MXD8921H
MXD8921H
    MAXSCEND(卓胜微电子)
    LGA6_1.1X0.7MM
    适用于LTE中高频段的带旁路模式的SIGE低噪声放大器
MXD8921H 数据手册
MXD8921H SiGe Low Noise Amplifier with Bypass Mode for LTE Mid-High Band Rev1.3 VED APPRO This document contains information that is confidential and proprietary to Maxscend Microelectronics Company Limited (Maxscend) and may not be reproduced in any form without express written consent of Maxscend. No transfer or licensing of technology is implied by this document. Page 1 of 8 Maxscend Microelectronics Company Limited. All rights reserved. Maxscend Confidential MXD8921H LNA with bypass mode for LTE mid-high band Features General Description MXD8921H high gain, low noise amplifier (LNA) is dedicated to LTE middle band and high band receive using advanced SiGe process. This product has two operation modes, low noise mode and bypass mode. MXD8921H works under a 1.6V to 3.6V single power supply while consumes 4.2 mA current in low noise mode, in bypass mode, the power consumption will be reduced to less than 1uA.  Broadband frequency range: 1.7G to 2.7 GHz  High Gain  MXD8921H uses a small 1.1mm × 0.7mm × 0.45mm LGA 6-pin package. Applications  LTE high-mid band receiving - 14.6dB gain at 1.7GHz to 1.8GHz - 14.5dB gain at 1.8GHz to 2.2GHz - 13.5dB gain at 2.3GHz to 2.7GHz Ultra low noise figure - 0.60dB noise figure at 1.7GHz to 1.8GHz - 0.65dB noise figure at 1.8GHz to 2.2GHz - 0.8dB noise figure at 2.3GHz to 2.7GHz  Operation current 4.2mA  Single supply voltage range 1.6V to 3.6V  Small, LGA (6-pin, 1.1mm x 0.7mm x 0.45mm) package ,MSL1 Pin Configuration/Application Diagram (Top view) RFin GND 4 3 RFOUT RF output V DD L1 MXD8921H 1nF RF inp ut RFI N 5 2 EN V DD VDD 0.1u F E nabl e EN 6 1 GND RFOUT Figure 1 MXD8921H application circuit Page 2 of 8 Maxscend Microelectronics Company Limited. All rights reserved. Maxscend Confidential MXD8921H LNA with bypass mode for LTE mid-high band Pin Descriptions & Input matching inductance Table 1 Pin 1 2 3 4 5 6 Pin Name I/O Pin Description GND AG Analog VSS VDD AP Power supply RFOUT AO LNA output GND AG Analog VSS RFIN AI LNA input from antenna EN DI Pull high into low noise mode, pull low into bypass mode Note: DI (digital input), DO (digital output), DIO (digital bidirectional), AI (analog input), AO (analog output), AIO (analog bidirectional), AP (analog power), AG (analog ground), Table 2 Input matching inductance Component Matching Band 1700MHz – 1800MHz L1 1800MHz – 2200MHz 2300MHz – 2700MHz Vendor Type Part Number & value Murata Wired inductor, high Q LQW15AN, 5.1nH various Ceramic inductor, low Q 4.7nH Murata Wired inductor, high Q LQW15AN, 4.6nH various Ceramic inductor, low Q 4nH Murata Wired inductor, high Q LQW15AN, 3.9nH various Ceramic inductor, low Q 3.3nH Recommended Operation Range Table 3 Parameters Operation Frequency Power supply Control Voltage High Control Voltage Low Symbol Min Typ Max Units f1 VDD VCTL_H VCTL_L 1700 1.6 1.0 0 2.8 1.8 0 2700 3.6 VDD 0.3 MHz V V V Absolute Maximum Ratings Table 4 Maximum ratings Parameters Supply voltage Digital control voltage RF input power Operating temperature Storage temperature Electrostatic Discharge Human body model Note1 (HBM), Class 1B Charged device model Note2 (CDM), Class III Symbol Minimum Maximum Units VDD VCTL PIN TOP TSTG -0.3 -0.3 –40 –65 +4.0 VDD+0.3 +25 +90 +160 V V dBm ℃ ℃ ESD_HBM 2000 V ESD_CDM 1000 Note: Exposure to maximum rating conditions for extended periods may reduce device reliability. There is no damage to device with only one parameter set at the limit and all other parameters set at or below their nominal value. Exceeding any of the limits listed here may result in permanent damage to the device. Note1: According to ESDA/JEDECJS-001-2014 Note2: According to ESDA/JEDECJS-002-2014 Page 3 of 8 Maxscend Microelectronics Company Limited. All rights reserved. Maxscend Confidential MXD8921H LNA with bypass mode for LTE mid-high band Specifications Typically TA=25℃ VDD=2.8V, All data measured on Maxscend’s EVB, unless otherwise noted Table 5 High Gain mode Electrical Specifications Parameter Symbol Min. Specification Typical Max. Units Test Condition DC Specifications Supply voltage Supply current VDD IDD 1.6 3 2.8 4.2 3.6 5.8 V mA VDD = 2.8V, VEN=1.8V 12.6 12.5 11.5 - 14.6 14.5 13.5 0.6 0.65 0.8 -8 -10 -12 -8 -12 -14 -23 16.6 16.5 15.5 0.95 1.0 1.15 -4 -5 -6 -4 -6 -8 -18 dB dB dB dB dB dB dB dB dB dB dB dB dB 1700-1800MHz 1800-2200MHz 2300-2700MHz 1700-1800MHz 1800-2200MHz 2300-2700MHz 1700-1800MHz 1800-2200MHz 2300-2700MHz 1700-1800MHz 1800-2200MHz 2300-2700MHz 1700 to 2700MHz 1.0 -8.3 -6 0 2 -4.8 -2.5 5 7 - dBm dBm dBm dBm turn-on-time - - 4 μs turn-off-time - - 1 μs RF Specifications Power gain G Noise figure NF Input Return loss |S11| Output Return loss |S22| Isolation ISL Stability factor Input 1 dB compression point Kf Input IP3 P1dB IIP3 Switch time at 2GHz at 2.5GHz Note1 Note2 Bypass state to High gain state, to 90% of the Gain High Gain state to Bypass state, to 10% of the Gain Note1: Pin=Pin2=-20dBm, F1=2000MHz, F2=2001MHz Note2: Pin=Pin2=-20dBm, F1=2500MHz, F2=2501MHz Table 6 Bypass mode Electrical Specifications Parameter Symbol DC Specifications Supply voltage Supply current VDD IDD Specification Min. Typical Max. Units Test Condition 1.6 0 2.8 0.1 3.6 1 V uA VDD = 2.8 V, VEN=low -5 -4 -10 -5 dB dB dB 1700-1800MHz 1800-2700MHz 1700 to 2700MHz RF Specifications Input Return loss |S11| -8 -7 - Output Return loss Input 1 dB compression point |S22| - -10 -5 dB 1700 to 2700MHz P1dB 5 10 - dBm 1700 to 2700MHz Insertion loss IL Page 4 of 8 Maxscend Microelectronics Company Limited. All rights reserved. Maxscend Confidential MXD8921H LNA with bypass mode for LTE mid-high band Specifications Typically TA=25℃ VDD=1.8V, All data measured on Maxscend’s EVB, unless otherwise noted Table 7 High Gain mode Electrical Specifications Parameter Symbol Min. Specification Typical Max. Units Test Condition DC Specifications Supply voltage Supply current VDD IDD 1.6 2.8 1.8 4.0 3.6 5.6 V mA VDD = 1.8V, VEN=1.8V 12.3 12.2 11.2 - 14.3 14.2 13.2 0.6 0.65 0.8 -8 -10 -12 -8 -12 -14 -23 16.3 16.2 15.2 0.95 1.0 1.15 -4 -5 -6 -4 -6 -8 -18 dB dB dB dB dB dB dB dB dB dB dB dB dB 1700-1800MHz 1800-2200MHz 2300-2700MHz 1700-1800MHz 1800-2200MHz 2300-2700MHz 1700-1800MHz 1800-2200MHz 2300-2700MHz 1700-1800MHz 1800-2200MHz 2300-2700MHz 1700 to 2700MHz 1.0 -10.5 -8.5 -1 0 -7 -5 3 5 - turn-on-time - - 4 μs turn-off-time - - 1 μs RF Specifications Power gain G Noise figure NF Input Return loss |S11| Output Return loss |S22| Isolation ISL Stability factor Input 1 dB compression point Kf Input IP3 P1dB IIP3 - dBm dBm dBm dBm Switch time at 2GHz at 2.5GHz Note1 Note2 Bypass state to High gain state, to 90% of the Gain High Gain state to Bypass state, to 10% of the Gain Note1: Pin=Pin2=-20dBm, F1=2000MHz, F2=2001MHz Note2: Pin=Pin2=-20dBm, F1=2500MHz, F2=2501MHz Table 8 Bypass mode Electrical Specifications Parameter Symbol DC Specifications Supply voltage Supply current VDD IDD Specification Min. Typical Max. Units Test Condition 1.6 0 1.8 0.1 3.6 1 V uA VDD = 1.8 V, VEN=low -5.4 -4.4 -10 -5 dB dB dB 1700-1800MHz 1800-2700MHz 1700 to 2700MHz RF Specifications Input Return loss |S11| -8.4 -7.4 - Output Return loss Input 1 dB compression point |S22| - -10 -5 dB 1700 to 2700MHz P1dB 5 10 - dBm 1700 to 2700MHz Insertion loss IL Page 5 of 8 Maxscend Microelectronics Company Limited. All rights reserved. Maxscend Confidential MXD8921H LNA with bypass mode for LTE mid-high band Package Outline Dimensions aaa C A D ccc C A3 E A A2 SIDE VIEW aaa C LASER MARK FOR PIN1 IDENTIFICATION IN THIS AREA TOP VIEW e ALL DIMENSIONS ARE IN MILLIMETERS. 0.050 SYMBOL A A AA A A B 0.050 PIN1 ID A A2 A3 e D E aaa MILLIMETER MIN. NOR. 0.40 0.45 0.09 0.12 0.31 0.33 0.35 0.40 0.65 0.70 1.05 1.10 0.10 ccc 0.20 MAX. 0.50 0.15 0.35 0.45 0.75 1.15 MIN. 0.0157 0.0035 0.0122 0.0138 0.0256 0.0413 INCH NOR. 0.0177 0.0047 0.0130 0.0157 0.0276 0.0433 0.0039 MAX. 0.0197 0.0059 0.0138 0.0177 0.0295 0.0453 0.0079 BOTTOM VIEW 0.1±0.035 0.2±0.035 B 0.2±0.035 0.1±0.035 0.2±0.035 A 0.2±0.035 Figure 2 MXD8921H outline dimension Page 6 of 8 Maxscend Microelectronics Company Limited. All rights reserved. Maxscend Confidential MXD8921H LNA with bypass mode for LTE mid-high band Marking Specification Manufacture Code(Variable): Product Code(Fixed): From 1~9 and A ~Z V excluding letter "I" and "O" for lot tracking Pin 1 Figure 3 Marking specification (Top View) Tape and Reel Dimensions Figure 4 Tape and reel dimensions Page 7 of 8 Maxscend Microelectronics Company Limited. All rights reserved. Maxscend Confidential MXD8921H LNA with bypass mode for LTE mid-high band Reflow Chart tP TP Critical Zone TL to TP Ramp-up Temperature TL TSmax tL TSmin Ramp-down tS Preheat t 25 ℃ to Peak Time Figure 5 Recommended Lead-Free Reflow Profile Table 9 Reflow condition Profile Parameter Lead-Free Assembly, Convection, IR/Convection Ramp-up rate(TSmax to Tp) 3℃/second max. Preheat temperature(TSmin to TSmax) 150℃ to 200℃ Preheat time(ts) 60 - 180 seconds Time above TL , 217℃(tL) 60 - 150 seconds Peak temperature(Tp) 260℃ Time within 5℃ of peak temperature(tp) 20 - 40 seconds Ramp-down rate 6℃/second max. Time 25℃ to peak temperature 8 minutes max. ESD Sensitivity Integrated circuits are ESD sensitive and can be damaged by static electric charge. Proper ESD protection techniques should be used when handling these devices. RoHS Compliant This product does not contain lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) and polybrominated diphenyl ethers (PBDE), and are considered RoHS compliant. 1.3.1 Page 8 of 8 Maxscend Microelectronics Company Limited. All rights reserved. Maxscend Confidential
MXD8921H 价格&库存
很抱歉,暂时无法提供与“MXD8921H”相匹配的价格&库存,您可以联系我们找货
