AD5U480016G8-BSSB
AD5U480016G8-BSSB
    ADATAINDUSTRIAL
    UDIMM288
    存储器 - 模块 DDR5 SDRAM 16GB 288-UDIMM
AD5U480016G8-BSSB 数据手册
DDR5 U-DIMM Memory Module The ADATA industrial-grade DDR5 Unbuffered-DIMM memory module is capable of reaching speeds of up to 4800 MT/s and yet only operates on 1.1V, which is ideal for edge computing, IoT, 5G, and industrial PC related applications. In addition, it is equipped with a Power Management IC (PMIC) to enhance power supply stability. Offering high capacities up to 32GB, the ADATA industrial-grade DDR5 memory can fulfill demands of big data analysis, deep learning and high speed computing (HPC). With On-die ECC (Error Correction Code), this DDR5 module can also self-correct errors, effectively improving transmission reliability. - UItra-high speed of 4800 MT/s - High capacities up to 32GB - Power Management IC (PMIC) ensures power supply stability - Ultra-low operating voltage of 1.1V for improved power efficiency - On-die ECC technology for more reliable data transmission - 30µ PCB gold plating for improved product durability and longevity - Customized services: Anti-Sulfuration and Conformal Coating help to enhance the product durability in harsh environments - Suitable for edge computing, IoT, 5G, and industrial PC related applications Capacity P/N IC Configuration 8GB AD5U48008G4-BSSB 1024x16 16GB AD5U480016G8-BSSB 2048x8 32GB AD5U480032G8-BSSB 2048x8 Model DDR5 U-DIMM DDR5 Interface U-DIMM Module Type 4800 MT/s Frequency Capacity 8GB/16GB/32GB Pin Count 288-pin Standard 1.23” PCB Height 1.1V Operating Voltage 0ºC to 85ºC Operating Temperature JEDEC Standard Yes RoHS HQ (Taiwan): EU: JP: T: +886-8228-0886 T: +49-899-0405-296 T: +81-3-5807-0011 E: adata@adata.com E: IASales_eu@adata.com E: IASales_jp@adata.com US: China APAC/MEA: T: +1-714-332-8708 T: +86-21-6233-1010 E: IASales_apacmea@adata.com E: IASales_us@adata.com E: IASales_cn@adata.com
AD5U480016G8-BSSB 价格&库存
很抱歉,暂时无法提供与“AD5U480016G8-BSSB”相匹配的价格&库存,您可以联系我们找货
