MH180KUA
MH180KUA
    MST.(美伽)
    TO-92S
    霍尔效应锁存器
MH180KUA 数据手册
MH180 Specifications Ultra High Sensitivity Hall Effect Latch MH180 Hall-effect sensor is a temperature stable, stress-resistant sensor. Superior high-temperature performance is made possible through a dynamic offset cancellation that utilizes chopper-stabilization. This method reduces the offset voltage normally caused by device over molding, temperature dependencies, and thermal stress. MH180 includes the following on a single silicon chip: voltage regulator, Hall voltage generator, small-signal amplifier, chopper stabilization, Schmitt trigger, Pull-up resistor output. Advanced DMOS wafer fabrication processing is used to take advantage of low-voltage requirements, component matching, very low input-offset errors, and small component geometries. This device requires the presence of both south and north polarity magnetic fields for operation. In the presence of a south polarity field of sufficient strength, the device output sensor on, and only switches off when a north polarity field of sufficient strength is present. MH180 is rated for operation between the ambient temperatures –40℃ and 85℃ for the E temperature range, and –40℃ to 125℃ for the K temperature range. The two package styles available provide magnetically optimized solutions for most applications. Package SO is an SOT-23, a miniature low-profile surface-mount package;Package SF is an SOT89-5L, a low-profile surface-mount package, while package UA is a three-lead ultra mini SIP for through-hole mounting. Packages is Halogen Free standard and which have been verified by third party lab. Features and Benefits ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ DMOS Hall IC Technology. Reverse bias protection on power supply pin. Chopper stabilized amplifier stage. Optimized for BLDC motor applications. Reliable and low shifting on high Temp condition. Switching offset compensation at typically 69 kHz. Good ESD Protection. 100% tested at 125 ℃ for K. Custom sensitivity / Temperature selection are available. RoHS compliant 2011/65/EU and Halogen Free Applications ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ 080519 High temperature Fan motor 3 phase BLDC motor application Speed sensing Position sensing Current sensing Revolution counting Solid-State Switch Linear Position Detection Angular Position Detection Proximity Detection High ESD Capability Page 1 of 5 Rev. 1.01 MH180 Specifications Ultra High Sensitivity Hall Effect Latch Ordering Information Company Name and Product Category MH:MST Hall Effect/MP:MST Power IC Part number 181,182,183,184,185,248,249,276,477,381,381F,381R,382….. If part # is just 3 digits, the forth digit will be omitted. Temperature range E: 85 ℃, I: 105 ℃, K: 125 ℃, L: 150 ℃ Package type UA:TO-92S,VK:TO-92S(4pin),VF:TO-92S(5pin),SO:SOT-23, SQ:QFN-3,ST:TSOT-23,SN:SOT-553,SF:SOT-89(5pin), SS:TSOT-26,SD:DFN-6 Sorting α,β,Blank….. Part No. MH180KUA MH180KSO MH180EUA MH180ESO MH180KSF Temperature Suffix K (-40℃ to + 125℃) K (-40℃ to + 125℃) E (-40℃ to + 85℃) E (-40℃ to + 85℃) E (-40℃ to + 125℃) Package Type UA (TO-92S) SO (SOT-23) UA (TO-92S) SO (SOT-23) SF (5-pin SOT-89) KUA spec is using in industrial and automotive application. Special Hot Testing is utilized. Functional Diagram VDD Out Voltage Regulator Amp Hall Sensor Clock GND 080519 Page 2 of 5 Rev. 1.01 MH180 Specifications Ultra High Sensitivity Hall Effect Latch Absolute Maximum Ratings At (Ta=25℃) Characteristics Supply voltage, (VDD) Output Voltage,(Vout) Reverse voltage, (VDD) Magnetic flux density Output current, (ISINK) Operating Temperature Range, (Ta) “E” version “K” version Storage temperature range, (Ts) Maximum Junction Temp,(Tj) (θja) UA / SO/ SF Thermal Resistance (θjc) UA / SO/ SF Package Power Dissipation, (PD) UA / SO/ SF Values 28 28 -28 Unlimited 50 -40 to +85 -40 to +125 -65 to +150 150 206 / 543/ 156 148 / 410/ 34 606 / 230 / 800 Unit V V V Gauss mA ℃ ℃ °C °C ℃/W ℃/W mW Note: Do not apply reverse voltage to VDD and VOUT Pin, It may be caused for Miss function or damaged device. Electrical Specifications DC Operating Parameters: TA=+25℃, VDD=12V Parameters Test Conditions Supply Voltage,(VDD) Operating Supply Current,(IDD) BBOP Output Leakage Current, (Ioff) IOFF B
MH180KUA 价格&库存
很抱歉,暂时无法提供与“MH180KUA”相匹配的价格&库存,您可以联系我们找货
