APHC-12708-S
APHC-12708-S
    EUROPEANTHERMODYNAMICS
    Module
    Peltier 模块 7.4 A
APHC-12708-S 数据手册
APHC-12708-S Peltier Cooler Module - High Temperature Cycling Data sheet Imax Vmax Pc max ACR ΔTmax Max. hot side temp. A A1 B H L Wire Features • • • • • • • • • • • [A] [Vdc] [W] [Ω] [°C] 7.4 14.7 71 1.6 66 [°C] 180 [mm] [mm] [mm] [mm] [mm] AWG 40 44 40 3.5 100 20 (At hot side temperature Th = 27°C / 300K, under dry N2 ) Pc max = Cooling power at ΔT = 0 and I = Imax ΔTmax = Temperature difference at I = Imax and Pc = 0 Max mounting pressure: 1.5MPa AF250 Teflon wire, 600V, -80 to +250degC RoHs and Reach 161 compliant Solid-state reliability High integrity nickel diffusion barriers on elements High strength for rugged environments Porched style for enhanced leadwire strength Sealed & lapped for multi-module applications Adaptive is a registered trademark of European Thermodynamics Limited. Web: www.europeanthermodynamics.com Tel: +44(0)116 279 6899 E-mail: info@etdyn.com Version 3 - 2020 Page 1 APHC-12708-S Peltier Cooler Module - High Temperature Cycling Data sheet - At hot side temperature 25°C 80 70 60 I = 5.00 A 50 I = 4.00 A I = 3.00 A 40 I = 2.00 A 30 Max COP 20 I = 6.00 A 140 I = 5.00 A 120 I = 4.00 A 100 I = 3.00 A 80 I = 2.00 A 60 40 10 0 I = 7.40 A 160 I = 6.00 A Waste heat (W) Heat removed (W) 180 I = 7.40 A 20 0 20 40 60 0 80 0 20 Temperature difference (oC) 16.0 80 I = 6.00 A 12.0 I = 5.00 A 10.0 I = 4.00 A I = 3.00 A 8.0 I = 2.00 A 6.0 4.0 Delta T = 0 C 4.5 Delta T = 10 C 4.0 Delta T = 20 C 3.5 Delta T = 30 C 3.0 COP Input Voltage (V) 60 5.0 I = 7.40 A 14.0 Delta T = 40 C 2.5 2.0 Delta T = 50 C 1.5 Delta T = 60 C 1.0 2.0 0.0 40 Temperature difference (oC) 0.5 0 20 40 60 80 0.0 0 Temperature difference (oC) Adaptive is a registered trademark of European Thermodynamics Limited. Web: www.europeanthermodynamics.com Tel: +44(0)116 279 6899 2 4 6 8 Current (A) E-mail: info@etdyn.com Version 3 - 2020 Page 2 APHC-12708-S Peltier Cooler Module - High Temperature Cycling Data sheet - At hot side temperature 50°C 90 80 70 I = 5.00 A 60 I = 4.00 A 50 I = 3.00 A 40 I = 2.00 A 30 Max COP 60 I = 3.00 A 100 I = 2.00 A 80 60 20 40 I = 4.00 A 120 40 20 I = 5.00 A 140 10 0 I = 6.00 A 160 20 0 I = 7.40 A 180 I = 6.00 A Waste heat (W) Heat removed (W) 200 I = 7.40 A 0 80 0 20 Temperature difference (oC) 18.0 I = 4.00 A 10.0 I = 3.00 A 8.0 I = 2.00 A 6.0 Delta T = 40 C 2.0 Delta T = 50 C 1.5 Delta T = 60 C 1.0 0.5 80 Delta T = 30 C 2.5 2.0 60 Delta T = 20 C 3.0 4.0 40 Delta T = 10 C 3.5 COP Input Voltage (V) 12.0 Delta T = 0 C 4.0 I = 5.00 A 20 80 4.5 I = 6.00 A 14.0 0 60 5.0 I = 7.40 A 16.0 0.0 40 Temperature difference (oC) 0.0 0 Temperature difference (oC) Adaptive is a registered trademark of European Thermodynamics Limited. Web: www.europeanthermodynamics.com Tel: +44(0)116 279 6899 2 4 6 8 Current (A) E-mail: info@etdyn.com Version 3 - 2020 Page 3 APHC-12708-S Peltier Cooler Module - High Temperature Cycling Data sheet - At hot side temperature 75°C 90 I = 6.00 A 70 I = 5.00 A 60 I = 4.00 A 50 I = 3.00 A 40 I = 2.00 A 30 Max COP Waste heat (W) Heat removed (W) 250 I = 7.40 A 80 20 I = 7.40 A I = 6.00 A 200 I = 5.00 A I = 4.00 A 150 I = 3.00 A I = 2.00 A 100 50 10 0 0 20 40 60 80 0 100 0 Temperature difference (oC) 60 80 100 6.0 I = 7.40 A 18 I = 6.00 A 16 14 I = 3.00 A 10 I = 2.00 A 8 Delta T = 10 C Delta T = 20 C 4.0 I = 4.00 A 12 Delta T = 0 C 5.0 I = 5.00 A COP Input Voltage (V) 40 Temperature difference (oC) 20 Delta T = 30 C Delta T = 40 C 3.0 Delta T = 50 C 2.0 6 4 Delta T = 60 C 1.0 2 0 20 0 20 40 60 80 100 0.0 0 Temperature difference (oC) Adaptive is a registered trademark of European Thermodynamics Limited. Web: www.europeanthermodynamics.com Tel: +44(0)116 279 6899 2 4 6 8 Current (A) E-mail: info@etdyn.com Version 3 - 2020 Page 4
APHC-12708-S 价格&库存
很抱歉,暂时无法提供与“APHC-12708-S”相匹配的价格&库存,您可以联系我们找货
