GM250-127-14-16
GM250-127-14-16
    EUROPEANTHERMODYNAMICS
    Module
    Peltier 模块
GM250-127-14-16 数据手册
GM250-127-14-16 Thermoelectric Generator Module Parameters for hot side temp 2500C and cold side temp 300C Matched load output power Matched load resistance Open circuit voltage Matched load output Matched load output voltage Heat flow through module Maximum compress (non-destructive) Maximum operation temperature 6.99W 3.65Ω ± 15% 10.11V 1.38A 5.05V ~ 139.8W 1.2MPa Hot side - 2500C. Cold side - 1750C Features • • • • • Compact structure (no moving parts) Reliable performance Maintenance-free Noise-free operation Low-carbon, green technology Geometric Dimensions A B H 40mm 40mm 4.1mm Adaptive is a registered trademark of European Thermodynamics Limited. Web: www.etdyn.com Tel: +44(0)116 279 6899 E-mail: info@etdyn.com Version 2 - 2017 Page 1 GM250-127-14-16 Thermoelectric Generator Module Note: Th = hot side temperature Adaptive is a registered trademark of European Thermodynamics Limited. Web: www.etdyn.com Tel: +44(0)116 279 6899 E-mail: info@etdyn.com Version 2 - 2017 Page 2 GM250-127-14-16 Thermoelectric Generator Module Note: Th = hot side temperature Adaptive is a registered trademark of European Thermodynamics Limited. Web: www.etdyn.com Tel: +44(0)116 279 6899 E-mail: info@etdyn.com Version 2 - 2017 Page 3
GM250-127-14-16 价格&库存
很抱歉,暂时无法提供与“GM250-127-14-16”相匹配的价格&库存,您可以联系我们找货
