MXD8721
0.5-6.0GHz SPDT Switch
VED
APPRO
This document contains information that is confidential and proprietary to Maxscend Microelectronics
Company Limited (Maxscend) and may not be reproduced in any form without express written consent of
Maxscend. No transfer or licensing of technology is implied by this document.
Page 1 of 8
Maxscend Microelectronics Company Limited. All rights reserved.
Maxscend Confidential
MXD8721 – 0.5-6.0GHz SPDT Switch
General Description
The MXD8721 is a CMOS silicon-on-insulator
(SOI), single-pole, double-throw (SPDT) switch.
The high linearity and ruggedness performance
and extremely low insertion loss makes the device
Applications
WLAN 802.11 a/b/g/n networks
WLAN repeaters
ISM band radios
Low power transmit receive systems
an ideal choice for WLAN applications such as
802.11 a/b/g/n.
Features
The MXD8721 SPDT switch is provided in a
Broadband frequency range: 0.5 to 6.0 GHz
compact 1.0mm x 1.0mm x 0.45mm 6-lead QFN
Low insertion 0.35dB @ 2.45 GHz
package. A functional block diagram is shown in
Low insertion 0.55dB @ 5.8 GHz
Figure 1. The pin configuration and package are
High P0.1dB of 32dBm
shown in Figure 2. Signal pin assignments and
Small, QFN (6-pin, 1.0mm x 1.0mm x
functional pin descriptions are provided in Table 1.
0.45mm) package,MSL1
Functional Block Diagram and Pin Function
Figure 1.Functional Block Diagram
Figure 2.Pin-out (Top View)
Page 2 of 8
Application Circuit
1
V1
6
GND
ANT
5
RF2
V2
4
RF1
V1
RF1
2
3
C1
33pF
ANT
V2
RF2
C2
33pF
Figure 3. MXD8721 Application Circuit
Table 1. Pin Description
Pin No.
1
2
3
Name
RF1
GND
RF2
Description
Pin No.
RF port 1
Ground
RF port 2
4
5
6
Name
V2
ANT
V1
Description
DC control and supply voltage
Antenna port
Truth Table
Table 2.
Active Path
V1
V2
ANT to RF1
ANT to RF2
1
Note: “1” = 3.0V to 3.6 V. “0” = –0 V to +0.3 V.
Recommended Operation Range
Table 3.
Parameters
Operation Frequency
Switch Control Voltage High
Switch Control Voltage Low
Symbol
Min
Typ
Max
f1
0.5
3.0
3.6
0.3
VCTL_H
VCTL_L
Units
GHz
V
V
Page 3 of 8
Specifications
Table 4.Electrical Specifications
Parameter
DC Specifications
Control voltage:
Low
High
Control current
Symbol
VCTL_L
VCTL_H
ICTL
Specification
Min.
Typical
Max.
Units
Test Condition
35
0.3
3.6
80
V
V
μA
VCTL = 3.3 V
0.35
0.55
32
30
25
0.75
dB
dB
dB
dB
dB
dB
0.5 to 3.0 GHz
3.0 to 6.0 GHz
0.5 to 3.0 GHz
3.0 to 6.0 GHz
0.5 to 3.0 GHz
3.0 to 6.0 GHz
RF Specifications
Insertion loss
IL
Isolation
ISO
Return loss
|S11|
Input 0.1 dB
compression
point
Switching on
time
Switching off
time
30
25
P0.1dB
+32
dBm
0.8 to 6.0 GHz,
ANT to RF1 and RF2
200
ns
50% VCTL to 90% RF
200
ns
50% VCTL to 10% RF
Absolute Maximum Ratings
Table 5. Maximum ratings
Parameters
Control voltage
RF input power
Operating temperature
Storage temperature
Electrostatic Discharge
Human body model
(HBM), Class 1C
Machine Model (MM),
Class A
Charged device model
(CDM), Class III
Symbol
Minimum
Maximum
Units
VCTL
PIN
TOP
TSTG
-0.3
+4.5
+32.5
+90
+150
V
dBm
–35
–55
ESD_HBM
1000
ESD_MM
100
ESD_CDM
500
V
Note: Exposure to maximum rating conditions for extended periods may reduce device reliability. There is no damage to device with
only one parameter set at the limit and all other parameters set at or below their nominal value. Exceeding any of the limits listed
here may result in permanent damage to the device.
Page 4 of 8
Package Outline Dimension
Figure 4. Package outline dimension
Page 5 of 8
Marking Specification
Pin 1 Point
st
1 letter (Fixed):
Product Code.
K,Y
last letter(Variable):
Lot code
From 1~9 and A ~Z excluding letter
"I" and "O" for each letter
Figure 5. Marking specification (Top View)
Page 6 of 8
Tape and Reel Dimensions
Figure 6. Tape and reel dimensions
Page 7 of 8
Reflow Chart
tP
TP
Critical Zone
TL to TP
Ramp-up
Temperature
TL
TSmax
tL
TSmin
Ramp-down
tS
Preheat
t 25 ℃ to Peak
Time
Figure 7. Recommended Lead-Free Reflow Profile
Table 6.
Profile Parameter
Lead-Free Assembly, Convection, IR/Convection
Ramp-up rate(TSmax to Tp)
3℃/second max.
Preheat temperature(TSmin to TSmax)
150℃ to 200℃
Preheat time(ts)
60 - 180 seconds
Time above TL , 217℃(tL)
60 - 150 seconds
Peak temperature(Tp)
260℃
Time within 5℃ of peak temperature(tp)
20 - 40 seconds
Ramp-down rate
6℃/second max.
Time 25℃ to peak temperature
8 minutes max.
ESD Sensitivity
Integrated circuits are ESD sensitive and can be damaged by static electric charge. Proper ESD
protection techniques should be used when handling these devices.
RoHS Compliant
This product does not contain lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls
(PBB) and polybrominated diphenyl ethers (PBDE), and are considered RoHS compliant.
Page 8 of 8
很抱歉,暂时无法提供与“MXD8721”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.07957
- 50+0.86184
- 150+0.76853
- 500+0.65211
