MXD85A0F
MXD85A0F
    MAXSCEND(卓胜微电子)
    QFN20_2.4X2.4MM_EP
    多频段SP10T射频开关
MXD85A0F 数据手册
MXD85A0F SP10T TRX Switch with MIPI VED APPRO This document contains information that is confidential and proprietary to Maxscend Microelectronics Company Limited (Maxscend) and may not be reproduced in any form without express written consent of Maxscend. No transfer or licensing of technology is implied by this document. Page 1 of 10 Maxscend Microelectronics Company Limited, All rights reserved. Maxscend Confidential MXD85A0F – SP10T TRX Switch with MIPI General Description Features The MXD85A0F is a low loss, high isolation  Excellent insertion loss - 0.75 dB Insertion Loss at 2.7GHz SP10T switch for antenna TRX application. The MXD85A0F is compatible with MIPI control,  P0.1dB @ 35dBm which is a key requirement for many cellular  Multi-Band operation 400MHz to 3000MHz  RFFE serial control interface  Compact 2.4mm x 2.4mm in QFN-20 transceivers. This part is packaged in a compact 2.4mm x 2.4mm, 20-pin, QFN package which package allows for a small solution size with no need for external DC blocking capacitors (when no external  No DC blocking capacitors required (unless external DC is applied to the RF ports) DC is applied to the device ports). Applications  2G/3G/4G antenna diversity  Cellular modems and USB Devices Functional Block Diagram and Pin Function RF1 RF2 RF3 RF4 RF5 ANT RF6 RF7 Ground Paddle RF8 RF9 RF10 VIO VDD SCLK SDATA Figure 1 Functional Block Diagram and Pinout (Top View) Page 2 of 10 Maxscend Microelectronics Company Limited, All rights reserved. Maxscend Confidential MXD85A0F – SP10T TRX Switch with MIPI 16 RF5 RF5 RF4 RF4 RF3 RF3 RF2 RF2 19 8 GND 20 7 GND 1 2 RF10 3 4 5 6 RF6 C4 DN1 ANT ANT RF6 C3 DN1 GND 9 Ground Paddle RF7 C2 33nF 11 10 18 NC C1 100pF 17 RF7 SCLK 12 RF8 SDATA 13 RF8 VIO 14 RF9 VDD 15 RF9 SDATA SCLK RF1 VIO RF10 VDD GND RF1 Application Circuit Figure 2 Evaluation Board Schematic Table 1. Pin Description Pin No. 1 2 3 4 5 6 7 8 9 10 Ground Paddle Name NC RF10 RF9 RF8 RF7 RF6 GND GND ANT GND Description Not Connect RF port10 RF port9 RF port8 RF port7 RF port6 Ground Ground Antenna port Ground GND Ground Pin No. 11 12 13 14 15 16 17 18 19 20 Name RF5 RF4 RF3 RF2 RF1 GND VDD VIO SDATA SCLK Description RF port5 RF port4 RF port3 RF port2 RF port1 Ground Power supply Supply voltage for MIPI MIPI data input/output MIPI clock Note: Bottom ground paddles must be connected to ground. Page 3 of 10 Maxscend Microelectronics Company Limited, All rights reserved. Maxscend Confidential MXD85A0F – SP10T TRX Switch with MIPI Truth Table Table 2. State Mode 1 2 3 4 5 6 7 8 9 10 11 ISO RF1 on RF2 on RF3 on RF4 on RF5 on RF6 on RF7 on RF8 on RF9 on RF10 on Register_0 D7 x x x x x x x x x x x D6 0 0 0 0 0 0 0 0 0 0 0 D5 0 0 0 0 0 0 0 0 0 0 0 D4 0 0 0 0 0 0 0 0 0 0 0 D3 0 0 1 1 1 0 1 0 0 1 1 D2 0 0 0 1 0 0 0 1 1 1 0 D1 0 1 1 1 1 0 0 1 0 0 0 D0 0 0 0 0 1 1 1 0 0 0 0 Symbol Min Typ Max Units f1 VDD VIO VH VL 0.7 2.5 1.65 0.8*VIO 0 2.8 1.8 1.8 0 3.0 3.0 1.95 1.95 0.3 GHz V V V V Min Typical Max Units 2.5 2.8 3.0 V 55 80 uA 1.65 1.8 1.95 V 0.8* VIO 0 10% to 90% RF 4 VIO 0 1 10 1.95 0.3 2 uA V V uS 0.1 to 1.0 GHz 1.0 to 2.0 GHz 2.0 to 2.7 GHz 0.1 to 1.0 GHz 1.0 to 2.0 GHz 2.0 to 2.7 GHz 0.1 to 1.0 GHz 1.0 to 2.0 GHz 2.0 to 2.7 GHz 0.50 0.65 0.75 40 30 20 25 20 15 dB dB dB dB dB dB dB dB dB +35 dBm Recommended Operation Range Table 3. Recommended Operation Condition Parameters Operation Frequency Power supply Power supply for MIPI MIPI Control Voltage High MIPI Control Voltage Low Specifications Table 4. Electrical Specifications Parameter Symbol Test Condition DC Specifications Supply voltage VDD Supply current IDD VIO supply voltage VIO VIO Supply current SDATA, SCLK control voltage: High Low Switching Speed, one RF to another IIO VCTL_H VCTL_L RF Specifications Insertion loss (ANT pin to RF1/2/3/4/5/6/7/8/9/10 pins) IL Isolation (ANT pin to RF1/2/3/4/5/6/7/8/9/10 pins) Iso Input return loss (ANT pin to RF1/2/3/4/5/6/7/8/9/10 pins) RL 0.1 dB Compression Point (ANT pin to RF1/2/3/4/5/6/7/8/9/10 pins) P0.1dB 35 25 18 20 15 12 0.7 GHz to 3.0 GHz Page 4 of 10 Maxscend Microelectronics Company Limited, All rights reserved. Maxscend Confidential MXD85A0F – SP10T TRX Switch with MIPI MIPI Read and Write Timing MIPI supports the following Command Sequences: • Register Write • Register_0 Write • Register Read Figures 3 and 4 provide the timing diagrams for register write commands and read commands, respectively. Figure 5 shows the Register 0 Write Command Sequence. Refer to the MIPI Alliance Specification for RF Front-End Control Interface (RFFE), v1.10 (26 July 2011) for additional information on MIPI USID programming sequences and MIPI bus specifications. CLK SA3 Data SA2 SA1 SA0 0 SSC 1 0 A4 A3 A2 A1 A0 P A0 P Register Write Command Frame CLK Data P D7 D6 D5 D4 D3 D2 D1 D0 P 0 Bus Park Data Frame Signal driven by Master Signal not driven, pull down only For reference only Figure 3 Register Write Command Sequence CLK SA3 Data SA2 SA1 SA0 0 SSC 1 1 A4 A3 A2 A1 Register Read Command Frame CLK Data P 0 Bus Park D7 D6 D5 D4 D3 D2 Data Frame (from Slave) D1 D0 P 0 Bus Park Signal driven by Master Signal driven by Slave Signal not driven, pull down only by Master For reference only Figure 4 Register Read Command Sequence Page 5 of 10 Maxscend Microelectronics Company Limited, All rights reserved. Maxscend Confidential MXD85A0F – SP10T TRX Switch with MIPI In the timing figures, SA[3:0] is slave address. A[4:0] is register address. D[7:0] is data. “P” is odd parity bit. Register 0 Write Command Sequence Figure shows the Register 0 Write Command Sequence. The Command Sequence starts with an SSC, followed by the Register 0 Write Command Frame containing the Slave address, a logic one, and a seven bit word to be written to Register 0. The Command Sequence ends with a Bus Park Cycle. CLK SA3 Data SSC SA2 SA1 SA0 1 D6 D5 Slave Address D4 D3 Data D2 D1 D0 P 0 Parity Bus Park Signal driven by Master Signal not driven, pull down only For reference only Figure 5 Register 0 Write Command Sequence Page 6 of 10 Maxscend Microelectronics Company Limited, All rights reserved. Maxscend Confidential MXD85A0F – SP10T TRX Switch with MIPI Register definition Table 5. Register definition table Register Address Register Name Data Bits R/W Function Description Default BROADC AST_ID support Trigger support 0x00 REGISTER_0 7:0 R/W RF Control Register_0 truth Table: Table 2 0x00 No Yes 0x001B GROUP_SID 7:4 R RESERVED 0x0 No No 3:0 R/W GSID Group Slave ID 0x0 No No 0b10 Yes No 0x001C PM_TRIG 0x001D PRODUCT_ID 0x001E MANUFACTU RER_ID 0x001F MAN_USID 7:6 R/W PWR_MODE 00: Normal Operation (ACTIVE) 01: Reset all registers to default settings (STARTUP) 10: Low power (LOW POWER) 11: Reserved Note: Write PWR_MODE=2’h1 will reset all register, and puts the device into STARTUP state. 5 R/W Trigger_Mask_2 If this bit is set, trigger 2 is disabled 0 No No 4 R/W Trigger_Mask_1 If this bit is set, trigger 1 is disabled 0 No No 0 No No 3 R/W Trigger_Mask_0 If this bit is set, trigger 0 is disabled Note: When all triggers are disabled, writing to a register that is associated with trigger 0, 1, or 2, causes the data to go directly to the destination register. 2 W Trigger_2 A write of a one to this bit loads trigger 2's registers 0 Yes No 1 W Trigger_1 A write of a one to this bit loads trigger 1's registers 0 Yes No 0 Yes No 0 W Trigger_0 A write of a one to this bit loads trigger 0's registers Note: Trigger processed immediately then cleared. Trigger 0, 1, and 2 will always read as 0. 7:0 R PRODUCT_ID Product Number 0x01 No No 7:0 R MANUFACTUR ER_ID[7:0] Lower eight bits of MIPI registered Manufacturer ID 0x81 No No 7:6 R RESERVED 0b00 No No 5:4 R MANUFACTUR ER_ID[9:8] Upper two bits of MIPI registered Manufacturer ID 0b11 No No 3:0 R/W USID USID of the device. 0xa No No Page 7 of 10 Maxscend Microelectronics Company Limited, All rights reserved. Maxscend Confidential MXD85A0F – SP10T TRX Switch with MIPI Absolute Maximum Ratings Table 6. Maximum ratings Parameters Symbol Minimum Maximum Units Supply voltage Supply voltage for MIPI MIPI Control voltage (SDATA, SCLK) RF input power (RF1/2/3/4/5/6/7/8/9/10) Operating temperature Storage temperature Electrostatic Discharge Human body model (HBM), Class 1C Machine Model (MM), Class A Charged device model (CDM), Class III VDD VIO +2.0 +1.0 +3.3 +2.0 V V VCTL 0 +2.0 V +36 dBm +85 +125 ℃ ℃ PIN –20 –40 TOP TSTG ESD_HBM 1000 ESD_MM 100 ESD_CDM 500 V Note: Exposure to maximum rating conditions for extended periods may reduce device reliability. There is no damage to device with only one parameter set at the limit and all other parameters set at or below their nominal value. Exceeding any of the limits listed here may result in permanent damage to the device Power ON and OFF sequence Here is the recommendation about power-on/off sequence in order to avoid damaging the device. Power ON 1) Apply voltage supply - VDD 2) Apply logic supply - VIO 3) Wait 10μs or greater and then apply MIPI bus signals – SCLK and SDATA 4) Wait 5μs or greater after MIPI bus goes idle and then apply the RF Signal Power OFF 1) Remove the RF Signal 2) Remove MIPI bus – SCLK and SDATA 3) Remove logic supply - VIO 4) Remove voltage supply - VDD VDD ON VDD VIO ON MIPI RF Trigger ON RF OFF ≥100us VIO OFF VDD OFF ≥100us VIO Slave State SDATA,SCLK SHUTDOWN STARTUP ≥10us ACTIVE SHUTDOWN ≥5us RF Signal Note: VIO can be applied to the device before VDD or removed after VDD. It is important to wait 10μs after VIO & VDD are applied before sending SDATA to ensure correction data transmission. The minimum time between a power up and power down sequence (and vice versa) is ≥ 100us. Page 8 of 10 Maxscend Microelectronics Company Limited, All rights reserved. Maxscend Confidential MXD85A0F – SP10T TRX Switch with MIPI Package Outline Dimension Figure 6 package outline dimension Page 9 of 10 Maxscend Microelectronics Company Limited, All rights reserved. Maxscend Confidential MXD85A0F – SP10T TRX Switch with MIPI Reflow Chart tP TP Critical Zone TL to TP Ramp-up Temperature TL TSmax tL TSmin Ramp-down tS Preheat t 25 ℃ to Peak Time Figure 7 Recommended Lead-Free Reflow Profile Table 7. Reflow condition Profile Parameter Ramp-up rate(TSmax to Tp) Preheat temperature(TSmin to TSmax) Preheat time(ts) Time above TL , 217℃(tL) Peak temperature(Tp) Time within 5℃ of peak temperature(tp) Ramp-down rate Time 25℃ to peak temperature Lead-Free Assembly, Convection, IR/Convection 3℃/second max. 150℃ to 200℃ 60 - 180 seconds 60 - 150 seconds 260℃ 20 - 40 seconds 6℃/second max. 8 minutes max. ESD Sensitivity Integrated circuits are ESD sensitive and can be damaged by static electric charge. Proper ESD protection techniques should be used when handling these devices. RoHS Compliant This product does not contain lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) and polybrominated diphenyl ethers (PBDE), and are considered RoHS compliant. 1.0.1 Page 10 of 10 Maxscend Microelectronics Company Limited, All rights reserved. Maxscend Confidential
MXD85A0F 价格&库存
很抱歉,暂时无法提供与“MXD85A0F”相匹配的价格&库存,您可以联系我们找货
