MXD8533B
MXD8533B
    MAXSCEND(卓胜微电子)
    LGA11_1.7X1.8MM
    0.4~3.8GHZ3XSPST天线调谐开关
MXD8533B 数据手册
MXD8533B VED APPRO 0.4~3.8GHz 3xSPST Antenna Tuning Switch Description Features The MXD8533B is a CMOS silicon-on-insulator (SOI), three  Broadband frequency range: 0.4 to 3.8 GHz single-pole, single-throw (3xSPST) switch. The high linearity  Input 0.1dB Compression Point: 48dBm  RFFE serial control interface handset antenna tuning application.  No DC blocking capacitors required The MXD8533B 3xSPST switch is provided in a compact  Ultra small package, LGA 11-pin (1.75mm x 1.66mm x and ruggedness performance and extremely low RON and COFF makes the device an ideal choice for GSM/WCDMA/LTE 1.75mm x 1.66mm x 0.37mm package. A functional block 0.37mm), MSL1 diagram, the pin configuration and package are shown in Figure 1. Signal pin assignments and functional pin descriptions are provided in Table 1. Applications  GSM/WCDMA/LTE band and mode switching  Antenna tuning switching RF1 RF2 RF3 1 2 3 4 RF2 5 RF3 A RF1 B GNDA USID GNDF GNDF C VDD VIO SCL SDA Decoder VIO VDD SCL SDA USID Figure 1 Functional Block Diagram Page 1 / 13 MXD8533B Rev1.5 This document contains information that is confidential and proprietary to Maxscend Microelectronics Company, Ltd. (Maxscend) and may not be reproduced in any form without express written consent of Maxscend. No transfer or licensing of technology is implied by this document. Function Characteristics 0.4~3.8GHz 3xSPST Antenna Tuning Switch Function Characteristics RF2 RF1 1 RF2 2 3 A RF1 4 RF2 RF1 RF3 5 RF3 RF3 USID Grounded Floating Tied to VIO B GNDA USID GNDF GNDF VDD VIO SCL SDA C VDD SDA DNI 100pF VIO SCL 33nF DNI Figure 2 Application Circuit Table 1 Pin Descriptions NO. Name Description NO. Name Description A1 RF1 RF Port1 B5 GNDF RF Ground A3 RF2 RF Port2 C1 VDD DC Supply Voltage A5 RF3 RF Port3 C2 VIO Supply Voltage for MIPI B1 GNDA Analog Ground C4 SCL MIPI Clock B2 USID Unique Salve ID C5 SDA MIPI Data Input/output B4 GNDF RF Ground Table 2 Register_0[7:0] (MIPI Data) for RF Operating Mode State Mode Register_0 D7 D6 D5 D4 D3 D2 D1 D0 1 All On 0 0 0 0 0 1 1 1 2 RF1 On 0 0 0 0 0 1 0 0 3 RF2 On 0 0 0 0 0 0 1 0 4 RF3 On 0 0 0 0 0 0 0 1 5 RF1+RF2 On 0 0 0 0 0 1 1 0 6 RF1+RF3 On 0 0 0 0 0 1 0 1 7 RF2+RF3 0 0 0 0 0 0 1 1 8 All Off 0 0 0 0 0 0 0 0 Page 2 / 13 MXD8533B: Rev1.5 Copyright @2018 Maxscend Microelectronics Company, Ltd. All rights reserved. Maxscend Confidential Electrical Characteristics 0.4~3.8GHz 3xSPST Antenna Tuning Switch Electrical Characteristics Table 3 Absolute Maximum Ratings Parameter Symbol Min Max DC Supply Voltage VDD -0.3 3.6 Supply Voltage for MIPI VIO -0.3 +2.5 MIPI Control Voltage(SDA, SCL) VI -0.3 +2.5 RF Input Peak Power(VSWR 1:1,20% DC) PIN Device Operating Temperature TOP -40 +90 Device Storage Temperature TSTG -55 +150 Human Body Model (HBM), Class 1C VESD(HBM) 1000 Charged Device Model (CDM), Class III VESD(CDM) 500 +48.5 Unit V dBm ℃ Electrostatic Discharge V Notice Exposure to maximum rating conditions for extended periods may reduce device reliability. There is no damage to device with only one parameter set at the limit and all other parameters set at or below their nominal value. Exceeding any of the limits listed here may result in permanent damage to the device. Table 4 Recommended Operating Conditions Parameter Symbol MIN F0 0.4 DC Supply Voltage VDD 1.7 2.8 3.3 Power Supply for MIPI VIO 1.62 1.8 1.98 MIPI Control Voltage(SDA, SCL) High VIH 0.8*VIO VIO VIO MIPI Control Voltage(SDA, SCL) Low VIL 0 0 0.3 Operating Frequency TYP MAX Unit 3.8 GHz V Page 3 / 13 MXD8533B: Rev1.5 Copyright @2018 Maxscend Microelectronics Company, Ltd. All rights reserved. Maxscend Confidential Electrical Characteristics 0.4~3.8GHz 3xSPST Antenna Tuning Switch Table 5 Nominal Operating Parameters Parameter Symbol Specification MIN Normal Condition TYP Unit Condition MAX VDD=2.8V, VIO=1.8V, VIH=1.8V, VIL=0V, PIN=0dBm, ZO=50Ω, TA=25℃, Unless Otherwise Stated DC Performances DC Supply Current IDD 100 200 μA Current on VIO IIO 5 10 μA Timing Performances Switching Speed TSW 15 Startup Time TON 30 25 μs End of MIPI Command to 90%/10% RF μs MIPI Low Power State to any RF RF Performances Isolation ISO (All off mode, RFx to RFy) 40 45 35 38 33 36 29 32 F0=0.8 to 1.0GHz dB F0=1.0 to 2.2GHz F0=2.2 to 3.0GHz F0=3.4 to 3.8GHz On Resistance RON 1.9 2.0 𝛀 Switch on Path @DC OFF Capacitance COFF 100 120 fF Switch off Path @500MHz P0.1dB +48 dBm F0=950MHz, 20% DC VRF 80 V Input 0.1dB Compression Point Peak RF Operating Voltage F0=950MHz, until 3F0 Nonlinear Isolation Mode 2F0 -70 -85 dBm 3F0 -70 -85 dBm 2F0 -55 -65 dBm 3F0 -55 -65 dBm 2F0 -55 -65 dBm 3F0 -55 -65 dBm 2nd Order Intermodulation IMD2 -105 -115 dBm Reference to Table 6 3rd Order Intermodulation IMD3 -105 -115 dBm Reference to Table 7 LTE TX Harmonic GSM LB Harmonic GSM HB Harmonic F0=700 to 2700MHz @+26dBm F0=824 to 915MHz @+35dBm F0=1710 to 2690MHz @+33dBm Page 4 / 13 MXD8533B: Rev1.5 Copyright @2018 Maxscend Microelectronics Company, Ltd. All rights reserved. Maxscend Confidential Electrical Characteristics 0.4~3.8GHz 3xSPST Antenna Tuning Switch Table 6 IMD2 Test Conditions Band In-band Frequency CW Carrier CW Interferer MHz MHz dBm MHz dBm 1 Low 2140 1950 +20 190 -15 1 High 2140 1950 +20 4090 -15 5 Low 881.5 836.5 +20 45 -15 5 High 881.5 836.5 +20 1718 -15 Table 7 IMD3 Test Conditions Band In-band Frequency CW Carrier CW Interferer MHz MHz dBm MHz dBm 1 LOW 2140 1950 +20 1760 -15 5 HIGH 881.5 836.5 +20 791.5 -15 Page 5 / 13 MXD8533B: Rev1.5 Copyright @2018 Maxscend Microelectronics Company, Ltd. All rights reserved. Maxscend Confidential MIPI Operating Mode 0.4~3.8GHz 3xSPST Antenna Tuning Switch MIPI Read and Write Timing MIPI supports the following Command Sequences:  Register Write  Register Read  Register_0 Write Figure 3 and Figure 4 illustrate the timing diagrams for register write command sequence and read command sequence, respectively. Figure 5 describes the Register_0 write command sequence. Other information such as MIPI USID programming sequences, MIPI bus specifications, etc. can be referred to the MIPI Alliance Specification for RF Front-End Control Interface (RFFE), V1.10 (26 July 2011) and the subsequent versions. In the below timing figures, SA[3:0] is the slave address. A[4:0] denotes the register address. D[7:0] means the data. “P” is a parity bit. Figure 3 Register Write Command Sequence Page 6 / 13 MXD8533B: Rev1.5 Copyright @2018 Maxscend Microelectronics Company, Ltd. All rights reserved. Maxscend Confidential MIPI Operating Mode 0.4~3.8GHz 3xSPST Antenna Tuning Switch Figure 4 Register Read Command Sequence Register_0 Write Command Sequence Figure 5 shows the Register_0 Write Command Sequence. The Command Sequence starts with an SSC, followed by the Register 0 Write Command Frame containing the Slave address, a logic ‘1’ (to denote the command type and address), and a 7-bit word to be written into Register 0. The Command Sequence ends with a Bus Park Cycle Figure 5 Register_0 Write Command Sequence Page 7 / 13 MXD8533B: Rev1.5 Copyright @2018 Maxscend Microelectronics Company, Ltd. All rights reserved. Maxscend Confidential MIPI Operating Mode 0.4~3.8GHz 3xSPST Antenna Tuning Switch Register Definition Table 8 Register definition table BROADC Register Register Data Trigger R/W Address Name Function Description Default AST_ID Bits support support 0x0000 REGISTER_0 7:0 R/W RF Control Register_0 truth Table: Table 2 0x00 No Yes 0b0 No No 0b0 No No 0b0 No No Address Frame with parity error 0b0 No No Data Frame with parity error 0b0 No No 0b0 No No 0b0 No No 0b0 No No 0x0 No No 0x0 No No 0b00 Yes No 0b0 No No 0: Normal operation 1: Software reset SOFTWARE 7 R/W Note: On software reset, this register and RESET all configurable registers are reset except for USID, GSID, and PM_TRIG. COMMAND_FR 6 R/W AME_PARITY_ Command Frame with parity error ERR COMMAND_LE 5 Command Sequence with incorrect R/W NGTH_ERR length ADDRESS_FRA RFFE_STATU 0x001A 4 S R/W ME_PARITY_E RR DATA_FRAME_ 3 R/W PARITY_ERR READ_UNUSE 2 D_REG WRITE_UNUSE 1 Read Command Sequence to an invalid R/W address Write Command Sequence to an invalid R/W D_REG address Read Command Sequence with a BSID or 0 R/W BID_GID_ERR GSID Note: Reading this register resets this register. 0x001B 7:4 R RESERVED 3:0 R/W GSID GROUP_SID Group Slave ID 00: Normal Operation (ACTIVE) 01: Reset all registers to default settings (STARTUP) 10: Low power (LOW POWER) 7:6 R/W PWR_MODE 11: Reserved 0x001C PM_TRIG Note: Write PWR_MODE[1:0]=0b01 will reset all register, and then automatically put the device into ACTIVE state. Trigger_Mask_ 5 R/W If this bit is set, trigger 2 is disabled 2 Page 8 / 13 MXD8533B: Rev1.5 Copyright @2018 Maxscend Microelectronics Company, Ltd. All rights reserved. Maxscend Confidential MIPI Operating Mode 0.4~3.8GHz 3xSPST Antenna Tuning Switch BROADC Register Register Data Trigger R/W Address Name Function Description Default AST_ID Bits support support Trigger_Mask_ 4 R/W If this bit is set, trigger 1 is disabled 0b0 No No 0b0 No No 0b0 Yes No 0b0 Yes No 0b0 Yes No 0x34 No No 0x81 No No 0b00 No No 0b11 No No 0x6 No No User Identification, with USID floated 0x7 No No User Identification, with USID tied to VIO 0x9 No No 1 If this bit is set, trigger 0 is disabled Note: When all triggers are disabled, Trigger_Mask_ 3 R/W writing to a register that is associated 0 with trigger 0, 1, or 2, causes the data to go directly to the destination register. A write of a one to this bit loads trigger 2 W Trigger_2 2's registers A write of a one to this bit loads trigger 1 W Trigger_1 1's registers A write of a one to this bit loads trigger 0's registers 0 W Trigger_0 Note: Trigger processed immediately then cleared. Trigger 0, 1, and 2 will always read as 0. 0x001D PRODUCT_ID 7:0 R 7:0 R MANUFACTU 0x001E PRODUCT_ID MANUFACTUR RER_ID ER_ID[7:0] 7:6 R 5:4 R Lower eight bits of MIPI registered Manufacturer ID RESERVED MANUFACTUR ER_ID[9:8] 0x001F Product Number MAN_USID Upper two bits of MIPI registered Manufacturer ID User Identification, with USID tied to GND 3:0 R/W USID Page 9 / 13 MXD8533B: Rev1.5 Copyright @2018 Maxscend Microelectronics Company, Ltd. All rights reserved. Maxscend Confidential Power ON and OFF Sequence 0.4~3.8GHz 3xSPST Antenna Tuning Switch Power On and Off Sequence Here is the recommendation for power-on and power-off sequence in order to avoid damaging to the device. Power On 1) Apply voltage supply - VDD 2) Apply logic supply - VIO 3) Wait 30μs or longer and then apply MIPI bus signals – SCL and SDA 4) Wait 25μs or longer after MIPI bus goes idle and then apply the RF Signal Power Off 1) Remove the RF Signal 2) Remove MIPI bus – SCL and SDA 3) Remove logic supply - VIO 4) Remove voltage supply - VDD VDD VIO ON ON CMD CMD START END RF ON RF OFF VIO OFF VDD OFF VDD 10us 10us VIO Slave State SHUTDOWN ACTIVE STARTUP 30us 25us SHUTDOWN No Operations During RF ON SDA,SCL RF Signal RF ON Figure 6 Power On and Off Sequence Notice  VIO can also be applied to the device before VDD or removed after VDD.  It is important not to send any SDA until a 10us or longer waiting time following the VDD and VIO startup to ensure corrective data transmission.  Operations of SDA or SCL are strictly prohibited during RF On period so as to prevent the device being damaged.  The minimum time between a power up and power down sequence (and vice versa) shall be 100us or longer. Page 10 / 13 MXD8533B: Rev1.5 Copyright @2018 Maxscend Microelectronics Company, Ltd. All rights reserved. Maxscend Confidential Package Information 0.4~3.8GHz 3xSPST Antenna Tuning Switch Package Outline Dimensions Figure 7 Package Outline Dimensions Page 11 / 13 MXD8533B: Rev1.5 Copyright @2018 Maxscend Microelectronics Company, Ltd. All rights reserved. Maxscend Confidential Package Information 0.4~3.8GHz 3xSPST Antenna Tuning Switch Marking Specification Fixed: Product Code 33B 33B AAA Variable: Lot code From 1~9 and A~Z excluding letter I and O for each letter PIN1 Figure 8 Marking Specification (Top View) Tape and Reel Dimensions Figure 9 Tape and Reel Dimensions Page 12 / 13 MXD8533B: Rev1.5 Copyright @2018 Maxscend Microelectronics Company, Ltd. All rights reserved. Maxscend Confidential Package Information 0.4~3.8GHz 3xSPST Antenna Tuning Switch Reflow Chart tP TP Critical Zone TL to TP Ramp-Up Temperature TL TSMAX tL TSMIN tS Ramp-Down Preheat t25-TP Time Figure 10 Recommended Lead-Free Reflow Profile Table 9 Reflow Chart Parameters Reflow Profile Preheat Temperature(TSMIN to TSMAX) Preheat Time(ts) Parameter 150℃ to 200℃ 60 to 180 Seconds Ramp-Up Rate(TSMAX to TP) 3℃/s MAX Time Above TL 217℃(tL) 60 to 150 Seconds Peak Temperature(TP) 260℃ Time within 5℃ of Peak Temperature(tP) Ramp-Down Rate(TSMAX to TP) Time for 25℃ to Peak Temperature(t25-TP) 20 to 40 Seconds 6℃/s MAX 8 Minutes MAX ESD Sensitivity Integrated circuits are ESD sensitive and can be damaged by static electric charge. Proper ESD protection techniques should be applied when devices are operated. RoHS Compliant This product does not contain lead, mercury, cadmium, hexavalent chromium, polybrominated biphenyls (PBB) and polybrominated diphenyl ethers (PBDE), and are considered RoHS compliant. Page 13 / 13 MXD8533B: Rev1.5 Copyright @2018 Maxscend Microelectronics Company, Ltd. All rights reserved. Maxscend Confidential
MXD8533B 价格&库存
很抱歉,暂时无法提供与“MXD8533B”相匹配的价格&库存,您可以联系我们找货
