AD4U3200732G22-BSSA
AD4U3200732G22-BSSA
    ADATAINDUSTRIAL
    UDIMM288
    存储器 - 模块 DDR4 SDRAM 32GB 288-UDIMM
AD4U3200732G22-BSSA 数据手册
Designed for enterprise servers and data centers, ADATA’s DDR4 U-DIMM features outstanding durability and power efficiency to meet the strictest demands of long-term operations. Without comprising reliability and stability, ADATA’s DDR4 U-DIMMs run on a mere 1.2 volts, and thus require 20% less power than outdated DDR3 memory. With this in mind, ADATA’s DDR4 UDIMMs are your environmentally friendly choice for operational cost savings and extended lifespan. Key Features - High speed up to 3200MHz - Large capacity up to 32GB - Transfer bandwidths up to 25.6GB/s - Energy efficient: save up to 20% compared to DDR3 - PCB gold plating: 30µ and up - Supports Intel® Core™ 8th/9th/10th series and AMD® ZEN 2nd 3rd Ryzen™ series - High-quality PCB provides improved signal transfer and system stability. Target Applications Server, Data Center, Embedded System, Box PC, POS ● Supported ─ Not available industrial.ada t a.com Specifications Model DDR4 3200 U-DIMM Speed 3200MHz Form Factor Standard (1.23” height) Interface 288 Pin Capacity 8GB / 16GB / 32GB IC Configuration 1024M x 8 / 2048M x 8 Timing CL-tRCD-tRP-tRAS 22-22-22-52 Voltage 1.2V Rank Number 1Rank / 2Rank Operating Temperature 0ºC to 85ºC Golden Finger Plating 3 or 30 micro inch Warranty Lifetime Standard JEDEC RoHS Yes Application Embedded system, Medical application Ordering Info Capacity P/N IC Configuration 8GB AD4U320038G22-BSSC 1024M x 8 16GB AD4U3200316G22-BSSC 1024M x 8 32GB AD4U3200732G22-BSSA 2048M x 8 ADATA Technology 2F, No. 258, Liancheng Rd., Zhonghe Dist., New Taipei City 235, Taiwan industrial.ada t a.com
AD4U3200732G22-BSSA 价格&库存
很抱歉,暂时无法提供与“AD4U3200732G22-BSSA”相匹配的价格&库存,您可以联系我们找货
