temperature(TSmin to TSmax) 150℃ to 200℃ Preheat time(ts) 60 - 180 seconds Time above TL , 217℃(TL) 60 - 150 seconds Peak temperature(Tp) 260℃ Time within 5℃ of peak temperature(tp) 20 - 40 seconds Ramp-down rate 6℃/second max. Time 25℃ to peak temperature 8 minutes max. ESD Sensitivity Integrated circuits are ESD sensitive and can be damaged by static electric charge. Proper ESD protection techniques should be used when handling these devices. RoHS Compliant This product does not contain lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) and polybrominated diphenyl ethers (PBDE), and are considered RoHS compliant. Page 8 / 8 MXDLN16TL: Rev1.5 Copyright @2018 Maxscend Microelectronics Company, Ltd. All rights reserved. Maxscend Confidential
MXDLN16TL 价格&库存
很抱歉,暂时无法提供与“MXDLN16TL”相匹配的价格&库存,您可以联系我们找货
