MH254EUA
MH254EUA
    MST.(美伽)
    TO-92S
    霍尔效应开关
MH254EUA 数据手册
MH254 Micro-power CMOS Unipolar Hall Effect Switch MH254 Hall-effect sensor is a temperature stable, stress-resistant, Low Tolerance of sensitivity micro-power switch. Superior high-temperature performance is made possible through a dynamic offset cancellation that utilizes chopper-stabilization. This method reduces the offset voltage normally caused by device over molding, temperature dependencies, and thermal stress. MH254 is special made for low operation voltage, 1.65V, to active the chip which is includes the following on a single silicon chip: voltage regulator, Hall voltage generator, small-signal amplifier, chopper stabilization, Schmitt trigger, CMOS output driver. Advanced CMOS wafer fabrication processing is used to take advantage of low-voltage requirements, component matching, very low input-offset errors, and small component geometries. This device requires the presence of unipolar magnetic fields for operation. The package type is in a Halogen Free version has been verified by third party Lab. Features and Benefits ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ CMOS Hall IC Technology Strong RF noise protection 1.65 to 6V for battery-powered applications Operation down to 1.65V, Unipolar Hall Switch Micro power consumption High Sensitivity for reed switch replacement applications Low sensitivity drift in crossing of Temp. range Ultra Low power consumption at 5uA (Avg) High ESD Protection, HBM > ±4KV( min ) Totem-pole output RoHS compliant 2011/65/EU and Halogen Free Applications ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ 082118 Solid state switch Handheld Wireless Handset Awake Switch ( Flip Cell/PHS Phone/Note Book/Flip Video Set) Magnet proximity sensor for reed switch replacement in low duty cycle applications Water Meter PDA PDVD NB Pad PC Page 1 of 17 Rev. 1.07 MH254 Micro-power CMOS Unipolar Hall Effect Switch Ordering Information Company Name and Product Category XXXXXXXXX - X MH:MST Hall Effect/MP:MST Power MOSFET Part number Sorting Code Package type 181,182,183,184,185,248,249,276,477,381,381F,381R,382….. If part # is just 3 digits, the forth digit will be omitted. Temperature range Temperature Code Part number E: 85 ℃, I: 105 ℃, K: 125 ℃, L: 150 ℃ Package type UA:TO-92S,VK:TO-92S(4pin),VF:TO-92S(5pin),SO:SOT-23, Company Name and Product Category SQ:QFN-3,ST:TSOT-23,SN:SOT-553,SF:SOT-89(5pin); SS:TSOT-26,SD:DFN-6 Sorting α,β,Blank….. Part No. MH254EUA MH254EST MH254ESN MH254ESQ MH254ESS Temperature Suffix E (-40℃ to + 85℃) E (-40℃ to + 85℃) E (-40℃ to + 85℃) E (-40℃ to + 85℃) E (-40℃ to + 85℃) Package Type UA(TO-92S) ST (TSOT-23) SN (SOT-553) SQ (QFN2020-3) SS (QFN1x1x0.4) Custom sensitivity selection is available by MST sorting technology Functional Diagram VDD Awake/Sleep Timing Control Offset Cancellation VDD Control Logic Amp Out Hall Sensor GND Note: Static sensitive device; please observe ESD precautions. Reverse V DD protection is not included. For reverse voltage protection, a 100Ω resistor in series with VDD is recommended. MH254, HBM > ±4KV which is verified by third party lab. 082118 Page 2 of 17 Rev. 1.07 MH254 Micro-power CMOS Unipolar Hall Effect Switch Absolute Maximum Ratings At(Ta=25℃) Characteristics Supply voltage, (VDD) Output Voltage, (Vout) Reverse Voltage, (VDD) (VOUT) Magnetic flux density Output current, (IOUT) Operating temperature range, (Ta) Storage temperature range, (Ts) Maximum Junction Temp, (Tj) (θJA) ST/SN/UA/SQ/SS Thermal Resistance (θJC) ST/SN/UA/SQ/SS Package Power Dissipation, (PD) ST/SN/UA/SQ/SS Values 7 7 -0.3 Unlimited 1 Unit V V V Gauss mA -40 to +85 -65 to +150 150 310/540/206/540/540 223/390/148/390/390 400/230 /606/230/230 ℃ ℃ ℃ ℃/W ℃/W mW Note: Exceeding the absolute maximum ratings may cause permanent damage. Exposure to absolute maximumrated conditions for extended periods may affect device reliability. Electrical Specifications DC Operating Parameters:Ta=25℃, VDD=1.8V Parameters Test Conditions Supply Voltage, (VDD) Supply Current, (IDD) Output Leakage Current,(I off) Output High Voltage, (VOH) Operating Awake State Sleep State Average Output off Min Typ Max Units 1.4 3.6 5 6 3 7 10 1 Volts mA μA μA uA 1.65 IOUT=0.5mA(Source) Output Low Voltage, (VOL) Awake mode time, (Taw) IOUT=0.5mA(Sink) Operating Sleep mode time, (TSL) Operating Duty Cycle, (D,C) Electro-Static Discharge HBM VDD-0.2 V 0.2 V 40 80 uS 40 80 mS 0.1 4 % KV Typical application circuit C1:10nF C2:100pF 082118 Page 3 of 17 Rev. 1.07 MH254 Micro-power CMOS Unipolar Hall Effect Switch MH254EST/UA/SQ/SS Magnetic Specifications DC Operating Parameters:Ta=25℃, VDD=2.0V Parameter Symbol Test Conditions Min. Typ. Operating Point BOP N pole to branded side, B > BOP, Vout On Release Point BRP N pole to branded side, B < BRP, Vout Off -20 Hysteresis BHY |BOPx - BRPx| 10 -50 Max. Units Gauss -30 Gauss -10 Gauss MH254ESN Magnetic Specifications DC Operating Parameters:Ta=25℃, VDD=2.0V Parameter Symbol Test Conditions Min. Operating Point BOP S pole to branded side, B > BOP, Vout On Release Point BRP S pole to branded side, B < BRP, Vout Off Hysteresis BHY |BOPx - BRPx| 10 Typ. Max. Units 30 50 Gauss 20 Gauss 10 Gauss MH254EST/SQ/SS/SN/UA Output Behavior versus Magnetic Polar DC Operating Parameters:Ta = -40 to 85℃, VDD =1.65V to 6V Test OUT Parameter Parameter condition (ST/SS/SQ/UA) Null or weak magnetic field North pole North Pole B=0 or B < BRP BBop-S High Low South Pole North Pole ST Package SQ Package SS Package UA Package Out (SN) Out (ST/SQ/SS/UA) 082118 SN Package South Pole Page 4 of 17 Rev. 1.07 MH254 Micro-power CMOS Unipolar Hall Effect Switch Performance Graph Typical Supply Voltage (VDD) Versus Flux Density 55 Typical Temperature (TA) Versus Flux Density 55 25℃ 45 25 25 Flux Density(Gauss) 35 Flux Density(Gauss) 35 15 Bop-S 5 Brp-S -5 -15 -25 5 -25 -45 5.4 -55 6.0 Typical Supply Voltage (VDD) Versus Flux Density 55.0 -40 BRP- N 15.0 5.0 -5.0 -15.0 -25.0 5.4 BOP -N BRP -N 5.0 -15.0 -25.0 -55.0 6.0 -40 -20 0 25 40 55 20 3.0V Sleep Current(uA) Average Current(uA) Awarke Current(mA) 18 16 14 Current Consumption 14 85 Typical Supply Voltage(VDD) Versus Supply current current(IDD) 20 16 70 Temperature(℃) Typical Temperature(TA) Versus Supply Current(IDD) 18 85 -5.0 -45.0 3.0 3.6 4.2 4.8 Supply Voltage(V) 70 15.0 -35.0 2.3 55 3V 25.0 -45.0 11.65 40 45.0 -35.0 -55.0 20 Temperature(℃) 55.0 Flux Density(Gauss) BOP- N 25.0 Current Consumption 0 35.0 35.0 12 Sleep Current(uA) Average Current(uA) Awarke Current(mA) 25℃ 12 10 10 8 6 4 2 8 6 4 2 0 -40 -20 0 25 40 55 70 85 Temperature(℃) 082118 -20 Typical Temperature (TA) Versus Flux Density 25℃ 45.0 Brp-S -15 -45 3.0 3.6 4.2 4.8 Supply Voltage(V) Bop-S -5 -35 11.65 2.3 Flux Density(Gauss) 15 -35 -55 3V 45 Page 5 of 17 0 11.65 2.5 3.0 3.5 4.0 4.5 Supply Voltage(V) 5.0 6.0 Rev. 1.07 MH254 Micro-power CMOS Unipolar Hall Effect Switch Typical Supply Voltage(VDD) Versus Output Voltage(VDSON) 250.0 25℃ 25℃ Output Saturation Voltage (mV) Output Saturation Voltage (mV) 250.0 Typical Temperature (TA) Versus Output Voltage(VDSON) 200.0 150.0 100.0 50.0 200.0 150.0 100.0 50.0 0.0 0.0 11.65 2.3 3.0 3.6 4.2 4.8 Supply Voltage(V) 5.4 -40 6.0 0.035 0.030 0.025 0.020 0.015 0.010 55 70 85 UA Package 600 R θja = 206℃/w ST/SQ Package 500 R θja = 310℃/w 400 300 200 SN Package 100 Rθja = 540℃/w 0.005 0 0.000 082118 40 700 Package power Dissipation(mW) Output Leakage Current(uA) 0.040 11.65 20 Power Dissipation versus Temperature(TA) 25℃ 0.045 0 Temperature(℃) Typical Supply Voltage (VDD) Versus Leakage Current(IOFF) 0.050 -20 2.3 3 3.6 4.2 4.8 Supply Voltage(V) 5.4 6.0 Page 6 of 17 -40 0 40 80 Temperature(℃) 120 160 Rev. 1.07 MH254 Micro-power CMOS Unipolar Hall Effect Switch Package Power Dissipation The power dissipation of the Package is a function of the pad size. This can vary from the minimum pad size for soldering to a pad size given for maximum power dissipation. Power dissipation for a surface mount device is determined by TJ(max), the maximum rated junction temperature of the die, RθJA, the thermal resistance from the device junction to ambient, and the operating temperature, Ta. Using the values provided on the data sheet for the package, PD can be calculated as follows: PD = TJ(max) - Ta R j a The values for the equation are found in the maximum ratings table on the data sheet. Substituting these values into the equation for an ambient temperature Ta of 25°C, one can calculate the power dissipation of the device which in this case is 400 milliwatts. PD(ST) = 150C - 25C = 400mW 310C/ W The 310℃/W for the SN package assumes the use of the recommended footprint on a glass epoxy printed circuit board to achieve a power dissipation of 400 milliwatts. There are other alternatives to achieving higher power dissipation from the Package. Another alternative would be to use a ceramic substrate or an aluminum core board such as Thermal Clad. Using a board material such as Thermal Clad, an aluminum core board, the power dissipation can be doubled using the same footprint. Sensor Location, package dimension and marking MH254 Package ST Package(TSOT-23) (Top View) Hall Plate Chip Location (Bottom view) 3 0.80 2 Hall Sensor Location 1 1.45 NOTES: 1. PINOUT (See Top View at left:) Pin 1 VDD Pin 2 Output Pin 3 GND 2. Controlling dimension: mm; 082118 Page 7 of 17 Rev. 1.07 MH254 Micro-power CMOS Unipolar Hall Effect Switch SS Package (DFN 1.0*1.0) NOTES: 1. Controlling dimension: mm 2. Leads must be free of flash and plating voids 3. Lead thickness after solder plating will be 0.254mm maximum 4. PINOUT: Pin No. Pin Name Function 1 VDD Power Supply 2 GND Ground 3 SPD 4 VOUT Output 5. (For reference only)Land Pattern SN Package (SOT-553) (Top View) Hall Plate Chip Location (Top View) 0.80 5 4 0.60 1 2. 082118 3 Hall Sensor Location NOTES: 1. 2 PINOUT (See Top View at left:) Pin 1 NC Pin 2 GND Pin 3 NC Pin 4 VDD Pin 5 Out Controlling dimension: mm; Page 8 of 17 Rev. 1.07 MH254 Micro-power CMOS Unipolar Hall Effect Switch SQ Package (QFN2020-3) Hall Plate Chip Location (Top view) 1 NOTES: 3. PINOUT (See Top View at left) Pin 1 VDD Pin 2 Output 1 Pin 3 GND 4. Controlling dimension: mm; 5. Chip rubbing will be 10mil Hall Sensor Location maximum; 6. Chip must be in PKG. center. UA Package (TO-92S) 3 1 2 Hall Chip location 2.00 0.9 Hall Sensor Location Mark Output Pin Assignment NOTES: (Top view) 1).Controlling dimension: mm 2).Leads must be free of flash and plating voids 3).Do not bend leads within 1 mm of lead to package interface. 4).PINOUT: 082118 Pin 1 VDD Pin 2 GND Pin 3 Output Page 9 of 17 Rev. 1.07 MH254 Micro-power CMOS Unipolar Hall Effect Switch MH254 UA(TO-92S) Package Date Code XXX Year Week EX:2018 Year_8 Week →808 MH 254EST/ESN/ESQ Package Date Code XX Week Code week 1 2 3 4 5 6 7 8 9 10 11 12 13 code AA AB AC AD AE AF AG AH AI AJ AK AL AM week 14 15 16 17 18 19 20 21 22 23 24 25 26 code AN AO AP AQ AR AS AT AU AV AW AX AY AZ week 27 28 29 30 31 32 33 34 35 36 37 38 39 code BA BB BC BD BE BF BG BH BI BJ BK BL BM week 40 41 42 43 44 45 46 47 48 49 50 51 52 BP BQ BR code BN BO EX:2018 Year_8 Week → AH BS BT BU BV BW BX BY BZ 082118 Page 10 of 17 Rev. 1.07 MH254 Micro-power CMOS Unipolar Hall Effect Switch TSOT- 23 package Tape On Reel Dimension NOTES: 1. Material: Conductive polystyrene; 2. DIM in mm; 3. 10 sprocket hole pitch cumulative tolerance ±0.2; 4. Camber not to exceed 1mm in 100mm; 5. Pocket position relative to sprocket hole measured as true position of pocket, not pocket hole; 6. (S.R. OHM/SQ) Means surface electric resistivity of the carrier tape. 082118 Page 11 of 17 Rev. 1.07 MH254 Micro-power CMOS Unipolar Hall Effect Switch SOT-553 Tape On Reel Dimension NOTES: 1. Material: Conductive polystyrene; 2. DIM in mm; 3. 10 sprocket hole pitch cumulative tolerance ±0.2; 4. Camber not to exceed 1mm in 100mm; 5. Pocket position relative to sprocket hole measured as true position of pocket, not pocket hole; 6. (S.R. OHM/SQ) Means surface electric resistivity of the carrier tape. 082118 Page 12 of 17 Rev. 1.07 MH254 Micro-power CMOS Unipolar Hall Effect Switch QFN2020-3 Tape On Reel Dimension NOTES: 1. 2. 3. 4. 5. 6. 082118 Page 13 of 17 Material: Conductive polystyrene; DIM in mm; 10 sprocket hole pitch cumulative tolerance ±0.2; Camber not to exceed 1mm in 100mm; Pocket position relative to sprocket hole measured as true position of pocket, not pocket hole; (S.R. OHM/SQ) Means surface electric resistivity of the carrier tape. Rev. 1.07 MH254 Micro-power CMOS Unipolar Hall Effect Switch SS (DFN 1.0x1.0-4) Tape On Reel Dimension NOTES: 10 sprocket hole pitch cumulative tolerance is ±0.1mm; Pocket position relative to sprocket hole measured as true position of pocket, not pocket hole; 9. Ao & Bo measured on a place 0.3mm above the bottom of the pocket to top surface of the carrier. 10. Ko measured from a plane on the inside bottom of the pocket to the top surface of the carrier. 11. Carrier camber shall be not than 1mm per 100mm through a length of 250m. 7. 8. 082118 Page 14 of 17 Rev. 1.07 MH254 Micro-power CMOS Unipolar Hall Effect Switch IR reflow curve ST/SN/SS/SQ Soldering Condition 082118 Page 15 of 17 Rev. 1.07 MH254 Micro-power CMOS Unipolar Hall Effect Switch UA Soldering Condition Packing specification: Package Bag Box Carton TSOT-23(ST) 3,000pcs/reel 10 reel/box 2 box/carton SOT-553(SN) 3,000pcs/reel 10 reel/box 2 box/carton TO-92S-3L(UA) 1,000pcs/bag 10bag/box 10 box/carton QFN2020-3(SQ) 3,000pcs/reel 10 reel/box 2 box/carton SS(DFN1.0x1.0) 8,000pcs/reel 5reel/box 12 box/carton TSOT-23-3L Weight SOT-553(SN) Weight TO-92S-3L(UA) Weight 3000pcs/reel 0.18kg 3000pcs/reel 0.13kg 1000pcs/bag 0.11kg 10 reels/box 1.99kg 10 reels/box 1.40kg 10bags/box 1.24kg 2 boxes/carton 4.9kg 2 boxes/carton 3.70kg 10 boxes/carton 12.57kg 082118 QFN2020-3(SQ) Weight SS(DFN1.0x1.0) Weight 3000pcs/reel 0.13kg 8,000pcs/reel 0.11kg 10 reels/box 1.40kg 5 reels/box 0.66kg 2 boxes/carton 3.70kg 12boxes/carton 8.72kg Page 16 of 17 Rev. 1.07 MH254 Micro-power CMOS Unipolar Hall Effect Switch ST/SN/SQ/SS Package Inner box label:Size:3.4cm*6.4cm Bag and inner box Halogen Free Label ST/SN/SQ/SS Carton label:Size:5.6cm* 9.8cm Bag and inner box Halogen Free Label UA Package Inner box label:Size:3.4cm*6.4cm Bag and inner box Halogen Free Label UA Carton label:Size:5.6cm* 9.8cm Bag and inner box Halogen Free Label Combine: When combine lot, one reel could have two D/C and no more than two DC. One carton could have two devices, no more than two; 082118 Page 17 of 17 Rev. 1.07
