AW13412DNR
AW13412DNR
    AWINIC(艾为)
    DFN6_0.7x1.1mm
    停产 0.1-3GHZSP2T射频开关
AW13412DNR 数据手册
AW13412 Nov 2017 V1.1 0.1-3GHz SP2T Switch for 3G/4G TRX FEATURES GENERAL DESCRIPTION  Broadband frequency range: 0.1 to 3.0 GHz  Low insertion loss: 0.35dB typical @ 2.7 GHz  High isolation: >23dB @ 2.7 GHz  Integrated logic The AW13412 is a SP2T switch with low insertion loss and high Isolation. It can be used to support band switching and mode switching for cellular 3G/4G, data cards and tablets.  Small DFN (6-pin, 1.1mm x 0.7 mm) package (MSL1, 260 °C per JEDEC J-STD-020) The symmetrical design of internal ports makes it convenient for PCB routing and adjustment of receiving and transmitting signals. The band/mode switching is realized by the GPIO pins as referenced in the chip block diagram and the control logic. APPLICATIONS  Cellular 3G/4G TRX  Cellular modems , tablets and USB Devices  Other RF front-end modules The AW13412 is provided in a compact 1.1mm x 0.7mm, 6-pin DFN package. TYPICAL APPLICATION CIRCUIT ANT 5 AW13412 RF1 1 3 4 1nF VDD Figure 1 RF2 6 100pF V1 Typical Application Circuit of AW13412 All trademarks are the property of their respective owners. www.awinic.com.cn 1 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW13412 Nov 2017 V1.1 PIN CONFIGURATION AND TOP MARK Figure 2 Pin Configuration and Top Mark PIN DEFINITION No. NAME 1 RF2 RF I/O path 2 2 GND Ground 3 RF1 RF I/O path 1 4 VDD DC power supply 5 ANT Antenna port 6 V1 www.awinic.com.cn DESCRIPTION DC control voltage 1 2 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW13412 Nov 2017 V1.1 FUNCTIONAL BLOCK DIAGRAM RF1 ANT RF2 Controller and Decoder VDD Figure 3 V1 GND FUNCTIONAL BLOCK DIAGRAM ORDERING INFORMATION Part Number Temperature Package Marking Moisture Sensitivity Level Environmental Information Delivery Form AW13412DN R -40°C~85°C DFN 1.1mm*0.7 mm-6L DX MSL1 ROHS+HF 3000 units/ Tape and AW13412 Reel Shipping R:Tape & Reel Package Type DN:DFN www.awinic.com.cn 3 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW13412 Nov 2017 V1.1 ABSOLUTE MAXIMUM RATINGS(NOTE1) PARAMETERS RANGE Supply Voltage Range VDD 2.4V to 3.3V Control Voltage Range V1 0V to 3V RF input power(RF1/RF2) 34dBm Operating Free-air Temperature Range -40°C to 85°C Storage Temperature TSTG -55°C to 150°C Lead Temperature (Soldering 10 Seconds) 260°C ESD (NOTE 2) HBM ±1000V CDM ±500V NOTE1: Conditions out of those ranges listed in "absolute maximum ratings" may cause permanent damages to the device. In spite of the limits above, functional operation conditions of the device should within the ranges listed in "recommended operating conditions". Exposure to absolute-maximum-rated conditions for prolonged periods may affect device reliability. NOTE2: The human body model is a 100pF capacitor discharged through a 1.5kΩ resistor into each pin. Test method: MIL-STD-883J Method 3015.9 ELECTRICAL CHARACTERISTICS VDD=2.8V, V1=0/1.8V, PIN=0dBm, TOP=+25℃, Z0=50Ω. (unless otherwise noted) PARAMETER TEST CONDITION MIN TYP MAX UNIT 2.4 2.8 3 V DC Specifications VDD Supply Voltage IDD Supply Current A 45 Control Voltage VCTL_H VCTL_L ICTL tON High 1.35 Low 0 Control Current Turn-on Switching Time 1.8 3 V 0.45 VCTL = 1.8V 0.1 1 A 50% of final control voltage to 90% of final RF power, switching between RF1/2 0.5 1 S 0.1-1.0G 1.0-2.0G 2.0-2.7G 0.1-1.0G 1.0-2.0G 2.0-2.7G 0.30 0.45 0.35 35 30 25 0.40 0.55 0.45 dB dB dB dB dB dB RF Specifications IL ISO Insertion loss(ANT pin to RF1/RF2) Isolation (ANT pin to RF1/RF2) www.awinic.com.cn 4 33 27 23 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW13412 Nov 2017 V1.1 PARAMETER TEST CONDITION Second harmonics (ANT pin to RF1/RF2) 2fo P0.1dB MAX UNIT 27 22 20 dB dB dB 85 dBc 88 dBc 0.1GHz–3GHz 34 dBm @ 2.0GHz, PIN=+26dBm, 57 dBm PIN=+26dBm, 0.1-3GHz 0.1dB Compression Point (ANT pin to RF1/RF2) 3rd Order Input Intercept Point IIP3 23 20 18 0.1-3GHz Third harmonics (ANT pin to RF1/RF2) 3fo TYP 0.1-1.0G 1.0-2.0G 2.0-2.7G PIN=+26dBm, Input return loss (ANT pin to RF1/RF2) RL MIN Δf=1MHz TIMING DIAGRAM (POWER ON AND OFF SEQUENCE) It is very important that the user adheres to the correct power-on/off sequence in order to avoid damaging the device. The control signal V1 should be set to 0V unless VDD is set in the operating voltage range. Power ON: 1) Apply voltage supply --- VDD 2) Set Controls---V1 3) Apply RF input Change switch position from one RF port to another: 1) Remove RF input 2) Change control voltages V1 to set the switch to desired RF port 3) Apply RF input Power OFF: 1) Remove RF input 2) Remove control voltages-V1 3) Remove VDD input Power on Change switch Power Off VDD V1 RF_IN Figure 4 www.awinic.com.cn Power on/Change switch/Power off sequence 5 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW13412 Nov 2017 V1.1 AW13412 CONTROL LOGIC State Active Path V1 0 1 ANT to RF1 ANT to RF2 0 1 APPLICATION CIRCUITS ANT 5 AW13412 RF1 1 3 4 1nF VDD RF2 6 100pF VCTL Figure 5 AW13412 EVB Schematic Figure 6 AW13412 EVB www.awinic.com.cn 6 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW13412 Nov 2017 V1.1 PACKAGE OUTLINE DIMENSIONS Figure 7 Package Outline AW13412 OUTLINE DIMENSIONS www.awinic.com.cn 7 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW13412 Nov 2017 V1.1 LAND PATTERN DATA TAPE AND REEL INFORMATION Pin 1 User Direction of Feed Figure 8-1 www.awinic.com.cn 8 Tape and Reel Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW13412 Nov 2017 V1.1 Figure 8-2 www.awinic.com.cn 9 Tape and Reel Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW13412 Nov 2017 V1.1 REFLOW Reflow Note Spec Average ramp-up rate (217°C to peak) Max. 3°C /sec Time of Preheat temp. (from 150°C to 200°C) 60-120sec Time to be maintained above 217°C 60-150sec Peak Temperature >260°C Time within 5°C of actual peak temp 20-40sec Ramp-down rate Max. 6°C /sec Time from 25°C to peak temp Max. 8min Figure 9 Package Reflow Standard Profile NOTE 1: All data are compared with the package-top temperature, measured on the package surface; NOTE 2: AW13412 adopted the Pb-Free assembly. www.awinic.com.cn 10 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW13412 Nov 2017 V1.1 REVISION HISTORY Vision Date Change Record V1.0 Aug 2017 Officially Released V1.1 Nov 2017 Change datasheet template www.awinic.com.cn 11 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW13412 Nov 2017 V1.1 DISCLAIMER Information in this document is believed to be accurate and reliable. However, Shanghai AWINIC Technology Co., Ltd (AWINIC Technology) does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. AWINIC Technology reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. Customers shall obtain the latest relevant information before placing orders and shall verify that such information is current and complete. This document supersedes and replaces all information supplied prior to the publication hereof. AWINIC Technology products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an AWINIC Technology product can reasonably be expected to result in personal injury, death or severe property or environmental damage. AWINIC Technology accepts no liability for inclusion and/or use of AWINIC Technology products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications that are described herein for any of these products are for illustrative purposes only. AWINIC Technology makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. All products are sold subject to the general terms and conditions of commercial sale supplied at the time of order acknowledgement. Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Reproduction of AWINIC information in AWINIC data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. AWINIC is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. Resale of AWINIC components or services with statements different from or beyond the parameters stated by AWINIC for that component or service voids all express and any implied warranties for the associated AWINIC component or service and is an unfair and deceptive business practice. AWINIC is not responsible or liable for any such statements. www.awinic.com.cn 12 Copyright © 2017 SHANGHAI AWINIC TECHNOLOGY CO., LTD
AW13412DNR 价格&库存
很抱歉,暂时无法提供与“AW13412DNR”相匹配的价格&库存,您可以联系我们找货
